Akai PT4298HD Rear Projection Television
Problem for Akai PT4298HD Rear Projection Television
Akai PT4298HD projection tv
By duchessofbel on Sep 21, 2008
The perfect focus feature hasnt worked since the tv repairman fixed the set. When activated (perfect focus feature on remote or on the set), the screen shows "no sensor data". I have tryed the manual convergence wich works for the red but not for the blue, is there any way the remote can be reprogrammed to reactivate the perfect focus feature. Or maybe there"s a code. I would appreciate some help with this problem and thank you very much in advance.
Sincerely"
Caroll Bourgeois
Same Problem
Oct 20, 2008
-   perfect focus no pass 40 % -   el pello
Oct 13, 2008
-   the same problem. suddenly got a blue shadow for the picture.
I have tried, several times, the perfect focus with no result.
the perfect focus on the blue (44) vertically but not horizontally.
my email: bichaif@hotmail.com-   bichaif
Solution #1
posted on Oct 20, 2008
Somewhat Helpful)
tvrepairguy
Rank: Wiz
Rating: 82%, 204 votes
convergence must be adj then saved then magic focus
if cannot be adj chips need to be replaced.
Was this helpful?
Yes
No
Popular Solutions for Akai PT4298HD Rear Projection
Questions and Unsolved Problems for Akai PT4298HD Rear Projection
Do you recommend Akai PT4298HD Rear Projection Television?
Answer
Answer
red block in center . On my 50 inch tv there is about 4inches on each side that is lighter then the... (More)
Answer
Picture is completely tinted orange and flicker to tinted in green. The tint covers the entire... (More)
Answer
How do you restore to factory settings on a PT4250AX/SmS? I would like to view in 1080i.
Answer
The screen that the image is projected on seems to have bowed in toward the projector. The image is... (More)
Answer
How do I reset the convergence values? My red and blue channels are way off from each other - looks... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Akai PT4298HD Rear Projection...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 801
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
