Question about Toshiba 44NHM84 44" TV
How to replace Power Supply in Toshiba 44NHM84 44" TV
My Toshiba 44NHM84 44" TV turns off after about 30-90 minutes and I have to wait about 30 mins for it to recover. But the same issue pops up agin. I have read on here that the power supply is the most usual culprit.
Is it easy to replace? is it just a PCB or are there other parts that need to looked at?
Thanks
Ken
  • kharford Sep 22, 2008
    Thanks Dan for your help with this issue.
    The only indicator light that changes is the power light that starts to blink and then goes to red.
    Is this any indication as to what might be the problem?
    Thanks again
    Ken
  • milldel79 Sep 23, 2008
    I googled for this exact same problem.  Found this post.  My shutdowns seem to be much more random, but have the same problem.   Once the damn thing shuts down, I can't get it back up and running.
    After a 30 minute wait I can get the tv back on for anywhere from 5 minutes to another 2 hours.  There seems to be no pattern or predictability.  Advise is greatly appreciated.
    Even had a tech here and so far all he thinks it might be is the lamp, which makes little sense since to me...
  • 4,234 Answers
Since this is a DLP type set, there is a lamp and ballast involved. When the set shuts down, are there any indicator lights on the front? If so, check the owner's manual for an explanation of their meaning. Typically, the lamp can cause this or the ballast. If either of those are the problem, usually the lights on the front panel will indicate it.
Keep us posted.
Dan
Posted on Sep 22, 2008
  • ABRsvcs Sep 23, 2008
    I'll need to check more on this. Stay tuned.
    Dan
Hi I have a Toshiba Regza 55" flat screen TV Model 55ZV65OU. Yesterday we had a power outage a quick flicker Off the power then on came the power but my TV won't turn back on.Note I use a power bar w
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Feb 11, 2015 | Toshiba REGZA 47HL167 TV
Sharp tv troubleshooting
There are two main causes for symptoms like this. Usually people replace the TV but it's actually much cheaper to fix.
1. The Power Supply. Just like computes, screens and tvs have a small power supply inside, usually directly connected to the power cable. Sharp can get you a replacement power supply under $100 and you can put it in yourself with a screwdriver or have someone do it easily.
2. Ask an electrician to check out the main capacitors (or if you know how to use a voltage tester, just be sure to unplug the screen and hit the power button a few times first to discharge) If you find a faulty capacitor, they're usually under $10 to replace.
Most likely one of these pieces is getting overheated and shutting off, causing power to fail to the rest of the TV.
Feb 07, 2014 | Televison & Video
Turn tv on watch it for 20 mins. screen shuts off but green power light is still on. turn it off manualy wait a few mins. turn back on watch for anouther 20 mins or so then screen shuts off again
The reasion your set is shutting off is because the power supply is dieding, and you need to replace the electrolytic caps on the power supply, or purchase a new one, go to www.partstore.com sand check to see if they have your power supply.
Aug 17, 2011 | LG 50PX5D 50 in. Plasma HDTV
Went to turn the TV on and it will not come on. No sound or picture. There as been no movement or anything done to the TV.
More likely to have power supply failure, the power supply is always running to supply the power to the processor waiting to get th turn on command form the remote control. Look for bad caps in the power supply and check the fuse, Need to verify if you do have the standby 5vdc, you must have this voltage before going any further.
Learn more here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Parts:
http://www.shopjimmy.com/catalogsearch/result/index/?q=Toshiba+32CV510U+&limit=100
Jun 14, 2010 | Toshiba 32CV510U LCD TV
Toshiba 52 inch TV turns on then blacks out.
Unplug the power to the TV and HD cable box, wait 5 min. Plug TV and HD cable box back in.Everything is working like new. Go figure.
Sep 29, 2009 | Toshiba Televison & Video
TOSHIBA dlp projection, model 42hm66 won't stay on
Could be the power supply. You can check the power from supply with multi-tester or voltmeter. If have a service manual, then I suggest testing the ballast as well
Aug 07, 2009 | Toshiba 52HM95 52" HDTV Projection...
Tv stopped working
Hi. This tv may have an issue within its contents.This issue concerns the power supply board. to confirm this, unplug the tv from the surge protector, if any, and wait for 3 Min's. after this 3 min wait, plug this unit into a wall outlet and power up. if it dose not power up, you will defiantly have to replace the power supply board.
Please rate and god bless:)
Apr 02, 2009 | iLO IWT3206 TV
Tv wont turn on.
try cutting power off and wait 15 to 20 minutes. also try another outlet depending how much power u r pulling thru the outlet u had it in. Had same problem and customer service said unplug for 3 min....not long enuf...so try 15 to 20 min and plug back in.
Apr 10, 2008 | Toshiba MD20F51 20 in. TV/DVD Combo
Tv turns off after 15 minutes of use
For bobby11 and luis, it is the power supply. Part Number EAY34797001 in the 42" and EAY34796801 in the 32". This is a known problem, and somebody should start a Class Action against LG over this one. Part is available online and easy to swap out for anyone with the most basic knowledge.
Jan 16, 2008 | LG 42LC7D-UB Television
Toshiba 44NHM84 44" TV Logo
396 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
