Question about Sony CDX-M610 CD Player
Cdx-m610 no power (why)?
Connected red and yellow wire for power and black for ground, but cd does not come on Why?. No power to unit at all Please help.
David
  • 1 more comment
  • Anonymous Nov 10, 2008
    I am experiecing the same issue
  • ShayShay27 Feb 17, 2009
    I'm having almost the same problem, the whole radio system has power to it, the face plate drops down and you can insert and eject cds, but there is no other kind of power, none of the lights come on, no sound, nothing.
  • Anonymous Mar 06, 2009
    I have the same problem. Need to know what it is so i can stop thinking about it!
    Problem Solver:
  • 3 Answers
Replace Brown Flex Ribbon Cable, which is connected between Display and Main unit. it is a common problem, this cable gets cracked since it moves with display. Teknofix
Posted on Mar 07, 2009
CDX-M20 marine stereo problem
Same problem here. Do you recall what you did to bring up the display?
Apr 20, 2012 | Sony Cdx-m20 Marine In-dash Boat Stereo...
Im not sure about power wire red black ground and yellow not sure?
Connect black to earth or battery negative.
Connect red to battery positive or the acc lead from your ignition switch. If connected to acc the unit will power down when the vehicle is switched off. If connected to battery positive it will remain on irrespective of ignition switch position.
Connect yellow to battery positive for memory power. The moment this lead loses power all the settings/memory on the unit will be lost.
Leave a comment if you require further assistance
Dec 29, 2010 | Sony XPLOD CDX-GT200 CD Player
Need a wiring diagram for a sony cdx-gt08 it is going into a 2000 saturn sl2 I have the new wiring harness but need to know what wires go where
yellow to yellow main power wire
red to red key wire
black to black ground
speaker wires are green purple for rear speakers and white and grey for front speakers solid wire color is power and black lines is ground
orange is dimmer switch you wont need it
blue wire is for power anntenna your car shouldn't have it and blue with white stripe is remote wire if you have an amp it will shut off your amp when hooked up any other wire unnessary for your car some head units need a anntenna adapter to work good luck. remember ground before anything and disconnect the battery so you don't blow the fuse
Mar 13, 2010 | Sony XPLOD CDX-GT200 CD Player
Need colour coding for wiring back of radio
black= ground
blue= antenna
red= power ingition
yellow= 12volt battery
blue\white= amp turn on
Jul 17, 2009 | Sony CDX-S2000 CD Player
Hooking up a sony cd changer cdx-434rf I am not
hey, i just found one of these in my garage and im trying to connect mine too.. I found out what the wires do...
black(ground) - any metal part of the car
red (remote) - to a wire that gives 12v+ when ignition is on.
Yello (power) - 12v+ source, just connect this wire straight from + on the battery.
Read this manual for more info....
http://safemanuals.com/fullswf-SONY.php?type=.SWF&file=SWF/SONY/15-01-08-13-09-05-614&langue=en&img_width=839&img_height=1191&cat=vide
Apr 11, 2009 | Sony Car Audio & Video
Powered subwoofer wiring
Red = 12v power Always
Black = Ground Allways
Blue = memory wire that has to run to a Amplifiers Memory Terminal
2x White, seems to be the dimmer and Ant, but im unsure as of these two,
Rca's will go into the AUDIO out of the cd player RED and White holes, that will go to your amplifier.
Im unsure if your talking about a Cd player here, but it seems this it is. If so you should have color coded wires for speakers also (ex- green, green with white stripe, Yellow, yellow with white stripe )
Please provide more information if this dosent solve your problem
Thank you
Sep 11, 2008 | Sony CDX-M610 CD Player
Wiring diagram
First, you can buy a harness for whatever vehicle you're putting it into and the colors on THAT harness will match the harness on the radio.. With that said:
black---------ground
red------------12V Switched (ignition)
Yellow-------12V (constant)
blue-----------power antenna
blue/white--Amp turn on
orange-------dimmer
white--------Left front+
white/blk---Left Front -
Gray---------Rt Front+
Gray/blk----Rt front-
green--------left rear+
green/blk---left rear-
purple--------rt rear+
purple/blk---rt rear -
Aug 04, 2008 | Sony CDX-M610 CD Player
Sony cdxm610
Red- Constant Power -
Yellow - Ignition power - 12v
Black - Ground
Blue - Ant & memory
Orange - Dimmer
All the wires that have 2 of the same color are speaker wires
ex - green, and green with stripe. The one with a stripe is the Negitive
In most cases the red and yellow need to be together to get the cd player to start if you dont have 2 hook ups for both constant and ignition powers.
The black ground can go to any bolt that is screwed into a metal grounded object. The blue and orange are not needed unless you have a harness that supports the dimmer and memory feature.
If you cd player works with this but wont keep settings or time, hook up the blue to the power so it can constantly save your settings.
All the speaker wires a total of 4 diffrent sets of 2 can go anywhere as long as you dont want to fade or bal your speakers if so you need to test them by hooking up 1 speaker at a time to find out where it leads to. GOOD LUCK
And
Thank you for your question
CDX-M610 CD Player
Constant 12 volt is yellow,switched 12volt is red. Mix these two up and you'll lose your presets everytime you turn your car off. Ground is black. Sony uses gray,green,white, and I think purple for the speaker wires. You'll have green and green with a stripe going to one speaker and so on. Check out Sony.com, you can print off wiring diagrams that are model specific...
Mar 18, 2008 | Sony CDX-M610 CD Player
Sony CDX-M610 CD Player Logo
221 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
