Question about Conair GS16 Iron
Where can i get replacement bulbs for conair model BE6FV makeup mirror?
  • cblloyd63 Apr 08, 2009
    Need replacement bulbs for Conair BE6FV lighted make-up mirror
Can i refill conair butane cartridge
There are two videos on YouTube on the subject. Before you start, remember neither the Fire Marshal nor your insurance company will be happy with you when you burn the house down.
How To Refill Thermacell Butane Cartridges Cheap Save Money
How to refill thermacell butane cartridge the easy way Save money
Feb 27, 2015 | Conair Instant Heat Curling Iron, Model...
How can i fix the cord from my conair
Small Appliance Repair shop may be able to help, but probably best and more economical to just replace. If money is a factor to replace, check local thrift stores for a used one.
Sep 24, 2013 | Conair Professional Ceramic Hair...
Conair steamer green light comes on but low water beeps. water full.
How To Use The Conair® Deluxe Fabric Steamer
www.conair.com/how-to-use-the-conair-reg-deluxe-f...
Conair CorporationThe Conair® Deluxe Fabric Steamer (model # GS11DR) conveniently rolls to any spot in your ... This unit comes with a rotating hanger. ... The switch will light to indicate when power is on. ... Note: If the low water indicator lamp becomes illuminated but the water tank is not empty, follow the instructions for decalcification.
[PDF]Instruction Booklet - ExtremeSteam® Upright ... - Conair
www.conair.com/.../gs95_13pa140688_ib_final.pdf
Conair CorporationMar 1, 2013 - ... water only. 8. Plug the steamer unit into a standard 120V AC power outlet. 9. ... Push button on T-nozzle - light will go on and steam will start.
Customer Reviews: Conair Extreme Steam Fabric Steamer ...
Aug 16, 2013 | Irons
I just got my Infinity by conair model cs32 straightener and it will not turn on or heat up. Please help.
If you just purchased it today or up to 30 days after purchase, TAKE IT BACK!!. If you start having problems from the beginning you will possibly always have them.
Sep 14, 2011 | Conair Infiniti Instant Heat Ceramic Hair...
Hand steamer conair GS15R will not produce steam. It is on, it is full of water, the body gets warm, and it makes noises like it is steaming but nothing comes out.
Hi.
The iron steam lines may be clogged with limescale.
Try first using descaling solution to clean the lines.
Do descaling several times.
If that does not work, then the thermostat may have started malfunctioning and cutting off earlier than normal. This will cause water not getting enough temperature, and iron not steaming.
Try using a descaler product, often that can fix the problem.
Jan 14, 2010 | Conair Irons
Power chord frayed and I need a new one for a conair hair iron CS36. The chord pivots in the handle 360 degrees.
go to (www.fixit.com/small apliance)
what I found out with my hair dryer (conair infinity model) was that there was a short at the plug and when I bent the wire a little to left or right the dryer would work. The plug is GFI protected that means there is a test and reset switch built in to the plug. There for for me to fix my hair dryer I would have to replace purchase order the whole cord. The cord assembly cost almost half the price it would cost to replace the dryer with a new dryer. I purchased a new dryer.
Dec 26, 2008 | Conair Dry 'N Straight Hair Dryer and...
I have lost my operating instructions, I have a Conair G3 compact garment steamer and want to use it, how do I start. Thank you for your help.
Check out a video manual on Conair Fabric Steamer
at http://www.handbooklive.com/
Click on Appliances category. The video instructions are for GS4 model but it must be similar.
Hope that helps
Sep 03, 2008 | Conair Compact Garment Steamer Iron
Conair GS16 Iron Logo
198 people viewed this question
Top Conair Irons Experts
ashburton
Glenn Smart
Glenn Smart
Piyal Perera
Piyal Perera
Are you a Conair Iron Expert? Answer questions, earn points and help others
