Question about SMProAudio SM Pro Audio TB202 2 Channel Tube Mic Preamp and Compressor Microphone
I would like to ask anyone who has experiment on hook up....
I bought the product TB202 , but I dont know how to hook up to the mixer 1202-vlz3. If anyone can show me how , I'm appreciate
thank you
johnminhchi@yahoo.com
  • johnminhchi Sep 22, 2008
    I did'n think you can help me. thanks anyways
    your information is not help at all.
Just bought the mixer and when i hook up the mixer to the amp the amp showing it clipping and no sound to the main speakers
If you are getting signal from you mixer at leaves tha are clipping your amp, then the mixer is working and at least the front end of your amp is working to register the clipping. In that case, your problem is-
1. The amp outputs are blown, check by hooking up to a different amp.
2, The speaker wires are connected incorrectly.
3. The speakers are not working. Try a different set.
May 21, 2016 | Mackie 1604 Vlz3 16 Channel Mixer
Do you have necessary cables to hook up balanced output? its 3 pin cable.
Please let me know to help you further.
Sep 21, 2008 | SMProAudio SM Pro Audio TB202 2 Channel...
How do I hook up two powered 15's and two passive 15's to this mixer(1202-VLZ3)?
You connect the powered 15's using balanced cables. The passive speakers you will have to get an amplifier for as the mixer does NOT have a powered output, only line-level audio outputs.
The powered speakers MAY have audio line level outputs to continue to other powered speakers or, as in your case, external amplifiers to drive your passive speakers.
Remember to power ALL interconnected equipment from the same receptacle or source to avoid ground bounce faults that can destroy sensitive circuits in your equipment.
Mar 05, 2011 | Mackie 1202vlz3 12 Channel Mixer
Good day i have a second hand mixer and my problem is the main output,headphone are humming what solution to this and thanks ........ joel bee
Download the schematic:
http://elektrotanya.com/mackie_1202-vlz_pro_schematic_diagram.pdf/download.html
On page 10 you will find the power supply. You will likely find a failure among the components:
D4, D5, D6, D7, C1 or C2
There could also be a circuit board crack around these items.
C1 or C2 is the most probable failure. They are 2200mfd/25 volt electrolytics.
Feb 16, 2011 | Mackie Vlz3 1202 12 Channel Analog Micline...
Type pf op amp in a Behringer XENYX 1204USB Mixer and a Mackie - 1202-VLZ3
Behringer uses 4580's in appropriate packaging everywhere. There are 339 comparators for the level indicator area.
The Mackies uses both NJM2068 and NJM4560M
The 2068' are used in most of the low noise areas and the 4560 is used in the 75Hz high pass filter for example.
Jul 22, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
I was trying to hook up our 1604 vlz3 at our church and was wondering how the best way to do this?
Without knowing the resources you are connecting I cannot give you a schematic but will give this GENERAL advice:
1. Use BALANCED lines to connect from the mixer to your amps, preferably XLR connections.
2. Service the power to the amps and the mixer from the SAME place even if it means stringing a power cable alongside you audio cable snake.
Jun 12, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
29 people viewed this question
Top SMProAudio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a SMProAudio Audio Player and Recorder Expert? Answer questions, earn points and help others
