Baby Gear Logo
Posted on Oct 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 2 year old can get out of bugaboo even though she is strapped in? Is there extra straps or a harness for bugaboo
Stephen Faulkner
Level 2:
Guru:
  • Expert 541 Answers
  • Posted on Oct 11, 2011
Stephen Faulkner
Expert
Level 2:
Guru:
Answers
541
Questions
Helped
237619
Points
983
The Bugaboo's like 99% of all strollers have a 5 point harness. Two shoulder straps Two Lap straps and a center strap with the main body of the buckles. 2 year olds become little Houdini's pulling the shoulder straps off in both strollers and car seats. There are small buckle units you can buy that lock the two shoulder straps at chest height these are excellent at keeping kids in their place. Ask any nursery supply shop they should have them.
The shoulder strap adjustors (the things that make the strap longer/shorter) on my Bugaboo Cameleon are easily pulled down by my 2 year old. He is then able to get out of his harness & out of the pram....
No that should not happen. Bugaboo have very good customer service while in the two year warranty period that all turns to custard the day after it expires, So contact them now!
Hi I have a bugaboo bee 2010 and the harness straps the clip has snapped and broken were can I buy another clip !!
Bugaboo do sell this as a part and it's not too expensive. Google a local Bugaboo agent to order one as shipping can add a lot to the total price. Here's one site that sells them. www.babycare.nl/bugaboo-bee-seat-belt-set-p-2744.html
How do i take the old bugaboo harness out &
You cant.. you would need to buy a carrycot frame which comes with the straps £95.00 not cheap but you can buy it from www.buggypitstop.co.uk
Where can I get a harness replacement for my stroller? Thanks i,m in the UK, my bugaboo frog aubergine has a broken harness from the seat frame, where can i get a replacement
Hi, I trust that you mean the waist straps? I would suggest that you contact www.bugaboo.com who will be able to assist you in purchasing these spares. If the problem is with the **** strap or shoulder harness parts, you may have to purchase a new seat fabric. I hope this helps.
4helpful
3answers
Bugaboo Strap too loose
Well the best solucion is to cross shoulder straps and buckle it like that because soon they will learn how to take them of if you don´t do these: The straps have to be criss crossed on there chest  Hope these helps
2helpful
Adjusting the shoulder straps on the Maclaren volo stroller
What year is your Volo. Different years adjust differently. The newer ones have 3 height adjustment slots and a slider that adjusts the strap itself. They do not adjust way down though and even with teh straps as tight as they will go, they are still a little loose on my 15 month old granddaughter. I have found that buy tightening the waist straps it does keep her a little more secure.
23helpful
Need help with putting straps back on
I know this is months later, but here you are in case you (or anyone else) needs the info again. First, though, I feel that it wouldn't be responsible to neglect to tell you that if you got the seat in 2000, it is expired and no longer safe to use. Car seats generally expire after 6 years because the plastic degrades over time - in a 10 year old seat, it can look fine but actually be brittle enough that the entire harness can rip out of the seat if it's an accident. For the manual, visit Cosco's website and fill in the product number and date of manufacture. It will bring up a PDF file of the manual that you can download. To rethread the straps, first replace the **** strap. Slide the metal plate down through the slot in the seat, with the buckle facing out. Slide the metal clip under the tab and push it down to lock it in place. Facing the seat, start by threading the end of the harness strap down through the slot of the left side of the bottom (where the child's right hip would be). Under the pad/cover, thread it across the bottom of the seat and up through the matching slot on the right side. Pull it until you have equal lengths on both sides. Thread the buckles onto the the strap (one one each end) and buckle them. Thread the chest buckle onto both ends, making sure that the harness doesn't twist. Buckle it, too. Push the ends through the harness slots. Pull the harness through to the back, making sure that it goes OVER the metal bar, but UNDER the plastic adjuster handle. There is a loop sewn into each end of the harness. The adjuster strap has a splitter plate, kind of shaped like a Y. Slide each loop over the ends of the plate and all of the way into the slot, so that the curved ends of the splitter plate are exposed and the strap is secure in it's slot. Adjust the harness height by squeezing the metal bar on the back of the seat (the one behind the harness) forward and moving it and the plastic adjuster bar up or down to the correct position (at or below the shoulders for rear-facing, at or above the shoulders for forward facing). Do note that the very top slot is NOT for use with the harness - it's only to adjust the headrest when the seat is being used as a seat belt positioning booster and is not reinforced to support the harness in an accident! Adjust the tightness of the straps with the button/extra length on the front of the seat. Properly tightened straps should lay in a straight line without sagging and you should not be able to pinch up any slack (lengthwise going down the harness, not across the width of it) at the shoulders or hips. Adjust the chest buckle to lie in line with your child's armpits, never his neck or belly.
2helpful
Where can I get a new safety strap?
Contact bugaboo directly. The safety strap is an imporant feature of the stroller, and it should be replaced. Because it is directly connected to the chassis it is almost impossible to replace the strap apart from replacing the entire chassis.
Go to bugaboo.com and go the the contact section. Relay your situation with the strap, giving them your serial number and such and see how they respond. They may need to replace the entire chassis, but it is covered under the warranty.
If you have any further questions, or need a buffer between you and bugaboo, pelase do not hesitate to contact us. We are more than willing to help.
[email protected]
StrollerInfo
ww.StrollerInfo.com
2answers
Broken harness on bugaboo cameleon!
I actually called bugaboo and they are sending me a new clip. covered under my guarantee.
Broken harness on bugaboo frog
CONTACT BUGABOO
PHONE: 1-800-460-2922
E MAIL: [email protected]
WEB SITE: WWW.BUGABOO.COM
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
ZJ Limited
ZJ Limited
john h
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
