Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Help Black line going down the middle of my tv. When I turn off the tv for about 10 mins it goes off and picture resumes but after 30 mins of watching tv it comes back on. Very annoying
  • Hitachi Master
  • 5,568 Answers
Considering that it's a LCD type, that is not a good sign; the individual pixels are addressed by a matrix and that kind of indicates that a vertical driver for that column is failing and these are often not replaceable by human hands having pin spacing too close for shaky techs.
If you want to confirm that this is heat related, you can buy a can of freeze spray from any electronic supply house and spray into various slits in the housing to see it you can restore that column temporarily with it.
Posted on Sep 21, 2008
Black vertical line
This seems to be a problem with some older panels. If you are prepared to tackle the problem yourself then try the following.
WARNING there are some very high voltages within the TV which can be LETHAL so the greatest of care should be taken.
With the back of the TV removed, use a hair dryer and apply warm air to all the ribbon cables in turn until you find the one which causes the fault to disappear. Now turn your attention to the faulty ribbon and remake the connections as necessary.
Dec 19, 2013 | Insignia Televison & Video
Picture has lines and goes black after warm up
Try unplugging for 2 mins. Or press power button for 30 seconds. Your Light in the tv might be shot.... happens every 5 or so years.
GOOD LUCK
CNBY
Jun 03, 2010 | JVC RM-C18G-1H Remote Control
While watching tv half the screen goes black
Download software from the Phillips web site. Use a usb flashdrive to transfer the download to the TV. This worked well for us and our picture is better than ever.
Apr 09, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
Picture goes black mins after watching
Bad flyback transformer. It has a short in the winding making the Horizontal output transistor heat up so when its too hot the set goes into protection.
Aug 25, 2009 | RCA D52W23 52" HDTV CRT TV
My tv is 2 years old and in the last month or so in the middle of a show the screen will go black and a red line runs down the middle and it lasts for about 5 min and a little pop sound and the picture...
It appears you may have had a line collapse caused by a poor connection in the line output stage, it would be a matter of resoldering around this area. Now that you say it will come on could indicate that a component has now failed as a result of the line collapsing, more than likely the line output transistor has now also failed & would need replacing.
Jul 01, 2009 | Jensen Q2749J 27" TV
Samsung 42" Plasma -Black vertical line when turned on.
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
May 25, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Mar 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Vertical Lines all over then starts to move lines back and forth
you should first check all the cables inside the set to make sure they all are seated properly, check some other sources like a dvd player and see if it does it on a dvd, after that it is probably a defective main board
Nov 07, 2006 | Samsung HP-R5072 50 in. Plasma HDTV
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
57 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
