Question about Kenmore 62872 Electric Dryer
Question about kenmore dryer
Hi I have a kenmore and a little while ago it stopped drying cloths while it turns the clothes just dont get dry. We think it has something to do w/the heating element I have the model #417.84092500, its only about 3 years old, I hope I dont have to replace the control panel that is really expensive, but basically I took it apart pulled the drum out tested the charge of the wires it seems to be good... I dont know what to do from here please help!
  • 5,911 Answers
Most heat related problems associated with long dry times are contributed to clogged ventilation. A dryer needs proper air flow to dry efficiently. If the external ducting is clogged, this will cause the internal heating circuits to actually overheat to the point of failure. If your dryer is heating, but simply taking a long time to dry, I would recommend a thorough cleaning of all ducting.
An easy way to determine if you have restricted air flow somewhere is to simply remove the vent house from the back of the dryer and attempt to dry a load as you normally would. The air flow coming from the dryer should be forceful and warm (about 140 degrees F on most dryers). If it is, I would begin an inspection of your ducting from the point where it enters the wall, to where it exits your home. Rule of thumb: The SHORTER and STRAIGHTER the vent ducting, the BETTER. If you have ventilation that runs up the wall and into an attic, runs under a crawl space, or has excessive bends or kinks, all of this can contribute to creating chokes points where lint can accumulate and cause more resistance on the blower. In a nutshell: it reduces the dryer's efficiency.
If the air flow coming out of the dryer is weak, you need to inspect the internal ducting where the blower fan is. If the air flow is cold, you more than likely have a blown thermal cut-out (safety thermostat), or heating element. On your model dryer, the heating element and TCO are located behind the drum. If both components are good, you should be able to see the element glowing through the holes in the back of the drum and feel heat.
Read through the advice I've given and let me know what your symptoms are. Hopefully this is just a simple air flow problem. NOTE: DO NOT run the dryer for extended periods (meaning days or weeks) with the vent hose off. This will cause the humidity level in your home to increase, along with the temperature. Which can lead to mildew. I hope this information is helpful. Let me know if I can be of further assistance.
Posted on Sep 21, 2008
  • Jeff Rockwell
    Jeff Rockwell Sep 22, 2008
    "Thanks for Trying"? The last paragraph I asked you to read through the advice and let me know what your symptoms are. That way we exchange information to try to resolve your problem. All dryer heat related problems are not alike. That's why is is necessary to ask for specific information and give preliminary advice to ensure the problem is not a simple installation or cleaning issue. I generally stop giving further advice once the solution is rated negatively.
  • Jeff Rockwell
    If your dryer is NOT heating at all, you probably have a failed safety thermostat or heating element. They both are located behind the drum. You will need to remove the dryer drum to get these components. Of the two, I suspect the safety thermostat is blown. This component acts like a fuse and commonly blows if the dryer overheats. If it blows it must be replaced. Since you mentioned the lint accumulation, you may have overheated your dryer.
  • 21 Answers
Http://applianceassistant.com/Appliance-Repair/Appliance-Service-Repair-Manual-Feature.php?id=1813 check this link out
Posted on Feb 09, 2014
I cannot respond for some reason it will not let me log in I didnt say thanks for trying I have been trying to log in and let you know that basically it did have alot of lint in the system we cleaned it out now today i have to go through the task of putting it back together which will take hours my grandfather even took apart the control panel
Posted on Sep 22, 2008
  • majstikle971 Sep 22, 2008
    We tested everything and only the timer was the only thing that didn't show a charge
I have a Kenmore 500 series dryer, model number 110.79522800 that will note completely dry clothes. It seems like it doesn't run long enough, heat high enough or a combination of both. What can I do to...
Your Sensor that senses the clothes are wet or dry is shorted out. The dryer works likes this so the dryer heaters dont stay on while the clothes are dry. When the sensor senses the clothes are damp or wet, the heater stays on, when they start drying the sensor senses it and starts to turn down the heaters
http://tlc.howstuffworks.com/home/dryer6.htm
Mar 10, 2011 | Dryers
Dry take hours to dry
need to check hi limit thermostat on element make sure it is not cycling to soon
Apr 13, 2010 | Kenmore Elite HE4 Electric Dryer
My dryer runs but does not heat up or dry clothes. What could be the problem?
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
Feb 16, 2010 | Kenmore 62602 Electric Dryer
My kenmore dryer heat element goes on and off. The clothes take hours to dry.
It seems to run forever If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system. Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Dec 31, 2009 | Kenmore Dryers
Kenmore 11066912690 dryer stops working
if you are using the sensor drying cyle this could cause the unit to stop. it will detect the most dry clothing first usually light clothes that dry faster.if not and you are useing timed dry the most likely cause is a faluty timer,or a thermostat sesnor is going bad and turnoing off the dryer before the clothes are dry
Sep 16, 2009 | Kenmore 62602 Electric Dryer
Clothes dryer drum stops turning during drying cycle
your motor is going out , it doesn't have wenough to keep going.
Jun 26, 2009 | Dryers
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Dryer no longer has heat to dry clothes
The element gets brittle and breaks. The element is in the rear of the dryer under the dustcover.
May 06, 2009 | Kenmore Dryers
Gas dryer not drying clothes
Hi, Dryers are simple machines to fix yourself so the main reasons dryers do not dry cloths is listed below.
1. Make sure the vent is clear from obstruction of lint built up by taking off vent and make sure the vent flap is opening when dryer is on, beware most house fires are caused by neglect of dryer vent!
2. People allot of times overload machine which causes cloths not to dry.
3. Electrical Repair Needed: one of the thermostats in the dryer are defective
May 02, 2009 | Dryers
Kenmore 62872 Electric Dryer Logo
160 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
