Question about Nikon D40x Digital Camera
Nikon\d40x camera the flash mode button will not pop up the built in electronic flash.
Shove the camera in an oven for about 20 minutes on 450f. this will melt the internal postules back together.
Posted on Sep 22, 2008
Nikon D40. How do i force the flash to work in daylight?
First, you have to be in one of the PSAM modes; in the other modes the camera decides whether it needs the flash and in daylight it will decide there's enough light without it. So, after turning the model dial to one of the PSAM positions, press the flash button on the front of the camera to pop up the flash. In these modes the camera will fire the flash if it's popped up, and not if it's down.
To change the flash mode, hold down the flash button (after it's popped up) and turn the command dial. Depending on the chosen exposure mode, your choices may include Fill flash, Red-eye reduction, Rear-curtain sync, Slow sync, Rear-curtain plus red-eye reduction, and Rear-curtain plus slow sync. Refer to the "Flash Mode" section of the manual for full details.
Jul 30, 2011 | Nikon D40x Digital Camera
I have a Nikon D40X. The built in flash pops up but the flash does not go off (light up)....not aware of the capability of turning it off manually.
You have 2 options to try before you consider a service tech to look @ the camera.
Prelim : Ensure the batteries are charged & your using standard batteries.
Option 1 : Put the dial in Auto mode and see if that helps with the flash, also ensure you are trying to click the picture in a dim or dark environment, else the Auto flash won't fire if the environment is bright enough
Option 2 : Backup your pictures and reset your camera by using the menu. This should take care of any settings that might have been accidentally turned ON or OFF, then try to get back to the option 1 to see if the flash fires... (you will have to set the date & time post this action)
Mar 30, 2011 | Nikon D40x Digital Camera
Flash on my Nikon D40x digital camers not working.
First look at you mode dial on the camera and make sure it is not on the setting with a picture of a flash with a cross through it. If that doesn't work in your menu see if the flash is disabled. Note: When On A Manual Mode You Need To Manually Pop Up The Flash
Oct 24, 2010 | Nikon D40x Digital Camera
Nikon D40x flash will not go off
I have the D40x. Only thing i can think of is the little sensor thing on the front down and to the left of the release button. If you have your finger over it, the flash don't work and the focus won't work right. "Infrared assist" in the manual. Myself, I use the sb400 strobe flash cause the popup flash uses too much power from the camera battery.
Jun 28, 2009 | Nikon COOLPIX L3 Digital Camera
Nikon D40X built in flash doesn't pop up automatically
This is a common fault with the D40x. You will need to contact Nikon for repair details.
Mar 31, 2009 | Nikon D40x Digital Camera
Nikon d40 built in flash not firing but it popped up
there is a sensor in there that tells the camera the flash is up you need to take it to a repair shop its not a at home thing
Mar 11, 2009 | Nikon D40x Digital Camera
I HAVE A NIKON D40X.I CANNOT GET THE BUILT IN FLASH TO WORK.IT IS IN AUTO MODE AND FLASH IS TURNED ON.IF I ATATCH AN EXTERIA FLASH IT FIRES EVERY TIME.I HAVE TRIED IT ON ALL THE OTHER MODES,IT DID FIRE...
In Auto mode the flash will only fire when the camera thinks it needs it.
Only in the PASM modes do you get to decide whether to use the flash or not.
Aug 27, 2008 | Nikon Cameras
Flash not automatically opening up.
Check the flash setting in the shooting mode (on Auto). Press the "?" button twice. You should see the flash mode window. Small box on the lower left for flash settings (hi-lighted in yellow, or navigate to it). Press OK to see and change flash settings to your preference.
Apr 18, 2008 | Nikon D40x Digital Camera
Nikon D40X inbuilt flash
If it's withing 30 days, get it exchanged. I have a D70s and it's been working fine for me, maybe something with the D40x with other customers? Take it back to the store and let an "instructor" try it out to make sure it's not a setting.
It's great for the manufacturer to know about any problems so they can get a good sample of problems to help many people. Good luck.
Nov 16, 2007 | Nikon D40x Digital Camera
Nikon D40x Digital Camera Logo
65 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
