Question about Maytag EPIC MFW9700S Front Load Washer
Maytag washer haqving problem with washer not washing on hot cycle
  • 750 Answers
Hi JMH5530,
What is happening when you wash on the hot cycle?
Waiting for your reply
Oh, How old is your washer.
And the model #
Posted on Sep 22, 2008
I have an MAV7600 Maytag washer the hot water fill valve drip after the cycle complates
if the washer keeps taking water and even when the washer is on the off position.
The problem could be a bad water valve.
Mar 15, 2012 | Maytag MAV7600 Top Load Washer
The cold cycle on my Maytag Neptune front load washer is not working. It works fine with hot water.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
Sep 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Maytag clothes washer won't fill with hot water
Then you most likely have a bad hot water valve. On Maytags the valve is one combo unit for both hot and cold. Maytag didn't change that much for a number of years, so you may be able to salvage one out of an old machine somewhere and fit it in -- that's what I did when my wife's Maytag did this.
Dec 30, 2009 | Washing Machines
After wash cycle still has water leaving bad smell on clothes
Most maytags don't heat water so even if you select hot wash it will only wash at the hot water temp available in your home, so you could end up with a cold wash
Nov 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer will not go into rinse cycle
Hi, Does the timer advance to rinse but the washer soes not fill? Make sure that you have both hot and cold water. While the washer is in wash cycle, check and see if the hot and cold water work.
This is just the first thing to check. If both hot and cold are working, please let me know so I can assist you further.
Jun 20, 2009 | Maytag MAV4755A Top Load Washer
Hot water will not work on my washer
call the maytag repair people. sounds like the water solinoid valve is bad.
Mar 18, 2009 | Maytag SAV2655A Top Load Washer
Maytag washing machine
If the hot water is not cycling then you have a bad solenoid (coil),strainer is clogged or no power to the coil. Check the harness to make sure that the connector is firmly secured to the coil
Sep 21, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag Front Load Intellisense 6.5kg
washer may not be detecting water temp but water flow ..if you never use hot water may try hooking cold water to a Y-connector and then hooking to both hot and cold inlet valves ..however it is also possible washer is detecting inlet temps in which case you're out of luck ..i suspect the latter
Sep 01, 2008 | Washing Machines
Maytag EPIC MFW9700S Front Load Washer Logo
27 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
