Question about Refrigerators
The power works and the interior lights work but it wont get cold. It's a DEC fridge and it's about 2 years old
  • 750 Answers
Hi Boatgc,
You say, the power works and the interior lights work but it wont get cold. It's a DEC fridge and it's about 2 years old.
Is the freezer also not cold?
If the fridge is not cold and the freexer is!!!
There are a couple things to sheck.
Let me know!
Huuum
Posted on Sep 21, 2008
Samsung RF265AARS 6 years old been sitting unplugged 5 years wont start
Remote chance fridge is on defrost cycle but more likely the compressor has seized.
Have it check by a qualified tech.
It's usually cheaper to buy another fridge than to have the compressor replaced and new refrigerant installed.
Nov 02, 2017 | Samsung Refrigerators
Hi I have a domestic rm3862 refrigerator and it will not cool on gas or elect we replace the elect board and still don't work it get hot not cold
Evaporation fridges are normally reliable and have the advantage of being silent. There is no compressor but there is a heating element that should cause the gas to circulate. Under normal circumstances the fridge thermostat should switch off the heating element when the interior is cold enough and the subsequent heating cycles will be so short the heat will not disrupt the fridge operation.
If the fridge is not cooling the thermostat will not switch off the heater and eventually it will begin to warm the interior.
It will not cool if there is insufficient refrigerant.
It will not cool if there is no refrigerant gas.
In this case it will be because a leak has allowed it to escape.
It will not cool if the refrigerant has settled away from the heating element. This happens sometimes if the fridge has been unused for a time or transported in a non-upright way.
It sounds odd but years ago we had a large American Electrolux evaporation type fridge that was unused for a while and would not work. We were told to take it outside and to spend an hour tipping it over and over. We did this and when we plugged it in it began to work like a brand new fridge even though at that time it was nearly 30 years old...
It was still working when we gave it away five years later.
Oct 24, 2016 | Refrigerators
Fridge/Freezer
Probably be cheaper to get new one, it has probably had the compressor fail or a leak in the cooling system.
Sep 16, 2017 | Smeg FR148A Refrigerator
Whirlpool model HAXNQ : lights out on fridge side only
Hummm... I would suspect your DOOR SWITCH on the fridge side... $11.321 shipped... eBay!
Anthony
Whirlpool 1118894 Door Switch
Dec 02, 2017 | Whirlpool GS5SHAXN Side by Side...
My propane fridge will not get cold
You have described an Ammonia refrigerator. The chemicals in the system are Ammonia, water, and hydrogen. In a crazy system of events, heating the bottom of the unit will cause the chemicals to seperate and then reunite in a complete cycle.
If you have never smelled a strong ammonia smell, then yes, the upside down thing will many times work.
The chemicals can become seperated in the wrong areas of the interior components.
Perform the upside down thing for 24 to 48 hours. Return to normal. Pause it for minimum of 4 yours and try again.
If the burner is working correctly, then you should see some results.
Oct 30, 2009 | Refrigerators
No power
Fridge is 60% nit working.The freezer is -20%.Circuteboard was replaced and defrost controler.Referigator does not work.Service technition has tried three times to repair.Referigator is 14months old.
Aug 05, 2009 | LG LFC23760ST Side by Side Bottom Freezer...
SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
Mar 30, 2009 | Amana ATB1832AR Top Freezer Refrigerator
I have a Beko fridge freezer just over a year old. This is kept in an unheated garage and has just stopped working. The light is on so the power is OK. The manual does say that thew fridge should not be...
Switch off fridge unscew & lower stat & light housing, note positions of blue doulble wire & red/grey, the blue wire spade is permanent live for light, fit red/grey to this spade the motor should then run,I let it run for 5mins then replaced wires to there normal position,I think it is due to fridge not running enough when cold. it worked for me so try it. (at your own risk.) best of luck.
Dec 04, 2008 | Refrigerators
Kenmore coldspot
hi thanks for the question i would check the cold control what is happening is that the fridge gets cold enough but because of this bad control it wont send power to the rest of the fridge replace cold control thanks the appliance doc
Sep 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
165 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
