Question about KitchenAid KESC307 Electric Kitchen Range
I have a Kitchenaid Superba electric range with a glass stove top. One of the top burners does not get hot enough, while another only turns on to maximum heat regardless of the position of the dial
  • Anonymous Mar 18, 2014
    one burner will not shut off and light stays on
  • Anonymous Mar 30, 2014
    When we turn it on there is no heat.
  • 116 Answers
It would be good if you said (describe) which burners are not working. But its very likely that something has gone bad with the switch (intinite switch). Best to change the switches.
Posted on Sep 21, 2008
  • 449 Answers
try to check the tube may be clog
or there something block on the tube
or check the adjustment control!!
  • Chris Kartson
    Chris Kartson Jul 22, 2012
    That would be on gas she has electric
My scholtse glass top won't work with my utencils
THe glass top is just that, glass! If the elements beneath it are not producing enough heat your utensils will not cook. Pull off the glass top by removing fasteners (either in the front of the stove or under the back panel of the stove). Then, turn on each electric burner to see if it turns RED hot. If not, wait till everything COOLS and reseat each heating elememt and retest those that failed. If that doesn't solve the problem, you can buy heating elements at Home Depot or other stores...
Nov 12, 2012 | Kitchen Ranges
Problem with Kitchenaid Electric Range Stove Top Burner
there may be a loose connection in either the pipe or on the burner rings on the surface. Some stoves have a safety cutoff if gas supply is interrupted to avoid prolonged gas supply.
May 12, 2012 | KitchenAid KERA807P Electric Kitchen Range
I have a kenmore ceramic top electric stove and one of the burners quit getting hot. what could be the problem
It is a kenmore glass top stove about18 years old. One of the burners stop working just wondering if I can fix it myself?
Aug 06, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
I have a Kitchenaid electric range Architect Series II. Seems every time I use the large burner on the right side there is some sort of residue left that is very hard to get off. I have already made a...
What are you using to clean the stove? Only cleaners made for ceran type tops should be used according to directions. Do not use enamel coated pans or glass pans on your cooktop.If you have a boil over, turn off the burner and change to a different burner immediately. Clean up the spill completely before cooking on that burner again. Use a flat edge razor to clean tough residue. Your cooktop will look new for years to come, even with heavy use.
As far as the scratch, don't use abrasive cleaners on the top and only use pots and pans with flat bottoms. If you do use cast iron pans, never scoot them around on the top.
Nov 30, 2009 | KitchenAid KESC307 Electric Kitchen Range
My oven will not turn on. I notice the clock is not on but the burners do work. I have a kitchenaid superba oven with a glass cooktop.
You can download an electrical schematic from the kitchenaid web site. In the back of the stove, you will be able to trace the wires to find a loose connection. Be careful - make sure you disconnect the power before you start. You don't want to accidentally touch 220V.
Oct 03, 2009 | KitchenAid Ovens
KitchenAid Superba
Enter your model number and it will give a listing of the manuals available to you.
Feb 11, 2008 | KitchenAid KESC307 Electric Kitchen Range
Stove top ignition
I have a Kitchenaid Model KGCT365x and need to replace the igniter switch on the front right burner. Can this be done through the knock hole or does the whol glass top have to be removed? If it has to be removed, what is the best procedure to do this?
Jan 01, 2008 | Bosch HES 252/ HES 256 Electric Kitchen...
KitchenAid KESC307 Electric Kitchen Range Logo
454 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
