Need to install this 1gb of memory - Computers & Internet
  • 781 Answers
Find first what type of ram you computer needs.. try http://www.mobel.com/memoryfinder.htm or
1. look for your manual of your motherboard.. (look inside the case and get the alphanumeric code printed on *********** board.. watch the electrostatic discharge.. it may run your pc components.. (ground yourself by touching the the power supply first)
2. once you have the code for *********** board.. google it up!
3. find what specifc type of ram your computer needs. and where to install it on your computer as you may have room but depending the motherboard documentation you may have to put it a certain order or in a certain dimm, rimm or simm slot..
things to keep in mind.. if you buy memory that's not the one your computer needs because you're brave and you think you can do it yourself.. if the memory turns out not to be compatible with your system (it's a possibility because it has happened to me)... you're stuck.. because you can't return memory!!.. plus if you don't do it right.. you may damage a component inside your computer...
my advise.. pay for the upgrade... and have someone to blame if it gives you problems!!
Posted on Sep 21, 2008
EMachines T3304 won't work with 2GB memory
might not be a working pair
are the memory modules of the same brand and type
IE: hynex ddr3 low density
if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
hope it helps
Jun 21, 2012 | eMachines Emachine T3304 Amd Sempron 3300...
I have a HP dc7600 small form pentium4HT 3.4 GHZ with 1GB of Ram. What type of RAM do i need to max this machine out safely?
Memory Type: DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 4GB
Slots: 4
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.*
*Not to exceed manufacturer supported memory.
icon_note.gifAlthough the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.When using PC2-5300 parts the maximum memory is 2GB. When using PC2-4200 the maximum is 4GB.
Jul 30, 2011 | HP dc7600 Small Form Factor P4 640...
How much memory can I ad to a SR1802HM computer and do I need an external hard drive to handle more memory?
You dont need a extras Hard drive That someting else .. Hard Drive and Memory are two differente Thing... Go on the Net and Exemple... Type Compaq Presario SR1802HM.. Manual & Spec, You will get all the information your need for it ....
Sep 22, 2010 | Compaq CPQ SR1802HM PRESARIO DESKTOP...
Is it possible to install high desnsity memory RAM on a T42
The T42 can support up to 2 Gb of RAM.
The laptop comes with 512Mb of RAM under the keyboard and a spare memory slot on the bottom of the laptop.
To install 2Gb of RAM put 1Gb in the memory slot under the kerboard - need to remove the old RAM and put the other 1Gb in the memory on the bottom of the laptop
T42 Memory specs.
  • 64-bit Double Data Rate (DDR) non-parity SDRAM memory
  • PC2700 at 333MHz
  • Two 200 pin SO-DIMM memory slots, one slot is pre-populated with 256MB or 512MB, leaving one socket available
  • Supports up to two 1GB SDRAM SO DIMMs
  • Supports maximum memory up to 2GB
Sep 22, 2009 | IBM ThinkPad T42 Notebook
Removed 1gb memeory and installed 2gb but only 2gb recognized
You may need to go to your manufacturer's website for toshiba, and flash your bios with the latest flash for this.
Sincerely, Ryan Deschaine Systems Engineer Boxen Solutions LLC http://www.boxensolutions.com
Email address: ryan@boxensolutions.com
Office number: 262.432.3120
Mobile number: 262.364.6196
Fax: 414.918.8432
AOL: BoxenRyan
Twitter: BoxenRyan
W172 N9175 Shady Lane
Suite 418
Menomonee Falls, WI 53051
Jun 30, 2009 | Lenovo T7200 Notebook
Olympus c-740 reads card error when 1gb xd memory
its non supportive to 1gb card as you will have to get the device upgraded to make it support 1gb.
Mar 03, 2009 | Cameras
Installing 2GB of memory in my Fujitsu Siemens Amilo Pro V2020
Here is the problem, the laptop take 2GB RAM. 1GB in each slot, so get 2X1GB RAM. They are cheap now. You need 2, 1GB sticks of ram. For cheap prices go to Newegg.com
Have a nice day!
Dec 22, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
P4m800-m7 Rev:3.1 RAM PROBLEM!
the problem is with the new ram.
its phsically damged.
may be little bit that you cant see it.
try checking the other 1GB ram.
Nov 08, 2008 | EliteGroup P4M800-M7 Motherboard
RAM upgrate
you can upgrade to a max of 2gb on that board. These are your 1gb options: 1GB PC2700 333MHz DDR Memory, 1GB PC2100 266MHz DDR Memory, and 1GB PC3200 400MHz Non-ECC Unbuffered 184-pin DDR DIMM Memory. Install a set of any of these and your off and running.
Dec 22, 2007 | FIC P4M-800T Motherboard
Installing 1GB Memory
the problem is will your processor read 1GB of random acess memory. install you open the laptop remove the screws and access the mother board push down the usually white clips and lift the ram straight out, when installing make sure you ease the stick into the socket and when you have it against the bottom push it firmly until the clips lock back into place.
Dec 09, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
131 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
