Question about GoVideo VR3845 DVD Recorder/VCR
Remote damaged REMOTE CONTROL NEED TO REPLACE
    Sergeant:
    Champion:
  • 435 Answers
Hi, This one is similar. But they say that it does not have TV buttons.
http://www.remotes.com/store/go_video/vr3845.html
I hope it should be fine since you may just need this for controlling DVD/ VCR player. Hope it helps.
Posted on Sep 21, 2008
  • 70 Answers
Dont order from go video this is a common brand and many very moderatly priced universal remote controls are avalible at ciciut city and any store that sells universal remotes u can get one for under 20.00
What is error code 76 on a Rheem tankless hot water heater that has propane connection?
Communication Fault with Remote Control. At a minimum check the following: 1. Check remote control wiring for loose or damaged connections. 2. Bypass remote control cable by connecting remote control directly to remote control terminals on PCB. Replace cable if found to be faulty. Yes Either the wiring or the remote control is at fault. To rule out the wiring, disconnect the remote control and use a short, good jumper wire and connect directly to the remote terminal on the PCB. If the unit works using the remote, then the wiring is at fault. If the unit does not work, then the remote is at fault. Did the unit go to main burner? No Replace the Printed Circuit Board Remove remote control wires from wiring terminal on the PCB. Plug unit in and open a hot water source.
Dec 16, 2016 | Rheem Water Heaters
Remote control does not respond
If the case is not damaged, remove and re install the batteries. That generally fixes problems like this. If not you will have to replace it.
Dec 25, 2013 | Hampton Bay 52 In. White Redington...
Remote doesnt control tv
Check the remote control for its infrared emission. Check it with fresh batteries. Clean the contacts inside the battery compartment. If rust or dust obstruct the proper contact, the remote won't work. Clean these contacts before you replace the batteries. Check this link to know about how to check the remote controls. If the infrared sensor inside the TV has damaged, the TV won't accept any remote control signals, even though the remote control is good.
Jan 16, 2013 | Sansui Televison & Video
Error code = C4 76
You could look at the error codes list from :
http://www.palomastore.com/paloma_error_codes.html
Communication Fault with Remote Control Check remote control wiring for loose or damaged connections. Bypass remote control cable by connection remote directly to remote control terminals on PCB (replace cable if found to be faulty). Replace remote control. Replace PCB
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 22, 2011 | Rheem Water Heaters
Volume control on reciver isn't working. Only using remote control for volume works. So I must need a volume control for the receiver. Is this an easy fix or not worth the time to fix
Hello
You haven't specified if all the other functions are working with the remote control or not. If no functions are working with remote control, either there is no infrared emission from your remote control handset. Check it with the help of a cellphone with camera option. Cellphone digital camera can detect the infrared rays comes out of the remote control. Just put the cellphone to camera mode, and place the remote control just about 1 feet away from its camera lens and push each button on the remote control and see whether there is any image of infrared rays indicates at your cellphone camera screen. If not, be sure that the remote control is not working, and should be replaced or repaired. Replace the cells first, and check. If this does not helps you and still the remote control is not working, replace it.
If the remote control works, and the all the other functions of your device can be set with it, the motor of the volume control or it control circuitary has damaged. To check this, you must have through knoledge in electronics and is a time taking service work. OK.
Apr 24, 2011 | Sherwood RD-6500 Receiver
I have sign C7 76 and the unit shuts off. What is wrong?
Sorry to read about your problem, I hope this helps you out.
Your code 76
Check remote control wiring for loose or damaged connections. Bypass remote control cable by connecting remote control directly to remote control terminals on PCB. Replace cable if found to be faulty. Replace remote control. Replace PC
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I have a Rheem tanklees water heater, model RTG-74XN-2. The remote shows the following error code. C4 then the number 76 then C4 then 76. What does this code mean??
Contact Paloma/Rheem 866-720-2076. Super nice! I just called regarding mine. Having same problem Rheem Paloma sending parts out tomorrow overnite. Try turn it on/ off by moving tiny switch under the unit that tells you the temperature. Run your fingers along the bottom to find it. That is a temporary fix. Below is a website with all the error codes, so you know what is wrong. Good luck and blessings!
76
76
76
76
Nov 06, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I keep getting error code c4 76
You are having a communication fault with remote control...........#1...Check remote control wiring for loose or damaged connection. #2-Bypass remote control cable by connecting remote control directly to remote control terminals on PCB. Repalce caable if found to be faulty #3- Repalce remote control and #4- replace the PCB. These are items connected to your problem....it may be anyone of these....Good Luck
Apr 11, 2009 | Rheem Tankless Hot Water Heater...
Yamaha rx-v800 remote control's damaged
it can be accessed via the main unit controls but you need to go through your manuals. Maybe you can get your remote repaired still... maybe not badly damaged caused by corrosion.
redrivera0314@yahoo.com
Feb 04, 2008 | Yamaha RX-V800 Receiver
GoVideo VR3845 DVD Recorder/VCR Logo
153 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
