Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
My lg intellowasher wd1290 error code OE
The washer goes through the wash cycle but when it comes to rinse and spin it seems to stop with soapy water in it and gives us an error code. I have tried for hours to shut down and restart. Sometimes it works but only after many tries.
  • 3 more comments
  • embassymarin Oct 26, 2008
    I actually had a repairman (warrenty) coming out on OCT 31 to fix this same issue with the OE or DE code. I opened the screw door and to my surprise the pump filter was completly blocked. The smell was horrible. I cleaned it and drained the little black hose to the left of it also. This inspired me to clean out the soap and softner dispenser also which led me to the rubber donut on the inside of the door. I completly removed the rubber dam and once again to my surpise has holes in it to allow water to pass through. Half of them had slime build up and were also blocked. It takes patience to install it back. I then ran bleach through my system on the sanitize setting with no spin and my LG Tromm works like a champ now. They make a product called "Washer Magic" that sears sells to clean the calcium and lime build up that you run through the washing machice once a month that I saw on another blogg. Thanks for the "FixYa" website for the info. It saved me an embarrassment if the repair man did come and tell me I need to pay attention to the pump filter on a regular basis.
  • Anonymous Apr 25, 2009
    this is ok helps if you have idea about mechanical knowledge,so you can order parts and replaced yurself
    i replaced inlet valve cold water side for only $47.00
    now i have OE errors code
    i removed all hoses and cleaned blocked drain tube???
    let see what i done.but lot of work
  • Anonymous May 12, 2009
    i had exactly the same problem, undid the filter cap and a bucket full of sludge came out all over the kichen
  • rc2571 May 13, 2009
    The filter was pluged but the little hose would not drain. Nothing would come out. Iam not sure why. Iam running a load to see if it was the filter.
  • Anonymous Mar 22, 2014
    Test mode - spin cycle doesn't work. And, error code when started normally is OE. What could it be?
  • 1,543 Answers
I think your "OE" is really a "DE" or drain error. Open the access door on the lower left of the front panel on the machine, drain the remaining water with the small drain hose there, and unscrew and remove the larger thing, which is a filter. Clean filter. If filter was not blocked, check for loose impeller on drain pump motor, which requires replacement of drain pump motor. (just sticking it back on will result in it coming off again)
If this helps, a "fixya" rating would be appreciated. Thanks.
Posted on Sep 23, 2008
  • Kitkat71 Mar 28, 2011
    I didn't have my manual, did a search and came across this suggestion. I tried it and so far so good! It's gong through a rinse and spin cycle but it hasn't stopped yet! You saved us a lot of money for a repairman to come and time in waiting to get it fixed. The filter was absolutely clogged with debris. Thank you!
The washer goes through the wash cycle but when it comes to rinse and spin it seems to stop with soapy water in it and gives us an error code OE.
I removed the filter (Bottom left) and like others found some sludge in the filter but not enough to stop water getting through. Inside the filter housing on the right hand side is a tube which goes in for about 2 inches where I guess it joints the rubber drain hose and the pump outlet pipe. I found 2 coins inside this tube a 5p and 1p. I got them out with my little finger and hey presto, all sorted.
Thanks to previous posts for pointing me in the right direction.
Hope this helps.
Ian.
Posted on Oct 03, 2009
Washer stops with soapy water, code displays OE. Help!!!!
Posted on Oct 19, 2008
  • nelling Oct 19, 2008
    Thank you will try as you suggest. Many thanks. Will keep you posted.
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
Lg intellowasher wf t8501tp
My washer WF-T8501tp shows a PE error code.
Can anyone tell me what's wrong with it
Nov 17, 2013 | Washing Machines
The water is still soapy after many rinses. I am using very little soap
I am having the identical problem with a Maytag washer! The first 2 or 3 rinses are effective somewhat, (but not like the Whirlpool I had for 22 years) and I think, "one more for fabric softener"---but suddenly I have a full inch of bubbly white, white, very soapy suds! Picture half a washer of water with a cup of tide! It's that soapy and I cannot figure out where the soap is coming from! Tonight, I had not even used a regular soapy detergent in the previous 15 cycles, having switched to an eco detergent from Costco and used little. I even ran a few cycles with no laundry and no detergent--no soap then!
Btw, the washer has only cold water rinses--I had not noticed the tiny print on the front of the washer--or I'd never have bought it. We learned in fabric class that icy cold water (it's snow melt here in Oregon) shocks fabric as badly as hot water, and it fails to get soap out as well. And everything comes out scratchy stiff like cardboard, and hurts my face--skin even peeled before I began opening lid to check on rinse cycle. I got rashes and dry skin from all the soap and ice water...until I began doing 7 or 8 rinse cycles on the items like washclothes, towels etc. Clothing gets hardly any soap, or I hand wash it now--am exhausted and want new machine! Can't sell this junk tho.
Anyway, so the way I rinse with warm or cool (not melted snow) water is I stop the washer and start over the wash cycle to get warmer water for the rinse. Then, I move the dial to extra rinse cycle for the rest of the rinse, after the water has filled, so it cannot go on to do an ice water rinse after competing the "wash" cycle that's really a rinse cycle with no soap.
I would hurt the person who designed this washer! It seems to add soapy water back into the rinse on the 4th rinse cycle! Sounds bizarre, but I always think that everything is finally rinsed ok and one more with a little fabric softener will do it, but when I look inside to add the downey, there's an inch of suds on top! I don't have suds like that on my wash cycles! It's bizarre...I've wondered if neighbor's suds are coming in, or am I haunted?
Last week, I hand-rinsed my washcloths and kitchen towels and put them in washer for the spin cycle, at end of the rinse cycle, just to get water out of them for dryer.... To my dismay, the spray of water while spinning (have no idea why washers add icy snow melt to my warm rinsed laundry during the final spin but they all do, you can hear the spray) was soapier than my original wash cycle--which has a teensy bit of suds which is gone in a minute or 2! Honestly, my washcloths etc were fully soapy again! I'd rinsed them so well that immersing them in warm water left the water clear and clean, but after the spray, they were just as soapy as after the earlier rinse cycles that had the inch of suds... I had to take everything out and spend another hour hand rinsing and wringing befor the dryer....
I have taken to using pint-sized tupperware to get the suds off the top rather than letting it go into the laundry or washer. I skim it out and put it down the kitchen sink. It's so soapy I'd have to do dozens of rinse cycles to rinse it out, so I skim it out manually. So new soap must keep getting into the washer! It also does not seem to matter whether the wash is full or half. Tonight the previous rinse cycle had been full, and pretty clean. But when I o;pened the next one to add fabric softener, it was only half full of water, and an inch or soap suds. I had wondered if the soap was outside the basket, and came in through the holes, once water got that high, but no. Does not matter. And I had wondered if it was caused by suction from stopping the rinse cycle during spin...but I went load after load for 10 days, never stopping a cycle early and it still put all that soap in the 4th rinse cycle. Or in the 3 cycle's spin at the end of rinse, when it sprays water on the spinning laundry.... This is a horror. Maytag ignores my emails. The handyman says new washers are terrible and wants nothing to do with it. I wish I'd paid whatever it took to fix my old whirlpool. 22 years and never an issue ever, never more than 3 rinses and then only a 3d because I'd used double soap to get out dirt from gardening or road trips like Santa Fe in the winter when shih tzus got covered with red clay dirt used on snow and ice--that stuff is lethal! Normally I added fabric softener on 2d rinse cycle and things were so clean. Now things are not clean, come out ripped, or with pilling like they aged 10 years in one night. So I handwash anything I want to keep nice. Washcloths are getting frayed, towels look bleached or faded....and I am relating to my grandmothers on wash day. Sorry it's just more problems not solutions.
Jan 23, 2011 | Kenmore Washing Machines
1 1/2 year old lg WM2496H showed oe error code while washing a heavy unbalanced load. I removed the wet blanket (sitting in water) and tried drain/spin command with empty washer but washer will not go into...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!!!!!!!!!!!
Jun 09, 2010 | LG WM2496H Front Load
My washer stops before the rinse cycle because it can't seem to drain enough to start the spin cycle. I just had the drain motor replaced one month ago. I get the error code nd. I can sto the cycle and...
I'd love to say yes! The machine is stopping because it will not drain. This is what the nd code means. Therefore, it will not rinse (add more water) or spin because the water level is already too high and to try to "spin it out" would put too much pressure on the machine with that much water in it. Drain out the water by putting the drain hose below the level of the washer (this takes forever) and call your repair man back!
Feb 18, 2010 | Maytag MAH8700A Front Load Washer
Washing machine seems to be washing ok but when it comes to the final rinse and spin the soapy water is pouring out of the soap dispenser on the front
this is happening because the machine is not draining the water away fast enough when going into the spin cycle. clean out the filter under the machine, this will solve your problem.
pallesappliancerepairs.com
Feb 04, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
5,819 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
