Question about Troy Bilt Tb70ss Gas Trimmer
Stops running Weedeater worked fine on first two uses. On third use, started fine, ran 5 minutes, made a sound as is something in the carbuerator/ engine area vibrated loose and died. Would not restart. Put in garage and 1 week later tried again. Started fine, ran 5 minutes, sounded like something vibraated loose, engine died and would not restart. Where do I start looking for a problem, or is it too late to retur it for another one?
  • 163 Answers
If you bought it recenly and still able to return or exchange at store, try that first. if not, check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. if that doesn't work have the carb repaired at a service center or replaced.
Posted on Nov 29, 2008
Lawn mower stops running after 4-5 minutes
Sounds like a bad float in the carbuerator. It could also be bad fuel filter. I suggest you run this one by Partstree.com in Austin, Tx.
Jul 19, 2014 | Toro Garden
I have Ryobi weedeater that has a new Carbuerator,getting gas to the cyl.an has good fire to the plug an will not start need help bad
Make sure u r not getting to much fuel. With switch off pull string twice then turn switch with throttle cable helded wide open try to start.good luck.new dose not mean adjusted good luck
May 31, 2014 | Ryobi Garden
My air compressor starts right up, runs for approximately a minute, then quits. If left sitting for a minute or two, it will start again, and run for a minute, then stop. If you shut the fuel off, it...
It sounds like the compressor is reaching the max psi it can hold. At this point can you use a air tool or blower? The reason it comes back on is to keep the psi at running level. It replentishes the lost or used air.
Bruce
Mar 31, 2011 | Honda Air Tools & Compressors
I have a weedeater brand hedge trimmers 18 inches long. I rebuilt the carb and replaced fuel lines and filter. The unit ran fine until the last two times that I have tried to use it. It will run and...
have you checked the fuel plate thats in the bottom of carb? they tend to dry up and because rubber the 2 stroke fuel makes it dry and shrink, then it no longer pumps fuen into cylinder
Mar 01, 2011 | Weedeater Gas Powered Hedgetrimmer...
2001 monty carlo changed battery securty light flashing car wont start. car ran great before any trick or code i dont know to get it to start
Leave the key in the run position until the security light stops blinking. This should take 10 minutes. Then turn the key off, wait 5 seconds and try to start it. The security light should be blinking again. Leave the key on again for 10 minutes. Repeat this 3 times. After the third time on the the next start it should start and run fine. This will reprogram your theft system.
Feb 06, 2011 | 2001 Chevrolet Monte Carlo
I have a Weedeater FL1500. I just changed the
Once it heats up either the spark plug or the ignition module is breaking causing them not to work. I would first check on the price of the ignition module, Then decide it is to expensive to repair and send it to the scrap man.
Good Day.
Oct 30, 2009 | Poulan Featherlite Gas Blower, with Low...
Replace fuel lines WeedEater FL 1500 Blower
On the FL1500:
  • The Smaller line goes on the Lower inlet tube on the carborater the other end goes to the gas filter inside the gas tank.
  • The Larger line goes on the upper outlet tube on the carborater the other end goes to a fitting that holds this tube from coming out on the gas tank .This tube is only for Air, it helps fill the primer bulb when pushed.
I hope this helps.
Mechs correct me if I have made a mistake.
Thaxs Jon
Sep 09, 2009 | Garden
Coleman Powermate 6250 stops after 5-8 minutes of running
the carby needs to be cleaned out properly the jets blown out with air.when you intendto stop useing for any length of time swich the fuel off and let itstop by running out of gas or drain the carby before storage ,as fuel evaporates and the additives dont they build upafter a while and start to block the jets make sure motor is level,oil cutoutcan be fooled if not level ,disconectwire if worried about that bing the problem
Jul 28, 2009 | Coleman Powermate Premium Plus 6250W...
Stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Apr 23, 2009 | Ryobi Garden
6.5 tubbo diesel died and wont start back
Sounds like the fuel pump got air in the system. You may have to bleed out the air. Then it will run. Check the fuel tank for fuel first.
Nov 23, 2017 | 1998 GMC Sierra
Troy Bilt Tb70ss Gas Trimmer Logo
320 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
