Question about Canon Office Equipment & Supplies
Canon faxphone l80 error tx report tx function was not completed
    Genius:
  • 2,120 Answers
Call the other fax machine with a cell phone, listen for fax tones.
plug a regular phone in the jack to check for a dial tone.
make sure phone cord is plugged into the LINE port of yhe fax machine.
Posted on Sep 21, 2008
2 Suggested Answers
  • 1126 Answers
SOURCE: how to print a tx report with canon L80 faxphone?
Here is a link to Canon for your FaxPhone L80 Users Guide. Reference page 14-3 to access the menus, page 14-5 for report settings, and 14-6 for TX Settings
http://gdlp01.c-wss.com/gds/0300000539/FAXPHONE_L80_Users_Guide_EN.pdf
Posted on Jan 07, 2010
How do i get a fax confirmation to print?
Press function then data registration and set/ok.It will say user settings,press the arrow down to get report settings,press set/ok,it will say tx report press set/ok and use the arrows to get output yes,press set/ok and stop!It will print one after every fax u send!Enjoy!
Apr 29, 2010 | Canon FAXPHONE L80 Laser
Not getting fax report and want to set time and date on l80 faxph
Press functionand then data registration,press set/ok and it will say user settings,press set/ok and it will say date and time,press set/ok and type in the correct date and time press set/ok and stop!To get the report press function and data registration and set/ok,use the arrow down and scroll to report settings,press set/ok and it will say tx report,press set/ok and use the arrowdown untill u get output yes!Press set/ok and stop!Enjoy!
Apr 24, 2010 | Canon FAXPHONE L80 Laser
Every fax we try to send it comes up with a error tx report of "NG". What does "NG" mean and how can we fix it?
Hello.
NG means: Some or no pages sent.
Check the paper feeder to see if the page is pulling through.
Listen to see if the fax line "sounds"like it is working or if you hear dialing or not.
Hope this helps.
Mar 22, 2010 | Canon FAXPHONE L80 Laser
How to print a tx report with canon L80 faxphone?
Jan 07, 2010 | Canon FAXPHONE L80 Laser
Tx function was not completed
This problem is caused by telephone line noises,you can set your Tx speed to a lower transmition by pressing dataregistration and scroll to system settings press set and scroll to TX Start speed,set it to a lower tx speed and test if it help.You can check the tel line type settings under usersettings and make sure it is is on Tone.Another way to to over come this problem is to switch beteen ECM on and off in the TX settings.
Nov 30, 2009 | Canon FAXPHONE L80 Laser
Need to turn off report after every fax sent
Press [function] button and then [dataregistration] on the display dataregistration will be displayed,press [ok] user settings will be dislpayed,press the arrow down until you find report settings press [ok], tx report will be displayed,Press [ok] again.It will show on the screen "output yes",press the arrow untill it show "output no" and press [ok] again.
Thats it.
Apr 01, 2009 | Canon FAXPHONE L80 Laser
Confirmation sheets
Yes,press usermode go to reports and in RX report switch it to on.
Jul 11, 2008 | Canon FAXPHONE L80 Laser
Fax confirmation
1. Press Function key
2. Press Data Registration key
3. Press Set key
4. Use (up or down) arrows to select REPORT SETTINGS
5. Press Set key
6. Use arrows to select TX REPORT
7. Press Set key
8. Use arrows to select OUTPUT YES
9. Press Set key
10. At PRINT WITH IMAGE, use arrows to select YES or NO (YES will print the first page of the fax with the report)
11. Press Set key
12. Press Stop/Reset key to exit menu
May 23, 2008 | Canon FAXPHONE L80 Laser
Canon FAXPHONE L80 confirmation
First print out your user data.
Press Function, then Report, then arrow down to User Data List and press Set. This gives you a printout of your present menu set.
Now press Function, press Data Registration, press Set. Arrow down to Report settings, press Set.
Select TX Report, select yes.
You can also select that the first page of the document sent shows up on the confirmation report.
Feb 20, 2008 | Canon FAXPHONE L80 Laser
Canon FaxPhone L80
Press Function, Data Registration, and then Set. Use the up/down arrows to select "report settings", then Set again. Using the arrows and Set change the values or TX REPORT and RX REPORT to "YES". This will pring a TX/RX report after every fax. When you are done press Stop/Clear. This is from Sectioon 14 of the owners manual. Let me know if you need more help.... Mediaman85@mchsi.com
Aug 20, 2007 | Canon FAXPHONE L80 Laser
553 people viewed this question
old marine
old marine
