Question about Maytag EPIC MFW9700S Front Load Washer
Commercial Energy Advantage High-Efficiency Front-Load Washer MAH22PRAWW
Hi my washer is just showing bars on the screen "----" I think I just need to reset it but I don't have any idea on how to do so.
Take the front panel off, (12) screws in all. Start by the soap drawer (2 t-20's {safty type}). Then loosen the 4 T20's (also safty type) that hold on the aluminum face plate & display lens. Now the front meatl cover can come off (there is a snap clip by the soap drawer). Now remove the 6 - 1/4" inch screws 2- hold the top down, the other 4 hold the control board on. Now remove the control board & turn it over. You will see a white 3 pole connector plug, by it on the board it will say " service & coin". Remove the plug, now look at the display & you will see the error code. It will either be a "D" or an "F" code depending on your setup. Now push the lower left button on the panel (Delicates & Knits). your display should read 600 or 6 and a couple #'s (this is coin count). Replace the plug & your reset. Now just put it back together. Remember the display lens has a small window that need's to go bact into the upper left corner. I'll bet it will be an F22 or D17 - either way be carefull about closing the door (make sure nothing is caught by the door and boot seal). D8 or F21 -means long drain watch how much soap you use 1/4 cup or less is best. I hope this helps you.
P.S. keep track of the error codes- Maytag/Whirlpool may owe you an upgrade on the machines software.
Posted on Oct 27, 2008
  • 3 Answers
I dont know where the reset is on your model, but first try unplugging it for at least 10 minutes. That will reset most models.
Posted on Oct 13, 2008
How do i get door to unlock?
Unplug the washer, wait for 15 seconds or so, plug back in and hit power button the cancel. this should unlock the door as it should reset. Do you have any fault code on your display? Is there a dryer stacked on the unit? Good Luck
Apr 17, 2016 | Whirlpool WFW72HEDW WFW72HEDW 4.2 Cu. Ft....
Tip
Top-Load vs Front-Load Washers - Things to Consider
The traditional top-loader is more comfortable to load and cheaper to buy. High efficiency washers in top-load or front-load models are much more expensive but are water and energy savers, with front-load models having the best energy ratings. Front-load washers have a better spin which leaves less water in the load causing less drying time. High-efficiency models require low-sudsing HE detergent due to low water levels and they require a little more care. They also have more cycles and convenience features than traditional top-loaders. Warranty periods generally are a year regardless of washer style.
on Aug 17, 2010 | Refrigerators
Fridgidair affinity washer paused with error code EF2
According to SearsPartsDirect.com ( http://www.searspartsdirect.com/washer-repair/error-codes/frigidaire-front-load-washer-error-codes.html ) : EF2 Condition Too much suds Check/Repair Reduce the amount of high-efficiency (HE) high-efficiency detergent being used in the washer.
Aug 31, 2012 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Whirlpool wtw5tesvno
Hello.
Whirlpool washers are available in many colors and with different options, including various tub sizes, front or top load styles, a fabric care system, high efficiency wash features and energy, time and water sensors. The washers may be purchased in department stores, home repair stores and online. Many are Energy Star rated. However, the washing machine may malfunction occasionally and not agitate or spin. If this occurs, some troubleshooting steps may be useful in solving the problem.
1 sure the washer has electrical power and is connected to a grounded electrical supply. Replace or reset the circuit breaker or fuse if needed, particularly in event of a recent power outage. Make sure the washer lid is closed tightly before use; the washer won't work if the lid is open.
2 void selecting the following cycles: "Extra Low,, "Low," "No Spin", "Delicate," "Casual/Perm Press" or "Hand Washables." All of these cycles use little to no spinning or agitating during the cycle. Select the highest possible spin cycle for the fabrics being washed.
3 pen the washer lid and redistribute the load; unbalanced loads may cause the washer to stop or slow down. Add additional items if only one large item,
such as a rug or blanket, is in the washer.
4 Use only the recommended amount of laundry detergent, as excess sussing can reduce the overall spin speed or cause the washer to stop agitating. If the Whirlpool washer is a high-efficiency model, use only high-efficiency laundry detergent.
5 Examine the drain hose and straighten if kinked. Remove any possible obstructions and ensure the end of the hose is no more than 96 inches from the floor, as this will cause water to flow back into the washing machine.
Thanks.
Nov 13, 2011 | Whirlpool Washing Machines
Does kenmore recommend liquid or powdered detergent for front load machine
liquid is best as powder is mostly made of a "clay base" in its detergents??? yes i did say clay!
Nov 28, 2010 | Kenmore Elite 45986 Front Load Washer
The rubber seal at the front of the machine has gone mouldy. I have cleaned it before with bleach but the mould comes back all the time
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Oct 21, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
I have a samsung energy effecient front load washer machine ...I was wondering about the wash cycle ...is there always just a few cups of water in the drum to wash my clothing??...is this normal ..how can...
If its a High efficiency washer it doesn't use much water. Usually the front load washers are HE washers.. and you should use a HE detergent , it doesn't produce a lot of suds but it does clean( my clothes are very clean )
Sep 01, 2009 | Samsung WF203ANW Front Load Washer
Front of washer shows something inside the plastic on outside
It may just be spilled soap/softener the escapes from the tray when you load the dispenser. Happens here regularly. We just wipe it down from time to time.
Hope this helped. --W/D--
Jul 26, 2009 | Samsung WF218ANW 4.0 cu. ft. High...
Ge wbvh5200joww
That's because it is a high efficiency washer and uses 75% less water. The water and energy bills will thank you, trust me.
May 17, 2009 | General Electric WBVH5200J Front Load...
Maytag EPIC MFW9700S Front Load Washer Logo
1,075 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
