Question about Saeco Milk Island Automatic Frother - EssentialEspresso.com
Milk island error message
Hi, I have a Saeco Talea ring machine.  When I turn the know to the  milk Island setting I receive the error message 'milk island missing'.  If I remove the glass carafe the message changes to 'missing carafe', so it must know the milk island is connected.  Any ideas?
  • 1 more comment
  • AusFC Sep 29, 2008
    hi thanks for this solution, it took a couple of days to dry out but it works!!!
    thanks again
  • schumacherf1 Oct 13, 2008
    I recently have the same problem.  Do you need to disconnect the arm in order to let it dry out?  How many days did it take before it was dried and working properly again?  Also has this happened to you again? how can this moisture be prevented?
  • lala11lala Nov 30, 2008
    error says "milk island missing" - it is there and sometimes it works ok - I saw a post about drying it out - did that work?
  • 515 Answers
I think the problem is the arm where the carafe are connected, if there comes damp down in the arm then you can get this message.
/Mirran
Posted on Sep 22, 2008
Saeco talea grinder is starting when you start the machine
this sounds like the machine simply needs a good cleaning due to grounds jamming the switch in place
Sep 05, 2014 | Saeco Talea Ring Plus Espresso Maker with...
On my talea ring plus i get an error code 5. anybody knows what that is?
Error 5 is the water circuit is block, or airlock in the system that means you have to purge the air out.
Feb 11, 2010 | Saeco Talea Ring Plus Espresso Maker with...
Milk island does not foam milk. i have the switch in the right position. how do i set the two part valve on the milk island?
Clean the milkisland valve,that is on top of the jug.Careful not to loose the small rubber valve which control the air to make foam.To set valve, one side for hot milk, and the other is for foam.
Jan 19, 2010 | Saeco Talea Ring Plus Espresso Maker with...
Error Code 4 on Saeco Talea Ring
I need to know what error code 4 means as well.
Has anyone helped you yet?
Apr 05, 2009 | Saeco Talea Ring Plus Espresso Maker with...
HOW DO I GET THE INSTRUCTION MANUEL FOR A SAECO TALEA RING PLUS COFFE MACHINE?????
The French Saeco website has manuals (in English as well as French).
Try this url…
http://www.saeco.fr/en/manuali/manuali.html
HTH
Mar 16, 2009 | Saeco Talea Ring Plus Espresso Maker with...
Saeco Talea Ring Plus not frothing milk
per il milk island asciugare bene la valvolina e tutti i fori del blocco di plastica che fa da montalatte devono essere perfettamente asciutti dare dei colpetti alla valvola per fare uscire eventuale acqua all interno.
MORENO
Feb 20, 2009 | Saeco Talea Ring Plus Espresso Maker with...
What Descale sign means
Start the descaling and follow the instruction the machine give you.
Best regards
/Mirran
Sep 06, 2008 | Saeco Talea Ring Plus Espresso Maker with...
Milk island seems to leak water. After milk is frothed and island has been detached fro some time, a pool of water forms under the base of the milk island attachment and on top of it.
Milk island on a vienna class?
Perhaps its a Saeco Talea you have, correct?
First remember that after foaming your milk and have turned the knob back to´off location. wait until you hear a clicking sound from the machine, might take 2 -5 seconds after it set to off.
Then remove the milk container
That sound means it has close 100% and shouldent leak.
If it still leaks after that its the gaskets in the T-pipe that needs to be changed.
Jul 07, 2008 | Saeco Vienna De Luxe Espresso Machine
Coffee maker
I think that the electric board in milk island is gone and have to be replaced. If the milk island is leaking then it goes into the milk island and you get a short circuit:-(
Mar 19, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Milk Island Automatic Frother - EssentialEspresso.com Logo
515 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
