Question about Panasonic KX T7436B Corded Phone
KX T7436B Hi, I have accidentially removed 2 of our outside lines from the CO buttons. We originally have 3 lines. I can now only see one of the lines ringing and not the other 2 that I deleted. Can I restore the original settings or do I have to hunt down our manual for our phone system. I know that we haven't been able to get the manuals previously!!!
  • 7 more comments
  • vanessarose Sep 21, 2008
    Unfortunately when I go and reprogram line 1, nothing is happening.
    As for line 3, it is registering as line 2. How do I reset line 1 and 3 to reprogram it for the correct lines.
    My exisiting CO lines should say CO 01, CO 02 and CO 03
    Thanks
  • vanessarose Sep 22, 2008
    Yes, we currently have 4 other phones that are working correctly. CO1 is displaying Not stored and CO3 is showing CO2. How do I undo CO3?
    problem, when I go to program CO3 the following happens
    Prog - CO-3 (nothing happens) ie. CO3 doesn't say anything
    I know you are offering suggestions but they are not helping me.
    Any more suggestions ???
    ok, here we go again,
    On the good working phones I was able to get the following information
    Our outside lines say
    CO-1, CO-2 and CO-3 that's it
    Any suggestions ???
    Firstly, when I press PROG and the button for CO1 and dial 0 - I get 3 beeps (error tone) and the message program remains on the screen. I don't even get the CO1 or CO3 displayed when I hit the relevant buttons.
    help !!!
    hi there,
    The problem lies in my phone line. I have been able to relocate my phone and use it on a working workstation, however, using someone else's phone on my phone line is the same result as before.
    At least I know that my phone is a worker but my system is not !!!
    I really don't know what phone system we have. The main unit is located in another building where we don't have access to it.
    help is still needed !!!
    No luck again !!!
    Can you tell me, if I press Prog, 99, CO (the outside line), 2, - what am I programming my CO to register my outstide lines.
    Originally, I used the Storing numbers for one-touch dialling and accidentially removed CO1 and CO3 - hence the problems that I have now.
    You are soo wonderful....
    You have fixed the problem.
    I now have an operational phone that has 3 lines !!!
    Thank you soo much !!!
    Cheers
    Vanessa
  • vanessarose Sep 23, 2008
    Hi there, it's me again !!!
    Can you tell me how I can set the phone up to redirect incoming calls when I am already on the line. I get the call waiting tones on my line when I am talking to clients.
    Also our receptionist use to get our main line CO-01 come into her first, now it comes into our office.
    Help me once again please !!!
  • Panasonic Master
  • 2,460 Answers
Lucky for you. You don't need a manual for this one.
Go to any phone that works and press PROG and the buttons for the missing lines. Write down what they are...or you can skip that step eitirely.
Press PROG the button you want, dial 0 and the CO number (ie 001,002,etc) then ENTER. Press the next button and dial 0+002,003 etc) and ENTER.
Finish by pressing PROG
Carl
Posted on Sep 21, 2008
  • 6 more comments
  • Carl Navarro
    Carl Navarro Sep 21, 2008
    The buttons reassign according to the last function pressed. If you assign button 1 as CO2 and button 3 as CO2, button one will go to "Not Stored".
    Do you have any other phones where line 1 works?
  • Carl Navarro
    Carl Navarro Sep 22, 2008
    You don't....just store 003 under the button. PROG CO3 0-003 ENTER
  • Carl Navarro
    O.K. Please start with one of the phones that works. Press PROG and step through the buttons and write down what they say. For example, my buttons say "Single Line-001" Single Line-002" "Single Line-003" and "Single Line-004" from bottom to top.
    They were programmed with PROG button 0-001 store button 0-002 Store button 0-003 store and button 0-004 store from bottom to top.
    It doesn't matter if they say nothing when you first push it, but when you press 0 it will say "Single Line".
  • Carl Navarro
    How very odd. You have a TDA and I have a TDA and my buttons are programmed and I can change them. When you press PROG the button for CO1 and dial 0 what does your display say.
    In fact, if you press PROG a button and press SP PHONE, the display will start showing other options. When you first dial 0 it will say Single Line. The buttons are there, the CO lines are number 1 2 and 3 and, in fact, you don't have to dial 00 just 1, 2 and 3. I can't believe you can't do your own programming because there is no locking out of personal programming on a phone.
    You said before you got 3 beeps (error tone) when you went to store the number. What was the display saying at the time?
  • Carl Navarro
    Take the phone and move it to another location. Try your oringinal phone somewhere else and see if you can read the buttons. Then put another phone in your extension.and try to program.
    In my wildest dreams, I can't duplicate your trouble. Even dial restrisction by locking out the station lets me reprogram the buttons.
    What system do you have? Is it a 30, 50, 100 or 200? Do you have any idea what softwrae revision?
  • Carl Navarro
    Try Program 00. The display will tell you what extension you are and give you some hardware numbers. In mine, ext 103 is hardware 10501 for first cabinet, slot 5 port 1. Maybe we can figure out where your extension is.
    Do you have access to ext 101?
  • Carl Navarro
    OMG PROG 99 button 0 01 STORE do the same for 2 and 3.
    2 is a conversion of a lit button to speed dial. That number would include 2 9 Plus the outside number or 2 xxx for an inside feature.
    Your system is probably a TD not a TDA. What was I thinking?
    Carl
  • Carl Navarro
    Carl Navarro Sep 24, 2008
    I can do one, but not th eother. Remember that other building where the phone system is? Ringing is set (normally) from the phone at extension 101. System program 603 and 604 control the delayed ringing. It's set for 1,3 or 6 rings delay none or immediate.
    Call waiting is a numeric feature for both intercom and outside calls. IIRC on a TD system you either have it or you don't. (Other systems have 2 codes to let you set one or both CW modes).
    The codes are:
    INTERCOM 7311 CALL WAITING
    INTERCOM 7310 CW CANCEL
    There are two other modes (2 & 3) that allow Off Hook Call Announce that I can never remember anybody using and only work on digital phones or specific PT's with special wiring.
How can i pick up the call from my office phone when reception phone rings
Hello,Looks like you'll need to re-program your PBX unit. I would suggest looking up: 1.5.3.3 Outside (CO) Line Access 2.2.4 Operator/Manager Featuresin the Programming manual found here:
http://www.tongxun.com.cn/data/download/Feature_Guide.pdf
Hope this helps
Nov 27, 2012 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    How do i cahgne the ring tone on the panasonic kx-t7565 phone. I have changed it but it only appears to have chagned if ring ring the number internally. we need the ring tone to change from external...
    The ringtone for the CO or outside line buttons can be programmed by pressing program then press the
    CO button twice, enter the ringtone you want by dialing 01 to 08, press enter or store then program to end. This will set the ringtone for that line assuming it is programmed to ring at that phone. Transferred calls will use the ringtone of the intercom button which can be set by the same procedure. Use the same procedure if calls ring to a Group Directory Number(GDN) on the phone. The 7600 series of digital phones have ringtone settings of 01 through 30.
    Dec 15, 2010 | Panasonic KX-T7565 Corded Telephone
    Hi i have a panasonic KX-TES824 installed with 2 co lines and 4 extensions. I want the ringtones to be different for internal telephones (ie call between the extensions) and the CO Lines (when call comes...
    A Panasonic Analog PTS ring sound is not adjustable, however, the cadence is. An outside call rings with a single ring, an internal call is either voice announce or a double ring. The digital phones from Panasonic have either 8 or 30 different tones, but that's a different system.
    Carl
    Nov 21, 2010 | Panasonic KX-T7730 Corded Phone
    I need to have our Panasonic KXT7730 to ring at reception but instead one of our lines rings on another phone in another room. How can I change it to ring at reception.
    Hello, I presume that you are using this phone on a 308 or 824 system. You will have to check which line is ringing at the other phone. Is it line 1,2 or 3 ? Say for example it is line 2 you need to do the following: From the main phone / switchboard usually ext 101 press PROGRAM * # and your system password ( default is 1234 ). Now enter 408 and press SP-PHONE. The system now asks you to enter the line and in this example we use line 2 - so enter 2. The display now looks like this CO 2:#01: with ENABLE or DISABLE flickering. (CO 2 is the line number. #01 means extension 101, #02 means ext 102 and soforth.) To enable the line to ring at ext 101 choose ENABLE by pressing the AUTO ANS / MUTE button. Now press AUTO DIAL / STORE to save your changes. Now use the right arrow key ( located at the right bottom corner of the phone ) to move to the extension that you don't want to ring - say for example 106. Your diplay should now look like this CO 2:#06 with ENABLE flickering. Now use the AUTO ANS / MUTE button to set it to DISABLE and press AUTO DIAL / STORE to save your changes. Press PROGRAM to exit program mode.
    PLEASE VOTE / RATE MY ANSWER IF THIS WA HELPFUL - THANK YOU.
    Feb 08, 2010 | Panasonic KX-T7730 Corded Phone
    Stop ringing at main phones when outside calls come in.
    Here is a link to program line ringing.
    It sounds like your extension is forwarded (confirmed by the one beep you hear on an incoming call.
    From any display phone, press Feature 11
    then enter your extension number 2 times. So if you are extension 20, do this:
    Feature11-20-20
    see if that does it.
    May 28, 2009 | Lucent PARTNER18 Corded Phone
    I bught a kx-ta824, I just have one CO line and i want to put 4 extensions , but i couldn't. I can just recive 1 call and then the line sounds busy.
    With one CO line you can only make or receive one external call at a time. You can have extensions connected on intercom calls, but once your CO line is in use, anyone calling in will get a busy signal, as will anyone in the office trying to make an outside call. You'll need additional CO lines if you want to have several outside calls going on at once.
    Apr 10, 2009 | Panasonic KX-TA824PK Phone
    RINGER VOLUME
    Go back to that original 7433. Beg, borrow, or steal one of those phones from someone else and plug it back in. Have someone call you on the intercom and make sure the AUTO ANS button is not lit. Does it ring? Now plug in your 7453 and do the same thing. Does it ring?
    I think I only had one or two of those models and the ringer is a two step switch (3 positions) OFF LO HI on the side of the phone. Make sure it's set to something besides OFF.
    If the phone rings on intercom but not on the outside lines, that's a different problem.
    Carl
    Sep 05, 2008 | Panasonic KX-T7453 Corded Phone
    We have the Panasonic KX-T7433 model of phones at our office. Yesterday I set about to re-programme some of the extensions and now, as a result I have lost the outside line for the phones that I have been...
    I just found this, which had the process for programming a CO button as a one-touch. And it worked. It's a bit easier to follow than the panasonic manual so hopefully it will have an answer.
    http://www.command-a.com.au/Portals/0/Panasonic%20816%201232%20Quick%20Referance%20Guide.pdf
    Jul 23, 2008 | Panasonic KX-T7433B Corded Phone
    Panasonic Kx-T123230 extension to ring
    hope this help...
    with a handset on hook...press PROGRAM and press 3 (number 3 button) this should give you a choice of which extention you want the phone to ring.. ie 1or 2 or three... Then finally press STORE
    Feb 06, 2008 | Panasonic KX-T7730 Corded Phone
    Panasonic KX T7436B Corded Phone Logo
    Top Panasonic Lands Phones Experts
    guyvstewart
    john milligan
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
