Question about Sony VAIO PCG-U1 Notebook
Printer configuration Hi chaps - I have a Dc424 photocopier/fax/printer and been trying to get it to work- I have connected the USB cable properly but my place has on internet connection could this cause my printer not to work???
Need to hook up a brother MFC-210c so it can fax
Install the software (Brother MFLPro0 relevant to the printer. If you do not have the original CD download the appropriate suite from Brother Solution Center.
When you install the software you will be asked to choose USB, or Local Network. You can always install the USB and connect the printer to the calculator through USB. Different installations for different connection types (USB, LAN)
After you configure the software, you can open the Control Center 3 software and use the fax.
To be able to fax, you need to connect a telephone cable to the port marked line. After you do try pressing the unhook button. If connection to the phone line is correct you will hear the tone.
The MFC can fax without being connect to a computer, just the phone line.
Jul 30, 2012 | Brother MFC-210C All-In-One Printer
Faxing on my Dell Pc
dear Smitty1935
Kindly remove all the drivers and install once again the drivers , please note , do not take option reinstall, remove the drivers and then install the fax drivers
thanks
Gizmo
Jan 01, 2008 | Dell 924 All-in-One InkJet Printer
I have print server d-link dpr-1020 connected to laser printer hp P1006. My PC is running under windows 7 Pro. Print server is connected to linksys wrt120n router by cable. My PC is connected to the...
Hi, to make sure your printer is online. Please do these steps:
? On your windows 7 computer, please go to control panel and click printers and faxes.
? From printers and faxes, you can see your printer icon, right click the printer icon and select online.
? Try to print and that should be working.
Nov 05, 2010 | D-Link RangeBooster G DPR-1260 (DPR1260)...
My lexmark 4300 series says incorrect port detected
Hello!
Yes the problem is with your printer port setting, to view or to correct the printer port setting,
- go to CONTROL PANEL
- click or open Printer or Faxes
- right click your Lexmark printer and click properties
- a menu will appear, choose or click PORT tab
- at the Port tab listing, choose USB port and click ok after choosing the right port.
then you should be able to print properly after the right configuration.
Hope I was able to help.
Jul 23, 2010 | Lexmark All-in-One Printer with PictBridge
Printer is not print properly
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
aswq3
Aug 28, 2009 | HP Officejet 5610 All-In-One InkJet...
I am trying to hook up to a hp laserjet printer to the computer
disconnect the printer from your omputer (the cable i.e; parapllel, usb, CAT-5).
trun off the printer.
unisntall the printer software from your computer
restart the computer
reinstall the pirnter software.(don't connect the printer).
restart the computer again
connect the printer, turn on the printer
configure the printer from start>>printer and faxes.
Jan 13, 2009 | Dell Dimension 9200 PC Desktop
Epson TM on Windows XP with serial
you need to use the printer cable that was design for the printer. if you don't have the cable anymore, then you have to take the commercial cable apart and reconfigure in accordance to page 43 of the manual call outs.
Besides the cable, the printer software is only good for Windows 2000. Windows XP will not work unless Epson provide you with the printer driver. (which I did not see on the website).
all in all if you must use this printer with Windows Xp. you need to create a file in Autoexec.bat to enable the printer and allow the USB to connect to the printer.
that is going take time to do. if you need help on that. please post the request here.
Thanks
Dec 03, 2008 | Office Equipment & Supplies
Printer will not print
check your usb cable.may be it is fauly.
go to control panel then printer and faxes.
then right clik on your printer then ports.
then select your usb port and clik on configure port .
if u receve error.
your connection is not proper.
if good .then try to install driver from here.
www.nodevice.com/driver/X74-X75/get33244.html - 16k -
Nov 12, 2008 | Lexmark X75 All-In-One InkJet Printer
I just purchased a laptop with XP Home. I have an HP Laserjet 6L which does not have a USB connection. So I installed a "USB to IEEE 1284 Parallel Printer Cable." The computer found the...
Power OFF both Printer AND Computer.
Boot up computer.
Insert the USB cable into a port.
WIN XP will recognize and install needed software.
Attached the USB cord to the printer.
Power up the Printer
Next configure the Printer . . .
ø Start > Settings > Printers and Faxes
ø Right-click on HP LaserJet 6L
ø Properties
ø Ports
o Find “USB001 Virtual printer port for USB"
o Select this, if not already done
o Apply
Jul 08, 2008 | Office Equipment & Supplies
Photo copier
Please confirgue the print server properly. Assign a particular ip address to it if possible. Then install the photocopier driver in computer and add the network port ip eual to the ip of print server. if it does not work install the print server driver if comes with it as a printer and assign it a ip.
Jun 19, 2007 | Toshiba (GD-1010) for e-studio25S, 16S,...
Computers & Internet Logo
32 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
