Question about Panasonic Microwave Ovens
My panasonic microwae stops after 28sec and would'nt work
  • Panasonic Master
  • 8,934 Answers
Is it maybe 22 seconds?
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Posted on Sep 25, 2008
How do I replace the light in my Panasonic nn797s?
Remove the case and replace the lamp located between the magnetron tube and the control panel. If I remember correctly there is one phillip screw holding the base to the oven.
Oct 12, 2014 | Panasonic Luxury Full-Size 2.2 Cu. Ft....
Thermoststat defective need new one
they only make 2 types...normally open or closed 155 degrees + or -
use a VOM reed the old one if it shows open you need a normally closed thermostat..$5 or less
Apr 11, 2014 | Thermador 30 inch Masterpiece Series...
Model# FMV156EMA over the stove microwaive. We set the timer and when you push start the light on the inside comes on, but the microwaive will not start, the timer also runs but it does not actually come...
You have a failed bottom door switch, or that switch's mount is broken or misaligned.
See the service manuals here and here and this text file.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 22, 2011 | Frigidaire Microwave Ovens
Panasonic microwae h964bf comes on for 3to 4 secs shuts down and you can smell electrical
your magnetron is bad and it burned the diodes on the inverter board. not worth repairing it
Feb 05, 2010 | Microwave Ovens
I have a GE profile spacemaker microwae oven. The
Yes. You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If yours is a counter top model, you have to remove the outer cover, and the mini-manual will probably be in an envelope inside the wrapper.
Jan 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I am trying to locate instructions for a hinari lifestyle microwa
If you put "mx676tc manual" into google, you will find several companies who will supply a manual
Mar 13, 2009 | Microwave Ovens
Runs for 3 seconds
check inverter transter or Magnetron short to be repalce
G.K.MAHENDRAN.
Date: 09.05.2008
May 07, 2008 | Panasonic NN-S540 Microwave Oven
Microwave is nt heating
The problem of shutting down after 29 seconds is due to a defect in either the magnetron or the inverter. It will need service, preferably by a professional due to the lethal voltages inside. You should be able to find a servicer at the Indian site: http://nationalpanasonicindia.com
May 03, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Broken Microwaive Door
I'm assuming your correct model number is KCMS145JSS? You have a broken "release lever", part number AP3033332. It's reference number 7 on the exploded view diagram found here: http://www.appliancepartspros.com/sect/4/g/4/4g4rya32jj.gif You can order it by part number from Appliance Parts Pros here: http://tinyurl.com/gv383 If needed, you can download the owner's manual and installation guide here: http://www.kitchenaid.com/custserv/literature_search_results.jsp?searchTerm=kcms145jss If you need further help, please follow up. I appreciate your rating of this answer.
Nov 17, 2006 | KitchenAid KCMS145J Microwave Oven
Microwave Ovens Logo
147 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
