Question about Dell Dimension 4500 PC Desktop
Connection Problems I have a Dell 4500. Recently I began having connection problems. I run Windows XP by dial up with Earthlink as the browser. When I try to connect, my start page tells me I am 'Connected' and, I can even send and receive e-mails. But, the screen tells me that it Cannot Display the Webpage with the 'Diagnose Connection Problems' bar showing. When I do this, I am told that the cable between the computer and the modem is damaged or not connected and something about the ethernet cable. How can I be able to send and receive e-mails and not connect to Internet Explorer and/or have this problems with the modem/computer. I ran modem helper and it said that the modem was OK. I do not know the brand of modem. It was factory installed. Thanks.
  • Dell Master
  • 998 Answers
If you are able to send and recieve emails then your dial-up modem is working. For some reason your "Earthlink Browser" is looking for a high speed connection,(like DSL or Road Runner cable). Easiest step to take would be to re-install your Earthlink dial-up software program, but remove existing program under "Control Panel" (Add or Remove Programs).
Posted on Oct 15, 2008
Hello im troubleshooting a error on a dell dimension 2400, windows xp error when testing or querying the modem the error reads cannot connect or check to see if hardware is powered on or connected...
Wireless zero configuration is the feature of Windows XP that allows Windows to detect the available wireless networks and automatically connect to the most preferred wireless network.
It is enabled by the Wireless Zero Configuration service in Windows XP. It provides auto wireless network detection when you switch on the computer.
Follow the steps below to verify that the service is running:
1. Go to Start and right click My Computer. Select and click Manage.
2. Computer Management window will appear. Under Services and Applications, select Services.
3. Check for the service Wireless Zero Configuration. Make sure that it is started and that the startup type is set to automatic.
computer-management.jpg4. If it isn't, double-click the service. If the startup type is not set to automatic, click on the dropdown arrow and and change it to automatic. Click OK at last.
autostart-wireless-zero.jpgIf your wireless adapter driver does not support wireless auto onfiguration, you will notice the following:
- The network adapter does not appear as a wireless network adapter in Network Connections. It appears as a LAN adapter, similar to an Ethernet connection.
- The properties of the wireless connection do not have a Wireless Networks tab.
- You do not receive a Windows XP notification bar message indicating that wireless networks are available.
To get the most out of your Windows XP wireless experience, you should contact wireless adapter manufacturer to obtain the latest version of the drivers that support this XP feature.
If not, you must manually configure wireless network settings using the configuration software supplied with the wireless network adapter.
Jan 05, 2011 | Dell Dimension 4500 PC Desktop
Keep getting internet connection error#633
I Believe what is happening is that you have more than one connection trying to connect either that or is connected what I would suggest doing is checking your network connections. to do that you must do the following.
If using
1.XP: Go to start/run/type in ncpa.cpl and hit ok
vista: go to start/search bar/type ncpa.cpl
same with windows 7
2.If you are using a router wirelessly the connection will be a wireless connection however if you are connected with and ethernet cable it will say Local Area Connection.
3.Right click on the connection you are not using and hit disable.
4.If you have a Dial up connection that you don't use anymore you should delete it.
5.try the web browser "I hope this helped you out"
Sep 29, 2010 | Dell Computers & Internet
Missing Windows XP Product Key-Need to Reinstall/Repair XP
I'm assuming you have quite a lot of computer savvy??? You'll need to access that drive and get the original key off it. Try connecting the drive to another pc and see if you can get to the Windows folder. Once there, use Jellybean Keyfinder to navigate to the Windows folder in that drive and take note of the OS key. From there you can reformat and use the existing key.
Apr 30, 2009 | Dell Dimension 4500 PC Desktop
No dial tone on xp
U need to double confirm the phone line whether got dial tone or not. What u can do is to plug the phone line to a single line phone. If dial tone is available, u can able to make call.
Feb 13, 2009 | Dell Inspiron 530 Desktop Computer
Problems connecting to DGL-4500
This can be a firmware problem so upgrading the firmware of the router should fix this issue on it, so I advice you to upgrade to the latest firmware of your router, you can get it from Dlink web site...
Oct 19, 2008 | D-Link DGL-4500 Wireless Router
Dial up self connecting
thy running a trojan scanner
Oct 07, 2008 | Dell Dimension 4600 PC Desktop
Trying to set up a network printer with DELL TRUEMIBILE 2350...please help
using windows xp on all the computers, when you connect to the printer windows should automatically install drivers.
1. Goto My Computer, Click My Network Places (Explorer Bar).
2. Click View Workgroup Computers (Explorer Bar)
3. Find the computer that has the printer physically connected to it, open it
4. Find the printer and right click it!
5 Select Connect... and wait for the drivers to install.
this should install the print drivers and install the printer on your computer. the printer should now be available in print dialogs i.e. word etc etc and from the Control Panel > Printers window.
Nov 03, 2007 | Dell Wireless 2350 Router
Blue Screen error 0x00000024
You have first to determine if it's a hardware or software problem.
Hardware, verify that your devices are plug in correctly and fitted. It may be necessary to remove the video card and memory, clean the gold contacts and re-insert/re-seat back;
Software, try running in Safe Mode and/or Last Known Good Configuration. You may need ti uninstall any recent updates/software before the BSOD/conflict began.
Hope this be of some initial help/idea. Post back how things turned up so we can figure other possibilities or should you need additional information.
Good luck and kind regards.
Nov 01, 2007 | Dell Dimension 4500 PC Desktop
Dell Dimension 4500 PC Desktop Logo
98 people viewed this question
Alun Cox
