Question about Refrigerators
Kenmore Trio 596.75509400
Fridge section has stopped cooling but lights are still on; freezer appears to be working fine. Fridge is not cooling but freezer is working fine. lights are on hear it running but feel no cold air.
My problem is identical to jcalhoun on Sep 21, 2008..I have a Kenmore Trio 596.75502400. Freezer is ok..Lights are on. Any help would be appreciated.
Posted on Sep 21, 2008
Fridge section not cooling enough but freezer OK
Is the fan blowing in the freezer section? Also, check to see if you have airflow thru the damper (vent) in the frig section.
Mar 31, 2012 | GE GSL25JFPBS Side by Side Refrigerator
Fridge not cooling .kenmore trio frezer works fine
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts: http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Oct 06, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Freezer is working fine but the upper area refrigerator is not cooling properly. Temperature is barly cool but not cold.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 26, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Servis Fridge Freezer not working
fridge appears to be working, but freezers section intermittingly keeps going off
Apr 19, 2010 | Refrigerators
Hi, I have an LG refrigerator, the top freezer works fine but the fridge section has stopped cooling, I turned the unit off and next morning there was a large puddle of water on the floor, when I turned it...
When the fridge is not cooling that means the fan are not working or not working properly, need to replace or check if their is an ice bothering the fan to turn. ok
Feb 15, 2010 | Refrigerators
Our Kenmore Trio 596.76512500 freezer works, refrigerator section stopped cooling.
it probably needs new fans in the freezer... check to see if they are blowing, you can usually hear them when you open the freezer door
Jan 14, 2010 | Kenmore 24.8 cu. ft. Trio French Door...
Kenmore Elite Trio Fridge Not Cooling
check the over-load/contactor on the side of the compressor,remove it and shake it if it rattles,replace it
Nov 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
480 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
