Hello, You can get better prices for bulbs on the Internet. I went through this problem with my set.
Sometimes there is an upgrade in bulb Wattage on an individual basis by Model. What you may be having problems with is a system called a "Light Engine". This assembly has the power module and a spinning part called a "Light Wheel".
Your problem then can be from any of these devices. Your old bulb could have a dark spot (As normal light bulbs can develop), a weak power module, or a light wheel not spinning at the correct RPM for clarity.
You can take a chance and try a new bulb yourself or call for a Technician to give you either a "Convergence Set-up" or Evaluation and Repair estimate.
I learned about the insides of these TV's from the Front-Projectors and my own Rear-Projectors which had Warranty Recalls. So I have seen Messed-up and know what it looks like and somewhat about the causes and cures.
If you are getting a Convergence service, you may want to get the Estimate, then install a new bulb through the Internet, and then get it all set up fresh with the new bulb.
1. Press the OK or enter button on the front panel and MUTE
button on the remote control simultaneously (About 5 seconds).
2. Press the VOLUME (>) button.
3. Press the OK or enter button.
Lamp time will be reset.
