Question about Indesit W 123 Front Load Washer
My frond loading Indesit washing machine won't drain.
It is fulled with water and the dial just keeps clicking around non stop! I can't even get to the clothes or get rid of the water to inspect the problem. Help!!
  • 3 more comments
  • Anonymous Sep 24, 2008
    My machine will not empty, just washes all not and will not even drain out first soap water.
  • Anonymous Sep 25, 2008
    mine washes then the dial just keeps clicking around non stop so then it doesnt spin and my clothes are soaking wet
  • Anonymous Oct 29, 2008
    my maschine just wont start washing, the program nob just keeps on clicking around, filter cleaned, still same problem. PLEASE ADVICE!  THX!
  • miznikki2007
    miznikki2007 Jan 12, 2013
    Mine is the same, it just washes and then the dial continually clicks, i tried to turn the filter but it will not come off. i cannot get to the underneath of the washing machine as it is in a compact allocated space
  • miznikki2007
    mine is also just clicking after doing a wash, we attempted to do the filter as suggested but couldnt get it out, our machine is in a tight compact space so we cant lift it up to get to the filter out that way and it does not fit through the allocated space.. help?
Your machine has a filter on the bottomn roght hand side looks like a black plastic knob..torn this anti clockwise watch out for water coming out of it have some towels ready clean it out and thaen out it back on turn clockwise and that should sort it out hope this helps
Posted on Oct 05, 2008
My washing machine has just decided to stop before spinning and the dial continues to click round and round and round... Its still full of water...... What do i do?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 05, 2011 | Indesit Washing Machines
Indesit WA6x washing m - dial clicking around...
This sort of problem is usually associated with a faulty control board
If there is a reset point on the timer, then reset it, and try again, if it still does the same thing, then it it is going to be the control board.
Mar 22, 2010 | Washing Machines
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
Hi! I have an Indesit W84TX washing machine. Lately, it has stopped working every time it reaches the rinse cycle. It seems to rinse and drain just one time before the process stops and the settings dial...
Actually, while the settings dial spins, there is also a kind of grinding/clicking sound from down where the drain port is. I checked it and there is no filter there when I open it.
Apr 05, 2009 | Indesit WA 115 Front Load Washer
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
Dial keeps rotating
This a common problem with Indesit washers..
It is not a timer but a programme selector switch.
What you need to do is the following.
Switch the m/c on, let the drain pump empty the water, then switch the m/c off.
set the selector switch to one of the black dots on the dial, which is stop/reset.
Then switch washer back on, if the dial still keeps going round and round, then you are going to have to call an engineer, as you have what is called an Anomaly (fault).
Plz leave feedback for this solution.
Thanks
Dec 09, 2008 | Indesit W 123 Front Load Washer
Indesit washing Machine W93
Pump or hoses still blocked,Or pump has had it,Can supply new pump by post if req.
Sep 18, 2008 | Indesit W 123 Front Load Washer
Washer will not drain
hiya
i take it you have a toploading machine then, have you removed the agitator in the center of the machine there's usually a fluff filter underneath it, this could be causing your problem.
try draining it out manually by putting the outlet hose into a bucket.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Jul 17, 2008 | Indesit W 123 Front Load Washer
LG WT-R801 keeps draining
If the cycle does not stop draining that is usually because of a faulty membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
May 16, 2008 | LG WM0642H Front Load
Indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
Feb 26, 2008 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
209 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
