Question about Creative Labs Zen Digital Media Player
Zen wont turn on or charge
My zen wont turn on or charge and i press the reset button but still showin no signs of life
  • D-Darke Sep 26, 2008
    I plug my zen into a PC desktop computer and when i did this is went white and shut off, now it wont turn on. I have pressed restart button but that dosent work. Its as if the computer shorted out the battery. Has any one else had this problem? I cannot return it because it is passed the warranty date.
  • busted zen Dec 28, 2008
    My Zen is doing the same thing. The only time it shows any sign of life is when it is plugged into my computer. The screen flickers white every once every second. I can't turn it on, charge it, and my computer doesn't recognize that it is connected. None of the above solutions worked as my player is completely unresponsive.
  • 8,596 Answers
Creative Zen
Try another PC or another USB port
Make sure the hold/lock is not engaged
Reset
Check for firmware update on Creative's website
Get Recovery Tool from Creative
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If all else fails, check with this guy:
http://www.mycreativefansite.com/2007/05/myzenchecker-tools-guide-to-problem.html
Creative Zen – Formatting
Step by step instructions for formatting a player
1. Detach the player from the PC if it is connected, and turn off the player.
2. Press and hold the Play button while powering on the player.
3. When the player displays the Creative logo, release the Play button
4. Select Format (All) and select Yes to format the player.
5. After the player has finished formatting, select Reboot.
6. Re-transfer the tracks to the player.
-Tha Mp3 Doctor
Posted on Sep 27, 2008
I've dran a pattern on my zen touch & cnt remember it
Posted on Dec 29, 2012
Zen mozaic has frozen and now it won't even turn off, have tried pressing all the buttons but nothing happens
Did you try the reset button on lower left side of player? I use a twist tie and cut paper or plastic off tip to press button.
Nov 15, 2009 | Creative Labs Creative Technology Zen MP3...
My Zen Mozaic is dead, won't charge on ANY computer. Was fine b4.
I had this problem myself and the solution is really simple. As you look at the Zen, turn the left hand side towards you. Near the bottom you will see a very tiny "reset" button. Press and hold (with a pin or fine pen tip) for a couple of seconds, then try turning the Zen on. It worked for me
Sep 12, 2009 | Beond Creative Technology Zen Mozaic MP3...
Turned off when i was looking at it
You need to replace the battery in this unit as its not putting out enough charge to power the unit even tho it says it charged.
hope this helps
Aug 22, 2009 | Creative Labs Zen Digital Media Player
How can i turn on my zen
The reset button cap on the lower left side of the unit may be jammed, causing the reset switch it activates to be come stuck.
This will put the unit into a loop in which it continually restarts.
You'll never see any sign of life if this occurs.
Be sure you see the "RESET" stencil or that may not be the reset button.
I've seen people poke paper clips their devices' microphone or speaker openings!
Be very careful when pushing the reset so that the button cap goes straight down.
If yours is stuck, unstick it, then it should come on if the battery is charged.
Then be sure to give it a FULL charge before using it, because while the button was stuck, power was being consumed.
Be sure to remove the rubber boot / skin before trying to reset the unit.
Jun 28, 2009 | Creative Labs Creative Technology Zen MP3...
My zen won't charge or turn on
Press the restart button on the bottom right side of the player. Then try to start it, it should work.
Jan 08, 2009 | Creative Labs Creative Technology Zen MP3...
Creative zen
Don't buy this unit. The power system is prone to being blown out when disconnecting from USB. I've blown out two. I'm on my third. BAD DESIGN. AVOID IT!
Nov 09, 2008 | Creative Labs Zen Digital Media Player
My creative zen is completely dead it doesn't power on at all also it doesn't charge there is no power what so ever please help me
I have had the problem of the completely dead player after having it for less that an day. No response to any buttons, no response when plugged into USB to charge, and Windows sees it as an "unknown device" when plugged into the PC. It tried the reset hole, and still nothing.
Then I tried connecting it to the PC to charge and then using the reset hole. Success - the player sprang back to life, fully charged. Hope this helps someone.
Jul 17, 2008 | Creative Labs Zen Stone Plus MP3 Player
Creative zen
If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Q. How to reset Zen v +
http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
Feb 11, 2008 | Creative Labs Zen Digital Media Player
Creative Labs Zen Digital Media Player Logo
378 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Brian Sullivan
Brian Sullivan
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
