Question about Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor
Power Saving Mode problem using the DVI input. VGA input Ok.
In VGA Mode the monitor goes into power saving mode as set under display properties. Using the monitor with the DVI input, it cycles in and out of power saving mode in 1 second intervals at the time set in the display properties (green--amber--green--amber--etc) (screen flashes gray--black--etc). I am thinking that I need to reload the display driver or a bios update. I hate to fool around and cause more problems.
  • 1 more comment
  • John TS Sep 21, 2008
    This is not a stuck in power saving mode situation as seen in many of the posts.
    Yes, I checked that the new cables are securely fastened.
    The monitor works fine with the DVI set up. After the 20 minutes of no activity, it tries to go into the power saving mode, but insteads cycles as stated above. Moving the mouse or hitting a key brings the monitor back into normal display mode.
    Please see my reply which gives further details.
  • John TS Sep 22, 2008
    Tried turning off the screen saver and setting power saving to 2 minutes as suggested. I entered power saving mode in two minutes, but the cycling continued. My mouse is the ball mouse, not optical. That was a good thought.
    I don't have another computer with a DVI port. But I will try to borrow a portable computer with a DVI port to narrow the problem to computer or monitor as suggested. This will take a few days.
  • Dell Master
  • 13,433 Answers
Try the display on another computer, if the display does the same thing on another machine, then its definitely a problem in the display not in the computer drivers or bios.
Posted on Sep 21, 2008
  • Ekse Sep 21, 2008
    also if you could try your computer with another display, to see if your computer is working fine or not. would help to narrow down what the problem really is and where it is at. display or the machine.
  • 61 Answers
Rip out a toothbrush (without toothpaste of course) or a safe brushing device and brush all of the prongs on the DVI cable. If certain prongs are not contacting the DVI input on the computer it could leave out necessary operations such as screensaving.
Posted on Sep 22, 2008
    President:
  • 1,263 Answers
Go into your control panel feature. click on the apperance tab. then click on the screen saver tab. you should be able to adjust the time it takes for the hibernation and when the power save and screean saver come on. in your appearance menu you should have option tabs for power save, hibernation,and screensaver. i'm sure you just need to adjust the settings and remember to click the apply tab and then ok..;.please rate this
    Sergeant:
    Champion:
  • 435 Answers
Hi, Please check the cables. loose input connection may take monitor into power saving mode.
Does the LCD show anything when computer boots?
Please disconnect the DVI input to the LCD and check. If this problem persists, it has nothing to do with BIOS or driver updates.
hope it works,
cheers,
  • Karthik P Sep 21, 2008
    Ok.
    Try changing it to 2 mins( instead of 20 mins) and see if the problem persists after 2 mins of inactivity.
    if it does, you may have to update the graphics drivers and see.
    I hope you are using Windows XP.
    By the way, is the screen saver on? if so, try turning it off when you do the above.
    This may sound naive...
    Are you using optical mouse ?
    Sometimes, depending upon the orientation of the mouse/ surface, it might disturb the sleep mode of the monitor.
  • Karthik P Sep 22, 2008
    Guess you should go for Driver update.
Hi. I have a FLATRON W1934S computer. Every time I switch it on it says "power saving Mode". How can I fix it?
Hello, I didn't understand the problem.
1.After switch on and it goes to power saving mode , which can be visibly seen by changing the color of power led from green9or blue) to yellow.
First thing to be done is when it goes to that state "power saving mode" remove the video VGA cabl , and if the unit gives video message "no video signal" which stays for a while and usually goes again to power saving mode , this is OK,
So if there is no video signal on input it should work like this. so you have to check you PC.
Another way is to use laptop or other PC to check the monitor itself.
Hope this helps a bit
Oct 29, 2014 | Computers & Internet
LG 2542T goes dark after showing "analog power saving mode" message
Can you try the screen in another computer? I beleave the screen goes into power saveing mode when there is no input signal, thats what both my screens do.
Is your computer working?
May 16, 2008 | LG L1717S-BN 17" LCD Monitor
I have a lg flatron LCD w1934s-bn when I switch on the computer display coming and with in seconds monitor going in power saving mode. I change the VGA cable, change the system also same problem.
If your monitor goes into Power Saving Mode with different computers, it is most likely the signal input board in the monitor. I'm sorry to tell you your monitor is shot. It is probably repairable if you can find the correct board. Monitors are relatively inexpensive at the moment, and going by the "VGA only" input, it is time to upgrade, You will also get better resolution and picture quality.
Apr 20, 2012 | Computers & Internet
I have a flatron w2253tq and have "analoge power saving "on. I cannot see the desktop
Is the monitor connected to the computer using a VGA plug (a smaller one, with 15 pins in 3 rows), or a DVI plug (wider one, with flat pins in 2 rows)?
From what you write, your monitor is switched to the analog input (VGA). It doesn't sense any signal on that input and hence goes to power down mode.
You need to go to your monitor's on-screen menu and select the digital input - you should see the picture then.
Jul 02, 2010 | LG 22" FLATRON LCD Monitor
Computer screen goes into "digital power saving mode"
You should be able to adjust the settings on the monitor to prevent it from going into power save mode, or at least to delay how long it takes before it goes into power save mode. Press the menu button and look for settings that might disable or change power save mode.
Also, does your desktop/PC display show anything before the monitor goes into power save mode? If nothing comes up, its possible that you have a loose VGA connection or that your video card/motherboard are defective in some ways. Try using a different monitor.
If the other monitor works fine with your computer, try changing/lowering the screen resolution. If in XP right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution. If in Vista/Win7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there. Then check and see if your newer monitor works on it.
If the other monitor also doesn't show any display, most likely the problem is either with your video cable or your PC's video card/motherboard, not the monitor.
Hope that helps. Good luck
Feb 15, 2010 | LG L1915S 19" LCD Monitor
With Windows XP and Dell Latitude docking station, Dell 2001fp set to DVI, goes to Power Save mode and no display. It works fine with VGA input. It had been working fine for ~2 years.
Update Bios & Video Driver Also right click on my computer,go to properties,go under hardware,you can see hardware profiles,delete the dock profile (while the system is off the dock) & then dock & restart
Jan 08, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Power saving mode on screen when I turn computer on
if you are using dvi connector, change to vga connector
Jun 23, 2009 | LG 22" FLATRON LCD Monitor
"No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Sep 14, 2008 | BenQ FP71E 17" LCD Monitor
No display.
http://support.dell.com/support/edocs/monitors/2005FPW/En/setup.htm#Using%20the%20OSD
Make sure the proper input is selected
1: D-SUB for Blue VGA cable
2: DVI-D for White DVI cable
The option selected should be indicated on the power save screen.
If changing the input select and rebooting the computer have no effect an no video from the computer is ever displayed, then the monitor is in need of repair.
Jun 30, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Open Questions:
Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor Logo
913 people viewed this question
Alun Cox
