Question about Canon Rebel XT / EOS 350D Digital Camera
Camera will not focus while taking pictures in low light settings
When trying to take pictures of my sons football games, the camera takes beautiful pictures until it begins to get dusk then the camera will no longer focus on moving objects. ????
I am not familiar with this camera, but if it has a manual setting for ISO when it starts to get dark outside you should set the ISO to 800 and see if it works. That's my only guess. I use all manual cameras so I'm not sure if your camera would have a manual setting like that, but I had a canon powershot that allowed me to adjust the ISO so maybe yours does too.
Posted on Sep 21, 2008
While trying to take pictures of my son's Friday night football games, the pictures come out super dark when I use the flash. If I turn the flash off, the pictures are light, but all blurry. How can I fix...
The flash is only good up to 10 feet....are you that close? If not, turn off the flash and turn up the ISO to make the camera more sensitive to the lower light levels.
Oct 09, 2010 | Samsung L200 Digital Camera
How do I best set my camera to take football game photos with low lighting and subjects moving rapidly.
You need to set the ISO to a high number. Too high and the pictures will be grainy...you'll need to experiment.
Oct 16, 2009 | Vivitar ViviCam 3785 Digital Camera
I can not get my canon eos rebel k2 focus on a
Autofocus is activated by pressing the shutter button halfway, be shure to have a EF lens in the camera, otherwise it won't make autofocus, put camera on full auto mode or "sports mode" (the running guy) and the focus settings on redictive AI Servo AF: Continuously tracks subject movement and achieves focus before the exposure starts.
Jul 10, 2009 | Canon Photography
I have a Nikon D80 with an 18-135mmNikkor lens.  It's about two months old.   Yesterday I was outside, on a snowy day,and a couple of times, I pressed the shutter release button and it would not take a...
i suggest pointing the camera to an image which has more contrast as opposed to pointing it into a clear blue sky which has no clouds at all. the AF might have some trouble looking for cue to focus. go manual focusing and see the difference.
Nov 29, 2008 | Nikon D80 Digital Camera with 18-135mm...
Actions shots are blured
The various solutions include:
try to set focus range (settings), to infinity or to an approximate distance to the object you need to take a photo of as sometimes the automatic setting does not always do a godd job at focusing , or look at the lens when it is on if its got grease use a wet camera lens cleaning kit (someone touched the glass of the lens ) a s grease makesa it hard for the camera to focus , hence blurrig or go into your options and lower the iso mode or take it off night node if any as the iso mode leads to high exposure time which means any light that changes would record as a smear hence blurring or use flash.
Nov 14, 2008 | Cameras
Night football pictures
If u r taking in low light situation, u pls change ur photo mode to Night mode.. But while u change it to Night mode, take extra care not to shake even a little.. If u do so.. u will blur ur photo..
Best of luck..
Oct 11, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Pictures of sporting events all blury
have you got your camera set to continuse focus this will cause this set the camera to on shot
Sep 28, 2008 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Nikon D40X What is the best setting for night pictures at a youth football game (under lights) My pictures are not coming out focused and very dark
It will take a little experimentation on your part, but you are likely to get the best results by turning off most of the automatic features on the D40x.
First, for exposure, a lighted field tends to have pretty even lighting across it. You still need a decently high shutter speed to capture football action, so you will need a high ISO setting.Turn your D40x mode dial to "M" for manual (see p.43 of your manual). Set your ISO to 1600 (see p.37 in the manual).
Consulting my 1973 Kodak Master Photoguide, I'd suggest using an initial starting point for your exposures to be a shutter speed of 1/400s ("400" on the LCD) and and aperture of f/4 on your lens (p.43). If your lens is slower than that, equivalent starting points would be 1/200s at f/5.6 and 1/160s at f/6.3. For best results, though, you will want to use a faster lens for night sports.
Take a picture of a subject on the field, then display it via playback. Click the multi-selector up or down until you see the histogram display. While most of the bars in the histogram may be toward the dark end of the scale, there should be some in the mid-tone region representing your subject. If everything is toward the dark end, you will need to open your aperture or reduce your shutter speed. If there are bars piling up at the extreme right or light end of the histogram, you can increase your shutter speed. Continue this process until you find the exposure setting that gives you a clear-looking picture on playback with a good histogram. You should be able to use this setting for the rest of the evening. It pays to check occasionally, though, as sometimes lights either increase in brightness with time, or some lights may go out.
Concerning poor focus: if you are using a telephoto lens under low light, the camera autofocus mechanism can either take a long time to focus, or may fail to focus. This is another case where you may get better results going manual. If you are using an AF-S lens, there should be a switch on the lens marked "A <-> M". Switch it to the "M" position and you will now focus the lens manually. You will turn the focus ring until your subject appears its sharpest in the viewfinder. If you can predict where the action will be happening, you can pre-focus on the spot and wait for the play to unfold and take the picture when the players get there. Choosing moments when players naturally have minimal movement in the midst of action is something all sports photographers learn, so as to make the most of the small action-stopping ability of shutter speeds in low light situations, such as when the quarterback stops to throw a pass, or catching a receiver at the topmost height of a jump.
Remember after the game to restore your usual settings to the camera: a more moderate ISO setting, selecting the "P" or an automatic mode on the dial, and turn the switch on your lens back to "A" for automatic focusing.
Sep 27, 2008 | Cameras
Olympus FE-280 not working properly
the lens could be the problem.. probably need to send to repair before the warranty runs out
Aug 28, 2008 | Olympus FE-280 Digital Camera
Z650 picture quality
try reformating your card and see if that helps any.
Oct 14, 2007 | Kodak EasyShare Z650 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
49 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
