Question about Toshiba Televison & Video
The color red no longer works on my Toshiba 65HDX82 rear projection television. I am trying to figure out if it makes sense to repair. The rest of the TV seems to work fine.
  • 70 Answers
If the tv is digital (high def) it does make sense its just a bulb most likely. if its analog it does not make sense. for a plasma or lcd with comparable picture to rear projection will be 5-6 grand and the colours will be comparable. less money will get you less than perfect colour and black levels on your set. only if your set is digital if not its a very different story if you need more help let me know i can guide into the right decision
Posted on Sep 21, 2008
Toshiba 65hdx82 has a squiggly distorted side to side picture from all inputs. It gets slightly better after it is warmed up but still very bad. When you go into a menu screen that seems to be OK.
Ur convergence is the problem.U know how to solders?Tries websites.Tv repair World.com,Tvrepairkits.com for convergence kit,replaced what in the kit.
Dec 15, 2009 | Toshiba 65HDX82 65" Rear Projection...
Toshiba 65HDx82 video problems
I had a similar problem with a similar model by Panasonic. Unfortunately you will need a certified tech. to pick it up and repair it at there shop. It cost me around $400 bucks and when I received the TV back the remote no longer worked and the repair shop did not man up to the fact that they where liable. They just said they would order another signal reciever for the TV and never did. So, good luck. It is reparable just be careful who you deal with.
Oct 04, 2009 | Toshiba 50H82 50" Rear Projection...
Toshiba rear screen projection tv theaterview colors wavey? It no longer is visible, the colors are separated
1.) It sounds like you have a convergence problem; in the customer menu with the original Toshiba remote select convergence--if blue or red will NOT move in some direction you have a bad convergence IC.
2.) This set uses 2 STK-392-110 convergence chips; they and any open resistors around them need to be replaced and the set adjusted.
3.) If you are able to do this repair yourself you can save a lot of money--Most TV shops will charge 300-400 for this type of repair on this set.
4.) If you cannot do the repair yourself look in your area--now is the slow time of year for TV repair shops---if they say it "has to go to shop" keep looking----almost any good tech can do this repair in your home in about an hour--I have done hundreds of them here and charge 200-250 total depending on brand and model.
5.) I am here to help people and if you have questions or need advice let me know--the two chips this set uses you can buy on Ebay for about 12 dollars plus shipping.
I do this here for free, so if this information has helped you give me a vote here---let me know by replying here if you need more help.
REGARDS SD TECH
Sep 14, 2009 | Toshiba 50H82 50" Rear Projection...
Distorted Picture
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Aug 02, 2008 | Toshiba 65HDX82 65" Rear Projection...
Warped picture Toshiba 65HDX82
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 12, 2008 | Toshiba 65HDX82 65" Rear Projection...
Protective screen
buy another screen from a person who sells plexiglass
Apr 06, 2008 | Toshiba 65HDX82 65" Rear Projection...
Toshiba 65h82
check the screen voltages goinfg to all three tubes. Another thing you could try is unplug the crt socket to the red and see if the other tubes stay lit . There ia a possiblity that the red tube could be over powering and shutting the others off or down.
Apr 18, 2007 | Toshiba 65HDX82 65" Rear Projection...
Toshiba Projection Picture discoloration
burn in on one of the tubes try magic focus?
Mar 12, 2007 | Toshiba 65HDX82 65" Rear Projection...
No picture.
sounds like a short in the hirizontal output section of the set. Please this is a high voltage circuit and not some place a non trained tech should be poking about. Find a service tech to assist you with this repair.
Sep 03, 2006 | Toshiba 65HDX82 65" Rear Projection...
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
