Question about Shop Vac Vacuums
I have a shop vac, and id like to use it to **** up water. do i need special parts or what exactly do i have to do to use it for that purpose?
  • 120 Answers
The machine should have a filter inside if it looks like a big foam sleeve than your ready to go, if it takes a paper bag as well or a paper sleeve over the big foam sleeve you want to remove them ( not the foam ) because the paper would fall apart and make a big mess in the machine.
Posted on Sep 22, 2008
So I just got my shop vac second hand and it has no manual and no basic instructions were given either. Does it actually need a bag when using it? I feel like something may be broken or missing....
Shop cacs are multiple purpose dry/wet intake so typically you don't need a bag. You just open the tank and empty it like a big trash can. They will have a large filter In the tank that needs to be cleaned/replaced.
Oct 16, 2015 | Shop Vac Vacuums
6.0 hp 12 Gallon Shop-Vac 'exploding'
Those type of vacuums are designed for light duty work around homes anyways. For commercial industrial work as you are doing you need a sump pump. We used to drop one in a 5 gallon (20 liter) pail, drill holes in the pail and suspend from a rope. (you can put screen around the pail covering the holes if needed too). Use a stiff hose to expell the water. You can change to a flat hose like a pool waste water hose or fire hose after the water is out of the trench.
Nov 20, 2013 | Shop Vac Vacuums
Shop-Vac 6.0 hp Peak 12 Gallon 'Exploding' after 10 seconds of use. Happened twice on two different brand new Shop-Vacs.
Since you said you were sucking water out of a "trench" I would bet there was some debris in the trench that impacted the impeller on the vacuum and caused the metal impeller to fragment, taking the plastic pieces with it. It is highly unusual for this to occur on vacuums if some type of debris, such as a small stone or piece of metal does not reach the high speed impeller/fan. I suggest using either a foam sleeve over the filter cage, or an old nylon stocking if you can get one, to screen out the debris that will cause this condition.
Need replacement roller
This is a link to Sears website. They have replacement parts for a ton of household items. If you look on your id plate on the vac post your exact model number here and I'll go look up the exact part, however, the one I found is in this link and it looks just like your vac. So This may already be the right one. and for 27 bucks it's not too bad. http://www.searspartsdirect.com/partsdirect/part-model/Eureka-Parts/All-Products-Parts/Model-4700A/1281/0645000/50031517/00001?blt=06&prst=&shdMod=4700A Hope this helps you
Jun 20, 2012 | Eureka Power Plus 4703D Bagless Upright...
Shop vac is not pumping out water just fills the canister
The question makes perfect sense assuming we are talking about the ShopVacPumpVac. These devices are, essentially, a combination shop vac and sump pump. For those answering the question, you can see literature on these vacuum/sumps here: https://www.shopvac.com/includes/streamPDF.asp?loc=pdf&id=Shop-Vac-Pump-It-Out .
When I have experienced the loss of drainage, I have found a couple obvious problems and solutions.
First, make sure that the garden/discharge hose is not kinked at any point along the line from the vacuum to the outside. If kinked, the line will not drain.
Second, the baffle can become blocked or clogged. Take the following steps to determine if your baffle is clogged and to clear the clog:
1. Turn off and unplug the vacuum.
2. Unclip the two lid clips.
3. Lift the lid of the vacuum. When properly set up, the baffle hangs below the filter housing on an opaque hose about 1 foot in length.
4. Grasp that hose and pull firmly downward. Once removed, I take that hose and the attached baffle to an outside garden hose.
5. Pull the baffle off the opaque hose.
6. Spray water from your garden hose through the opaque hose to make sure it is clear.
7. Spray the baffle clear.
8. Lightly tap the port of the baffle, where the opaque hose has been inserted. Most of my clogs have been the result of hair balls (or worse) at this point. Just tap any blockage out and rinse.
Third, reattach the baffle to the opaque hose. Reattach the opaque hose and baffle to the motor under the filter housing. Set the vacuum top on the canister. Click the locking clamps closed.
If this doesn't result in clearing the clog and allowing it to drain, then you are in the exact spot I am right now. If I figure out this new problem, I will update further. But I have cleared this kind of clog maybe five times in the six months I've been using this new Shop Vac Sump Vac
Sep 08, 2011 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
I did not get a manual with my vac. I am trying to soak up water from a water tank leak and water seems to go right trough the vac and water is coming out the blower hole. the tub is not full.
There is a special sock that you need to buy for it. You can run the paper filter if your in a pinch but after that one time, that's it, that filter is ruined.
The paper filter is for dry vacuuming, the foam filter is for wet vacuuming, You have to have one or the other in place.
There are two ways to snap the cover onto the basket, only one is the right way.
Look to see that the baffle is facing the hose inlet hole.
Apr 22, 2010 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Bought house. Inherited shop/vac. A bit old, but
If you are going to use the wet vac to remove water, be sure to remove the bag inside the canister first. Also, some wet vacs have an internal float that has to be installed, but that may not be the case with yours.
May 16, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Need new switch for Shopvac QSP Pro 10 gallon unit
I just went through the same problem with a Shop Vac. The switch is easy to replace but not easy to find. After removing the switch, I found a match made by Sigma Switches. They directed me to contact a local RV dealer and look in either their Coast Supply or Stag/Parkway Supply catalogs for the appropriate switch (an H2-28 in my case for a QPL45 Shop Vac). After ordering the switch and $5 later, it snaps in like the original with no problems. Certainly beats $70 for a whole new motor assembly.
Dec 28, 2008 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Shop Vac 12 wet dry canister
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19255&thid=245090
Posted by Fa Fa on Nov 05, 2007
I'm not certain I have all the parts to my Shop Vac. I have no instructions so I need help describing how it works and a picture of the main parts.
Thanks for any help. Julia Harris
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I am supplying you with the contact for the Shop Vac Factory Service for owner’s manuals listed below: for the website and the customer service line, but make sure you include the Shop Vac Model # and the Serial # as well. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://shopvac.com/contact.asp Customer Service 570-326-0502 Phone #
Shop-Vac Corporation Customer Service 570-326-7185 Fax #
2323 Reach Road
P.O. Box 3307
Williamsport, PA 17701
Hours are: Monday thru Friday 8:00 am to 5:00 pm (EST)
Nov 05, 2007 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Shop-vac i lost book
open the top of the vacuum. remove ONLY the filter element. There should be a ball about a two inch diameter inside the cage. It's purpose is to shut off the vacuum flow when water reaches a high in the canister.
Aug 29, 2007 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Vacuums Logo
149 people viewed this question
Top Shop Vac Vacuums Experts
Mike
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
