Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
Anonymous Posted on Sep 21, 2008
My cuisinart coffee maker just recently started not using all the water I've poured into the reserve. Up 'til today it was leaving the last two cups in the reserve, but today, out of the six cups I poured in there, it only made two. The funny thing, is that if I run it again, ( I turn off the grinder), it then uses the rest of the water.
  • 4 more comments
  • Anonymous Feb 17, 2009
    same problem- The thing is 5 years old and suddenly it is leaving 2 cups+ of water in the reservoir when it's done brewing.
  • Anonymous Feb 20, 2009
    Leaves 2-3 cups water in the resevior after brewing. It has a 3 year warranty, they are sending me a new one
    I can't believe this - my filter pops out during brewing AND it is no longer using all the water in the resevoir. So much for going with an upscale brand
  • shelbyo Feb 22, 2009
    This is our second machine. Our first one started having that problem after 4 years of moderate use. We just bought another one this past September 08 and it just started having that problem again! We use it every day now, more than before, but have only had it for 6 months! We also found that the 1 to 4 cup setting works. We'll see how long it actually keeps working. This is disappointing from Cuisinart. We ran our newer coffee maker with CLR to clean it out and ran clean water through many times, but still had the problem. We did try the vinegar with the old machine, but that did not work. Old machine actually didn't work even when restarted, so we definitely had to get a new one.
  • jeffro9900 Mar 01, 2009
    my pot does the same. it shuts down after a few cups of water has passed through it. it takes 5 cycles turning in on to brew a full pot.talk about junk!
  • Anonymous Nov 05, 2011
    PS: We cleaned out the coffee maker with the vinegar and water a couple times this week and it didn't work.
ThaMp3Doctor
Level 3:
  • Master 8,597 Answers
  • Posted on Sep 26, 2008
ThaMp3Doctor
Master
Level 3:
Answers
8597
Questions
Helped
2173438
Points
14133
Pour a solution of 50% vinegar and 50% water into the machine and brew - this is going to decalcify the coffee maker, and hopefully solve the problem. let me know how it works out.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Sep 23, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
949
Points
This is a real problem with these coffee makers, and there's not much that can be done. However, there is a work around: before brewing, just hit the button to brew 1-4 cups. It'll still brew a whole pot, it'll use all the water, the coffee will taste no different, and you can still program it however you'd like. Cheers!
Cuisinart dgb-650
In an empty machine,(no coffee, no filter), pour in a 50-50 mixture of water and white vinegar. Allow the machine to start brewing and when a cup or so has run through, stop the brewing process and let it sit for an hour or two. This should dissolve some of calcium buildup in the machine and allow it to complete a full cycle. May have to do this a couple of times to fully clean out the mineral buildup. After cleaning, run a pot of clear water through to rinse out the remaining vinegar.
Coffee drips how do you clean reserve
Fill the pot with viniger at least up to half, Pour it in the researve tank end let it go though as if your makeing coffee with it, Do that 2 times, Then after it is finish doing the secound pot,leave it in for 30 minutes. Dump it out, Then do the same (Again) But use (water) to do it with, Once the .2 pot of water have gone though it ,then it is ready to use again, this should claen it up for you.
We've had a Cuisinart DCC-2000 coffee maker for less than a year: 1) it stops brewing about halfway through the brewing cycle (with plenty of water still in the reservoir, and 2) the "Clean" light
This problem is caused by a clogged water filter in the unit.
Unplug the coffee maker.
Open the top panel where you normally pour in the water and set the coffee filter.
Gently pull up on the tap that sticks up in the back left corner of the open top. This will free a long plastic part that has a compartment at the bottom that contains a filter filled with charcoal.
Unsnap the small compartment that holds the filter and clean it gently under running water with light brushing.
If there is a lot of coffee build-up, the water chamber where you normally pour in fresh water needs to be cleaned out. Pour in a cup of water and invert the unit over a large sink pouring out the water through the opening you normally use to fill the unit.
Repeat this until you remove the coffee grounds.
Let the unit dry fully before plugging in to run again.
My Cuisinart DCC-1200 takes a long time to brew now, the coffee is weak, and the self-clean button flashes each time. I've had it for about 4 years.
Over time, Calcium will deposit on the tubes and containers which get in touch with water.
The calcium can also impact the function of the Heating elements in the percolator tube.
Try Decalcifying with Designated Products.
Usually, you do this by diluting the product, fill up the water reservoir, and cycle on the machine, without cofee of course,
Pour out the water. It will probably look troubled.
If the water does not start percolating, just let the water reservoir stand with the decalcification product for about 30 mins. don't leave it in overnight, because these products are slightly caustic to remove the Calcium, but it could damage parts if left in the machine overnight.
Repeat the process until the water starts running faster and/or gets hotter.
don't forget to rinse with regular water. 2 Cycles rinsing should suffice.
See manual for suggested products or just use 1/4 cup of Vinegar diluted with Water per caraffe. It will smel like vinegar while you do this, as the vinegar evaporates with some of the steam.
I would repeat this process every month or so if you use your machine daily.
If this does not solve, try contacting cuisinart customer service at 1-800-726-0190
2helpful
Cuisinart DC 1150 (10 cup) coffee maker leaks out of the top.
I have experienced this same problem. You have to pour the water directly into the holding bay, avoiding the edges. I think water gets stuck around the rim, it just steams over the edge, or drips down the front and back onto the counter. I don't know why, but it happens, so just make sure you pour the water directly into the bay avoiding edges.
Funny tasting coffee
Vinegar/water cleaning is a good idea, but it won't necessarilly solve funny-tasting coffee. First, replace your charcoal water filter - you can get the Cuisinart brand-name replacements at Lowe's, Bed/Bath/Beyond, or Williams-Sonoma in most areas.
To do the vinegar/water cleaning, just pour 1/3 caraffe distilled white vinegar and 2/3 caraffe water into the water reservoir and brew it like it was regular coffee - I would simply bypass the self-clean function if your Cuisinart has one. Repeat up to 3 times, using a fresh batch of vinegar each time.
(if you have the caraffe-less DCC-2000, then just pour in 4 cups vinegar and 6 cups water).
Then run a full cycle of water. Then run a combo of 12 tsp lemon juice and 12 cups water (or 10 tsp and 10 cups water) to improve the taste.
On your next batch of coffee, use bottled water just to rule out any possibility that your local water supply may be contributing to funny-tasting coffee.
Now your coffee should be tasting fine again.
-Tha Mp3 Doctor
After taking out the filter basket and all the moveable parts, how do you clean the coffee maker itself?
You actually have to put the parts back in place (except the charcoal water filter and any paper filter you may or may not be using), pour in 2 cups distilled white vinegar and two cups water, and brew the vinegar/water solution just like it was coffee. Vinegar is very acrid, so you will then need to brew plain water to flush out the vinegar. Now, you can put everything back in place, and you are good to go. Remember - if one part is out of place, your coffee maker may beep at you incessantly.
-Tha Mp3 Doctor (also loves Cuisinart)
4helpful
3answers
Cuisinart DCC2000 quits brewing after 1or 2 cups
Finally, I got my coffee pot to run through without stopping several times. To fix it I had to run vinegar through eight times! Never before has it taken so many cycles to clean out a pot. It is still spluttering a bit so today I am going to get more vinegar or maybe even CLR and run it through a few more times.
7helpful
Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Top Cuisinart Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
john h
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
