Question about Kenmore 15516 Mechanical Sewing Machine
The fabric doesn't move forward.
My machine was working fine.... Suddenly, while sewing the cloth stopped moving ahead. I checked the threading, the bobbin etc. I guess, the metal zig-zag teeth (which are just below the needle) are not pushing the cloth. Now when I start the machine, the needle keeps going up and down on the same spot on the cloth. I don't know what could go wrong....just few minutes back the machine was fine. I have the same problem, the zig zag will not move forward.
  • 2 more comments
  • Anonymous Sep 30, 2008
    Same exact thing
  • Anonymous Oct 21, 2008
    Track is to low and will not move cloth forward.
  • keldaugherty Nov 19, 2008
    same problem, the feed dogs don't pull the fabric through.
  • Anonymous Dec 08, 2008
    Last time I used my machine it worked fine and now the feed dogs aren't visable and won't pull the fabric through.
    New Friend:
  • 46 Answers
What is the length set at?
Are the feed dogs visible at the needle plate?
What does the design look like in the pattern box?
Have you tried it on the straight stitch to see if is effected also?
Bonnie
Posted on Nov 06, 2008
  • Jimmie Sill Aug 10, 2016
    Sometimes thin material doesn't move very well. Try to adjust the foot pressure to a lower level.
ELNA 1000 not moving fabric through.
Have you got a tangle under your fabric? If so, release the fabric and rethread your machine, making sure the foot is up during threading. Otherwise check the feed dog under the foot. There's usually a switch somewhere that brings the feed dog up or down. If it's down the fabric won't feed. Another point, what type of fabric are you sewing. If it's leather or leatherette you'll need to use a roller foot. Hope this helps.
Oct 03, 2017 | Elna Sewing Machines
I have a singer model 513. It suddenly stopped moving the fabric forward while sewing....the little "teeth" are not moving, is this a belt issue or something else?
The feed dogs are not pulling the fabric through the machine properly. There are gears and arms that make that all happen.
These parts can break. Look for a switch or setting that lowers the feed dogs for free motion sewing. Please let a professional trained technician make any repairs or adjustments.
Cheers,
Embroidery Services
San Diego, CA
Sep 14, 2017 | Singer Sewing Machines
Cant get the feed teeth to come up and grab the cloth -- the cloth wont move --do I have it set on darn ?
it is possible that you have the feed in the neutral position ( halfway between forward and reverse ) from your problem discriotion
Apr 24, 2016 | Singer Sewing Machines
I have a Bernina Activa 130. I tried to sew over some leather, started fine, then the needle got stuck and I stopped right away. Now, the bottom threads keeps bunching. I have re-threaded the machine, new...
You need a fatter needle. The skinny needle will not open the leather enough for a smooth flow of thread and that's why the bobbin is bunching up when the top thread is sticking. Make it easier on your machine by using an appropriate size needle while sewing leather.
Nov 04, 2013 | Bernina Activa 130
The machine won't stitch anything...
check the feed dogs in the needle plate area to see if there up,
if you can see them & touch them with your finger, I'm putting in a link
for a free manual, so you can see where the lever is to the feed dogs, just
incase they are not up. if they are up then they may need to be checked
to see why they aren't moving the fabric.
http://www.singerco.com/uploads/download/1199_8770-efs.pdf
Jun 27, 2012 | Singer Curvy 8770 Electronic Sewing...
Won't sew, the fabric stays in one spot
is the problem the fabric is not moving forward but staying in one spot? which would mean the feeddogs need to be checked to see what position there in --up for sewing---down for darning
or the thread is not feeding into the machine?
Feb 10, 2012 | Janome DC3050 Computerized Sewing Machine
Fabric won't feed forward
Do the feed dogs move up and down? If they dont the plastic gear underenth has probably broken you can take this to a singer dealer and have them replace the plastic gear with a nylon one which would last longer than that did
Jul 16, 2009 | Brother LS-1217 Mechanical Sewing Machine
Machine stopped sewing
The thread is caught in the hook...Remove the upper thread and bobbin case, turn the hand wheel backwards and forwards by hand and remove the thread remands. Good Luck
May 28, 2009 | Sewing Machines
We need to do some examining. Remove the foot. Put the stitch length dial at the longest stitch. Turn the wheel and see if the feed dogs move about 1/4 inch. Also check to see that they rise just slightly above the needle plate. If it does these two things it will work. If the teeth don't rise above the plate, remove the needle plate and clean the lint out from between the rows of teeth. If you find a lot of tightly packed lint there this will solve your problem. Reinstall the needle plate and foot. If the feed dogs don't move about 1/4 inch, you probably have a problem which is going to require the services of a technician.
sewman7
Jun 09, 2008 | Brother LS-1217 Mechanical Sewing Machine
Fabric not moving forward
in can not re thread my bobbins what do i do
Oct 29, 2006 | Euro-Pro Shark 80 - 7133
Kenmore 15516 Mechanical Sewing Machine Logo
410 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
