Plasma tv I have A plasma mod # 42PF7320A/37 that has some red line from left to rt ?
  • patmac2 Sep 22, 2008
    This set was turned off and on about 10 times and still the same red lines could it be the y driver or the y board.????
  • 84 Answers
Couple of ideas
possible adverse effects relate to the altitude and are common to all plasma displays. Once the set is brought below approximately 6562 ft (and/or local air pressure equal or above 800 hPa) its function should return to normal.
This can occur when the Component Inputs or HDMI Inputs are used to display HD pictures or Progressive Scan DVD player pictures.
  • Press and hold down the Cursor button on the remote that matches the direction that the picture needs to be adjusted, and release the button when the picture position is correct.
Posted on Sep 22, 2008
  • 558 Answers
Thanks for your posting in FixYa.
Please do the following:
Most significant cause is the Magnetic effect, try to switch it on and off two or three times. then everthing will be ok.
Hope this would help you a lot. Dont forget to rank me up. Have a nice day.
Best of Luck & Regards
Posted on Sep 21, 2008
  • Puneet Jain
    Puneet Jain Sep 22, 2008
    Thanks for your reply.
    This is the vertical output circuit gone bad in the TV. A repair cost might range 200.00 or so. Here is a link that
    might help you find a shop.
    Let me know if it is helpful. Dont forget to rate me for up to helpful.
We have a Philips plasma 42PF7320A/37 tv. When we plug it in, all we get is a red blinking light. We took the back panel off and looked at the capacitors and they look fine. What else should we check...
cOUNT THE NUMBER OF RED BLINKS AND MAKE NOTES OF THE SEQUENCES. Third will tell tou what is wrong with the tv during it's self diagnostic.Google the make and mogel numbr and seaqrch you anwers from ther.
Jul 09, 2011 | Philips 42PF7320A 42 in. Plasma HDTV
Vertical Line on Phillips 42PF7320A/37
Hold down the cursor button towards the green line, it's really that easy...
Mar 07, 2010 | Philips 42PF7220A 42 in. Plasma Television
Tv turns off and I get a red flashing light on philips flat tv model 42PF7320A/37
After looking through the user manual I could not find any error codes to diagnose your problem. I suggest calling Phillips Customer Support at 1-888-PHILLIPS.
Sep 30, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Why do i have red lines on my philips plasma tv?
if the lines are going horizontally across and look like someone took a thin magic marker and marked across the screen, you have one of two problems, either some scan ic's have failed or you have a flex cable coming loose from the panel. Either way it will require repair. If it is the flex cable the cost to repair will be beyond the tv's worth because the whole panel needs to be changed to fix this. If it turns out to be the scan ic's, they can be changed or the board the ic's are on may be changed depending on how the repair is approched by the tech. But the cost would be reasonable around 200 to 250.
Good luck
Sep 03, 2009 | Philips 42HF7444T 42 in. Plasma TV
Philips 42PF7320A/37 blinking red light
hello, amigo if the all the caps are godd then you have to replace the power supply board. don't try to fix it this is not an easy task. you are looking at almost $200.00 with tax an shipping. just go to google and type your tv model # and ask for the power supply board or just look for the part# on the board itself. good luck
Jul 29, 2009 | Philips 42PFP5332D 42 in. Plasma...
This set is a HD plasma tv and convergence is done differently than the rear projection tv's,rear projection tv's have convergence Ic's and you can adjust the color but not on this unit.
Nov 23, 2008 | Televison & Video
Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Nov 17, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
My Plasma TV is not working any more
Sounds like a scan problem if yu suspect the y-sus i suggs\est changing the drivers to
Nov 16, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
sounds like the Y to replace all 3 at same time main and buffer upper and lower
Jul 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42PF7320A blinks 3 times every time i hit the power button
The SSB is small self contained board that u connect your Antenna, and HDMI to. An error three is a communication error between the SSB and to Logic board ( located underneath the SSB on the back fo the plasma panel that is just below the power supply. U can check and see if u want to purchase a SSB for this TV. Is the 3blinking lights coming from the front of the TV. Also check the power supply and see how many times the green led blinks on the upper left of the power supply and let me know.
Apr 24, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
