Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Top part of refrigerators and freezer not cooling right
Lost
  • 750 Answers
Jason44,
Hello I'll try to help but I need more info.
Why did you write LOST???????????
Ready lets try a few things?
You need to make sure the freezer is not filled to the top and covering the cold air vents and passages usually found in the rear or bottom rear of the freezer!
If they are blocked or covered with packages the unit will not be able to transfer cold air to and from the fridge!
They due share the air in most refrigerators!
Also in front of your fridge at the bottom should be a removable grille.
After this is removed it is advisable to gently run a refrigerator brush in there to ,GENTLY remove the dust and lint that may accumulate on the coils.
I've seen people that never cleaned the coils and this was the reason that their fridge was not cold.
In their case the coils were so covered with dust and lint you could not see the coils till I brushed some out.
The fan sucks air in and over the coils so they may be cooled off.
If this passage is blocked of the cools are coated with dust the get hot and can not do their job.
Next if the compressor can be heard and is on try to turn the fridge off , and then unplug the fridge or if you can not reach the plug ,shut the breaker off. Either one will due.
Now wait 5 minutes and then plug it back in and then turn it on.
With this action we are trying to reset the system .
Let me know how it goes!
Please don't forget to give a rating before you sign off.
Thank You. I'm waiting for the results!!!!!!
After you try these measures, perhaps you can tell me
what type fridge,model and age?
If not only a trained tech can make the electronic diagnoses.
Here is report that I found interesting
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Posted on Sep 21, 2008
Amana - Top freezer model ATB1915HR. Freezer is not cooling. The fan is running. Tried increasing and decreasing cooling settings. Emptied and cleaned out.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 31, 2011 | Amana ATB1830 Top Freezer Refrigerator
Items in freezer on top level have frost on them. It is appearing on top right side (as you face freezer). Long, "furry" frost has formed.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Nov 28, 2010 | Amana ARB1914C Bottom Freezer Refrigerator
We have a GE GTS 222C top freezer refrigerator, approx. 8 years old. The freezer works fine but the frig doesn't cool and is at the highest setting. We had to turn the electricity off for some wiring...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Nov 23, 2010 | GE Refrigerators
Water is leaking under the frezzer into the frig and it ices uo in the frig to right in the middel where the cool air comes from the frezzer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Oct 10, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Freezer is cold but frost building up in the front right portion, also frost on top/ceilngi of freezer and back now too.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 07, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
FRT16CRH Top Freezer Frigidaire Water leaking underneath refrigerator front bottom right hand side
heatman101
Sep 04, 2010 | Frigidaire Refrigerators
@15 yr old GE top freezer fridge. Top freezer
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Mar 30, 2010 | GE GTS22KBP Top Freezer Refrigerator
Hotpoint htr17bb Top Freezer Refrigerator Freezer working, but refrigerator not cooling
heatman101
May 06, 2009 | GE Hotpoint® HTR17BBSL Top Freezer...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
