Question about Frigidaire FRS26R4A Side by Side Refrigerator
Freezer burn on all foods when sealed by me or the manufacturer
Model # FD126RBS1
Serial # TH33069363
All of my food gets frezzer burn
Ther is ice inside all of the sealed stored food whether or not it comes sealed or I seal it with a ziplock or a Tupperware-like container. Why?
email : irishdad75@hotmail.com
  • 32 Answers
You might need to turn the freezer temp. up a little. I think 0-10 degrees is good.
Posted on Sep 28, 2008
  • papaross3 Sep 28, 2008
    Also try to find out if the auto defrost is working properly if it has one.
Model EEV-163F Whirlpool Upright Freezer. Defrosted this week, already seeing ice buildup. Freezer is cold and appears to run fine, but frost buildup seems excessive this quickly. Frost throughout
This freezer is not frost free. Being an upright limiting the amount and frequency of opening the door will reduce the build up of ice. Ice is expected and depending on humidity and quality of seal around door affects the amount of ice.
Using a thin ribbon check the seal integrity around the door. Confirm nothing is prohibiting the full closure of the door.
Adjust door if necessary. Replace seal if defective. Freeze open unsealed items in a frost free freezer before locating frozen food in this unit.
These units are likely located in the garage where the humidity is high. If used only as needed planning transfer between this and the kitchen unit frost can be minimized.
Being a conventional freezer not frost free freezer burn is less likely and frozen food will not dry out as quickly. Confirm that the freezer maintains about 0 degree F.
This unit is likely more efficient and will maintain the food frozen longer in the event of power outage.
Hope this helps?
Jun 24, 2017 | Whirlpool Refrigerators
How can i operate the temperature of the haier fridge model hrf-660aa
do you hear the compressor come on? can u feel it vibrating? if not? bad relay maybe? is there power from the outlet? may also have a bad cold control thermostat or defrost timer? is ther any heat in the freezer compartment?
Feb 16, 2015 | Haier Refrigerators
Slight smoky smell and freezer food/ice taste smoky
sounds like your motor is is burning out or someing inside the fridge is burn
Nov 19, 2013 | Kenmore Refrigerators
I have a ffa90 futre fridge & bottom frezzer. the fridge is frezzing the food in the door & in the fridge. have tryed water in botles & they get ice on it .in the door the food frezzers so
Find where the supply air is coming into the fridge part. It comes from the freezer and could easily be supplying -18 air direct to the door. This would give you a 2 in the fridge but anything in the direct air path could freeze.
Sep 07, 2012 | Hotpoint FFA90 Bottom Freezer Refrigerator
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
We have a frigidaire upright (ffu17m7hwd) which formed a lot of ice and we are in the midst of defrosting and don't want to experience this again. Can you assist please? Had to throw food out due to...
Freezer burn to food is caused by air & moisture in contact with it.
There should be a tight seal by the rubber gasket along all the inside edges of the freezer door. This gasket prevents unwanted hot moisture and hot air from entering the freezer compartment and causing ice build up. You can test the integrity of the rubber gasket seal by seeing how the freezer door will pinch a slip of paper in various spots around the freezer door. If the slip of paper pulls out easily, there is not a good seal at that spot. If that's the case (which I believe it is), the door gasket needs to be replaced. By the way, ice will build up over time because you need to access the food in the freezer, hence you will introduce moist air each time you open the freezer door.
Aug 28, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
G e profile refridare the frezzer and the freide are both to warm and we had to take food outof the frezzer. i hear it running. water comes out of the ice maker all the ligts work and the dors seal. what...
Hi, I once had this problem. My freezer and refrigerator were both warm, but I could still hear it running. When the repair guy came out he immediately checked the back interior of the freezer (had to remove a panel) and it was entirely frozen solid with ice. He said the defroster had stopped working, which caused the coils to all freeze. It took him about an hour to get all of the ice off. He replaced the defroster. Total cost was around $250.00.We have a GE side by side Profile, about 8 years old. Works fine now.
Jul 19, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Fridre is about 9 years old. For the last couple of weeks it's been making louder than normal humming noises and the temp is not cold, even when the thermostat is at it's coldest, same with the bottom...
the wind tunnel in the frezzer is iced up, therefore the fan is rubbing against the ice creating humming noise. solve this by defrosting and replace fridge seals before u get sick and die! food poision is bad. termostat should work, but may need be replaced.
Dec 16, 2009 | Fisher and Paykel Refrigerators
Frigidaire FRS26R4A Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
