Tape is stuck in the vcr and when you turn on the power it turns the tape about 10 seconds and then shuts off the power.
  • illhite Sep 22, 2008
    Finally got the tape out by hand winding little motor, tried a new tape still does not eject, play, rewind, fast forward and power still cuts off. Wondering if little motor isnt bad? how can I tell?
    Sergeant:
  • 305 Answers
If the tape has snagged inside, the only way to get it out is to take the top of the vcr off and manually remove it. very simple procedure. only use your fingers and not anything sharp. have you tried rewinding the tape (from STOP mode) sometimes tapes can end up being wound very tight which would have the same effect. if you can rewind do so, then fast forward until tape stops, repeat this a few times this should loosen the tape.
Posted on Sep 22, 2008
HOW DOES THE TAPE CARRIAGE EJECT AND LOAD?
go to mcmelectronics.com and order the replacement belt kit. then google your model number on alignment pdf. Your mechanism is out of alignment due to bad belts
Dec 03, 2017 | Televison & Video
My grandson was watching an old VHS tape and pushed something. Now, all I see when I turn the t.v. on is "counter00.00" and then the t.v. shuts off in about 3 seconds. I have lost the owners manual. HELP!
Left up the VCR tape gate,see,if the tape still in there?Yes,unplug,10 mins.replug the Tv and push the tape forward botton.Let the tape go forward about 5 sec. eject the tape take out.Grandson probally rewind the same seen to many times,causing power power shotdown mode.
Aug 09, 2010 | Symphonic SC3813 13 in. TV/VCR Combo
I put a tape in and I hear a loud clicking noise and the VCR doesn't play the tape and turns itself off after 8-10 seconds.
first, try another tape. if it does the same thing the vcr is out of alignment. many times a broken lever inside the vhs tape can cause the vcr to shut down.
Mar 05, 2010 | Panasonic PV-9662 VCR
VCR tape was hung in Sylvania SRDV495. Got the
You need the aligniament the eject gears to tape gears.Please remove the cover platen and the rear cover(bottom) and align the gears manually.Obturated the sensors hole and insert the cassette.Verify the eject and the tape belts.If you have knowlwdge VCRs the problems solved in 1 hour.
Aug 21, 2009 | Sylvania Televison & Video
A tape was stuck, As I tried to get it out the
I geuss the timing of the deck is off.Realignment wil be needed.
Aug 01, 2009 | Symphonic SL260A S-VHS VCR
T.v. ejecting vcr tape and turning self off after being turned on
If VCR mechanism doesn't load or unload properly, TV will shut off. VCR machnisam in your TV requires cleaning/ service. Spacialy belts and pulleys.
Jun 22, 2008 | Philips Magnavox DVD/VCR Dual Player
Tape stuck in an Emerson Model EWV401 VCR
take it to someone who has experience in removing stuck VCR tapes or you will be paying a lot more for a new VCR. They won't charge you much....IF they even charge you.
Apr 04, 2008 | Televison & Video
Philips DVP 3150V
saida horizontal com deficiencia faz com que a fonte aciona circuito de proteção.
Feb 09, 2008 | Philips CCB092AT 9 in. TV/VCR Combo
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
