Question about Linksys Wireless-G WRT54G Router
Having problems with linksys connection
I have a laptop that I set up to connect to my router and for some reason I can not get a connection even though computer is up and running with good connection. I also want to unlock my wireless.
  • ojochal Sep 21, 2008
    My wifi disconnect for an unknown reason. I did the troubleshooting procedure several times, but it still does not work. No connection.
  • 97 Answers
Please check if the router needed IP address?
- if yes? ( goto Network Settings and add the IP address.
- if not? ( obtained you Network Settings do not input IP address.
Double check also if your Router is properly configured?
Posted on Sep 22, 2008
I have a wireless network of computers, one wired and 2 wireless. in the correct setup, my other acer laptop doesn have internet, but s connected to the router, and this laptop im using CAN connect...
All the computers should have the same NETWORK NAME or SSID.
Recheck the settings and make an adhoc connection for each of the computers to your router.
You can also get a USB wireless adapter to enable ht NO internet laptop and connect them.
Just keep playing with the NETWORK SETTINGS.
Make sure all are connected to the SAME SSID.
Hope it helped.
God Bless You!
Feb 05, 2011 | Linksys WRT120N Router
My WRT54G linksys was connected 3 days ago to the laptop and the ps3. two days ago, i couldnt connect to the internet on the ps3, but could on the laptop. Yesterday, i couldn't connect on either one. I've...
First steps (forgive me if you are already doing this). Hook up the laptop with cat5 network cable to port on router to verify you have internet connectvity. Verify router settings that DHCP is on or off. It should be on unless u are using static IP's on network. Go back wireless and see if you can connect. IF yo do, open a DOS prompt and use ping command (c:>ping 192.168.x.x ) where x.x are the ip setting of router. In most cases the router IP will be set to 192.168.1.1 Check the most basic settings. Sometimes it is a simple thing that is throwing everything off. Also consider if your laptop is at the very edge of your signal area. Try moving laptop right next to router.
Hope this helps.
Jun 09, 2009 | Linksys Wireless-G WRT54G Router
When I try to connect my router to my laptop, the 321 error screen appears after about a minute. It says my ethernet cable is not plugged in properly, but it definitely is. Even the connection lights on...
This is a well documented problem with linksys routers. Go to google and type in "error 321 linksys". You will have to manually configure the router as stated on the linksys forum posts.
Jun 05, 2009 | Linksys WRT54G2 Wireless Router
My linksys router won't allo me to connect to the internet.
Well to be honest. The reason you keep having the problem is because your router resets itself every few hours. If your routers firmware was already updated by LInskys support and the same thing happens then you will indeed need a new router. Newer models and even the one that you have are all reliable the only problem in your case is most likely wear and tear. You have had it for a few years now hence most likely its degraded to a point that it resets itself which causes your problems so yes i would suggest you get a new one. YOu can get the latest WRT54G V8
Jan 08, 2009 | Linksys Wireless-G WRT54G Router
Wireless Connection limited range and intermittent
1. Access the router's setup page then go to wireless tab and change the current wireless channel to a different one.
2. You may also upgrade the firmware of your router.
Nov 08, 2008 | Linksys WRT300N Wireless Router
Linksys wireless g router will not connect to the internet
hello jillyg70
my name is tazman
have you tryed calling linksys they can help you . but you might want to try going to 192.168.1.1 first this will get you in to your router so you can set the settings on it. it might ask you for a password its admin try this before you contact linksys if you have trouble setting it up we have a premium chat i can help you
hope this works
Jul 06, 2008 | Linksys Wireless-G Broadband Router
Router
Can the laptop see the router at all? When you try to connect do you see the router's SSID? Does it connect?
Have you altered any of the router's settings or is it set up like factory default? Did you enable wireless security?
Assuming the router is set up like factory default, try this. On the laptop Start->Run then type "command" (with no quotes) and click on OK. A black window will pop up. Type the following:
ping 192.168.1.1
If you can provide some of this info maybe we can help.
Dec 16, 2007 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-G WRT54G Router Logo
89 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
