Question about Panasonic KX-FL511 Plain Paper Laser Fax
Not printing faxes or making copies
Hi
I suspect that I'm going to have to dump this machine. I just want a recommendation as to what I can buy as a good, reliable plain paper lasex fax/copier.
Carlos
It print out paper no information solution
Posted on Sep 22, 2008
    Genius:
  • 2,120 Answers
Any Panasonic Laser Fax
Posted on Sep 21, 2008
Brother 1460 Fax Machine. Will receive faxes and 'print' independant douments, but copies from both are COMPLETELY blank. I have auto-cleaned the heads several times and the cartridge has plenty...
Hello, Davetwydell -
Since you posted your question on Fixya.com, am I safe to assume you do not have the user manual for your Brother Fax-1460? If you do not have it, you can find it to download (free) here: http://support.brother.com/g/b/manuallist.aspx?c=eu_ot&lang=en&prod=fax1460_eu&flang=English&type3=121&type2=5 .
Instructions on how to make a copy or copies start on page 64 of the manual. The first step listed is to make sure you have the machine set to COPY mode.
If, after following the directions in the manual, copies still do not print, I recommend you contact the Brother Solutions Center for help: https://secure6.brother.co.jp/g/b/contactform.aspx?c=eu_ot&lang=en&cid=45&pcatid=4 .
Best wishes.
Dec 17, 2017 | Brother Inkjet Fax Machine Fax1460 Plain...
Fax will not print: I connected the fax machine and plugged it in. It sends faxes OK. When a fax is sent to it, nothing comes out. The sending fax doesn't receive an error message, seems like all went...
Does the machine print anything? such as a directory or print when making a copy? I rather suspect it does not. When an incoming fax is recvd does the paper get pulled in and come out blank? If so your problem is with printing (or lack of it). Perform head cleaning. Also make sure the black cartridge still does not have its deal stuck on it. Post again if you still have problem.
May 05, 2011 | Brother Multi-Function Center MFC-3360c...
Why our fax sending and receiving solid black
Its a problem with scaner unit. Reports are being printed out, and do not pass trough scaner, because of thath report is Ok.
If the fax is still under warranty, go to warranty provider service.
Next time dont buy "kids toy" for fax machine. Try laser Canon Fax L140.
May 20, 2010 | Canon FAX JX200 Fax / copier Plain Paper...
Black copies being received
Your image scanner is bad. Try making a copy....if it comes out black but your incoming faxes are fine then your image scanner is bad. You can also print a report from the machine and it should come out fine.
The image scanner is the part that scans your originals before faxing them out or making a copy. There is a light bar that lights up when scanning. Either that light bar(l.e.d. array) has gone bad or the scanner itself is bad. If this is the case it is probably going to cost more to fix than the machine is worth. You could buy a new machine for what it would cost to fix.
Good Luck and Thank You for using Fixya.
Apr 22, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Sharp Fax Machine UX-485 recipiant receives black page
If you receive clear copies. Make a test copy. If it come out all black. Yes replace your fax . you have a bad scanner . cheaper to buy a new fax.
May 21, 2009 | Sharp UX 510 Plain Paper Thermal transfer...
Check page counter on Canon MF6590
if the control panel doesnt have the "Check counter" button then you need to print the System dump list.
Access to service mode, then go to Report, then choose report output, then choose system dump, then press OK.
All the above info is classified since this machines are not suppoused to be kept track of prints like that for the user. Reason why i cannot go further.
when the page is printed (the first one) tells you how many copies you have Totally printed... under PRINT-TTL.
good luck!
Jan 29, 2009 | Canon ImageClass MF5770 Laser Copier...
Fax is received is very dark and almost unreadable
You can try using the menu to lighten the fax, but if all received faxes are dark, you may be experiencing a weak scan light. try making a copy instead of fax (which essentially is a fax printed to yourself) if also dark, its certainly your scanning imager that's failing. If that's the case I would recommend replacing the entire machine. Parts are expensive, and its a difficult to service part yourself. Also you may find that toner costs alone may pay for the replacement machine over this unit.
-Good Luck!
-FW
Jan 05, 2009 | Sharp Office Equipment & Supplies
Recieving fax no printout, all other printing processes ok
When you say all other printing processes are ok, I am assuming you can make copies and print from the computer. If so...then are the blank faxes coming from several different fax machines or are they coming from one particular fax machine. If one particular fax machine, then the problem is probably on their end. I need to go backwards a second....when you receive a fax does the machine spit out a blank page or no paper is fed at all..it just receives the fax? Is the machine programmed to just receive faxes to memory to be printed out later? It doesn't make sense for it to print or copy but not to print a fax. If problem persist try a different fax modem.
May 08, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Fax won't print
check with original cartridges or its carriage cable may be suspected, check with the expert technician.
Apr 12, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Panasonic KX-FL511 Plain Paper Laser Fax Logo
78 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
