SOURCE: braun 6512 shaver stop working
hi i would say that you have major problem with this did you drop it sounds like a problem with the circuit contact braun or shavers uk kevin.
SOURCE: Braun Toothbrush repair?
The Battery is comprised of two 2/3A nicads with spot welded connector tabs. A battery supplier can manufacture this 2.2 volt pack for around $10 US.
To get the battery out first unsolder the two wires from the sides of the circuit board. Then release the three tabs that grip the spring assembly. Next unsolder the bottom -ve battery tab from the bottom end, then unsolder the +ve top tab from the circuit board. You will need a solder ****** to remove all the solder fom the +ve.
You can then push the battery pack out of the tube and put in the new battery pack. To put the bottom of the case back on you have to push it in with the coil wires slightly twisted 1/8 counter cw.
I used a steel ruler in the slots to give good leverage to twist against the force from that spring.
SOURCE: Braun 5614 rechargeable cordless shaver light flickers
Your batteries are starting to degrade, but the good news is they're still holding a charge for a week, so you really don't need to rush to replace them at this point.
The flickering of the charged indicator is normal, as the shaver is still plugged in and the batteries are fully charged. The flickering is due to the batteries chemicals breaking down, and as such, the charge cycle keeps "topping" them off while it's still plugged in.
When you finally aren't able to get a decent amount of cordless operation and run times from your shaver, then you'll want to get them replaced, whether you decide to do that yourself or have it done by a professional service center, is up to you.
Here's a reference for your future use. www.electricshaver.com carries replacement (factory OEM) batteries for most brands of shavers and they also will provide the repair/replacement service for you, should you decide you don't want to do it yourself. You can also give them a call at 1-888-476-1785 and request a price quote, etc.
Anyway, your shaver is working fine and all you need to do is make sure you're not letting the shaver stay plugged in and charging constantly for more than a day, since any "extra" chargind isn't doing anything except keeping the batteries at a constant state of charge. Heat is a byproduct of charging and discharging any battery and as such, you want to allow for a cool down period before recharging them.
I tend to use my shaver until it is almost completely discharged before recharging it. By doing this, you can get the longest working life out of your batteries before you'll have to replace them.
Hope you find this Very Helpful and best regards!
Testimonial: "very helpful"
SOURCE: Braun 6520 is not charging after changing the battery board.
there may not be anything wrong with the batteries and circuit board at all. you may have a bad motor
SOURCE: Braun 8995 clean and charge stand
it sounds like it may be dead, i do know of this great site that sells Braun stuff check it out maybe it can help. http://stores.ilikenew.com/-strse-Braun/Categories.bok
