Question about Kenmore 24032\24036 Top Load Washer
Kenmore washer elite top load
Drum will not turn or move at all ... and makes a some what load grinding noise
  • 32 Answers
Sounds like you have a bad coupler.mach does not have a belt it uses a coupling system between the motor and trans.if you fill mach and it makes the same noise in agitation,replace the coupler
Posted on Sep 26, 2008
Kenmore elite makes loud grinding noise with larger loads like a comforter. Ok with normal loads
It is so common that the washing machine can maketerrible noise in many ways and is a common fault. In all occasions it isimportant that your observation is most important and so is vital to theidentification /rectification and solution. If you have noticed that machine isvibrating when it is running then the motor /drum suspension has to beinspected. Since these fittings are located on the underside of the machine itis important that you look for the noise with a good inspection lamp. Manuallyturn the motor and drum and listen for the noise, if so the motor bearings, thedrum agitator shaft and fittings must be checked. Also the suspensions whichinclude the shock absorbers and springs, the body clamps must be checked to bein correct alignment and not changed in position. Tightening of themounting is also very important. Finallyin most cases a drop of OIL or smear of grease on the moving parts cane solvemost issues.Check this link : of bearings check for tips on this visual link:
Jul 29, 2012 | Kenmore Elite HE5t Washer
Kenmore top load washer. The drum won't turn and makes a grinding noise.
The direct drive coupling between the motor and transmission needs replacing.
Sep 29, 2010 | Kenmore 24032\24036 Top Load Washer
I have a kenmore Elite front loading washer and yesterday during a load it made a terrible noise and when the washer was opened two of the fins inside the stainless steel tub had fallen off and now when...
u will need 2 replace all the baffles .remove top when this done on top of tub u will see a plug removethis . if u notice on the new baffle there is a place for a screw, that screw hole can b acessed through the hole in the top. the factory never puts these screws in the noise I dont know about. haundi24
Jul 21, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 137889, grinding noise
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the tub.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
The drum bearing is replaced by accessing the bottom side of the washer, and is a not a simple repair.
May 05, 2009 | Kenmore 13789 / 13782 Dishwasher
Kenmore elite heavy duty top load washer
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Grinding noise
replace your drive coupler. cheap fix. i charge around $60.00
Jan 01, 2008 | Kenmore 22422 Top Load Washer
Kenmore Elite King Size Top Load Washer
If your washer fills, agitates, drains, but will not spin, the likely cause is the gear case (transmission). A new gear case can run about $200 just for the part. With labor, this could be a bit expensive to repair. I hope this helps you some.
Jul 30, 2007 | Kenmore 22642 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
106 people viewed this question
Sal De
 Brian Main
Brian Main
