Question about Akai PT5492S 54" Rear Projection Television
Changing input source on AKai PT50DL14
How do you change the input source on the above named TV. My TV is the one listed above NOT what is in the Product Line. This is TV is connected to DISH network. While trouble shooting the receiver with Dish the input source got changed and I cannot find in the book how to change it back. I can get to Input on the TV; I can highlight the Input area BUT cannot change the input source from TV to AV receiver where it always has been and should be again. Therefore I have no picture. Dish was helpful enough to get me into this mess but does not know how to get it back to its original state. There should be a way to change the input source - I can find it, but not change it. The different input are gray indicating you cannot enter those areas..
Thanks
Suzanne
4 Suggested Answers
  • 1694 Answers
SOURCE: TV projects a pink/green shadow
Logically proceed one source at a time = disconnect all,
then hook-up one at a time or hook-up seperately.FYI, the
RF coax , composite and s-video inputs all share the same
circuitry, whereas component is a whole seperate video
processing circuit, with another difference between 480P and
1080 I . Sounds like you have a 1080 I problem, which might
be a little sister board..............................T.
Let me know..............Thanks.
Posted on Nov 12, 2007
  • 298 Answers
SOURCE: optical engine for akai pt50dl14
Here's a link to order the original Akai light/optical engine for this model (PT50DL14) from a major parts distributor:
Akai Samsung PT50DL14 Replacement Part Light Engine / Optical Engine Block
Posted on Feb 18, 2009
  • 10 Answers
SOURCE: AKAI PT46DL10 Bulb replacement
order from http://www.replacementlightbulbs.com/ i did and works good now mine was type j
Posted on Apr 29, 2009
How to source AV Input on remote
Search Results
    How do I change the input on my television? ' FAQ ' Cogeco ...
    https://www.cogeco.ca/.../how-do-i-change-the-input-on-my-tele...
    CogecoClick on the TV button near the top of the remote. Click on the video source button on the bottom left corner of the remote. Using the arrow keys to highlight/select the inputyou want. Some televisions may require pressing the source button multiple times to change the inputs.
    Understanding Inputs - Harmony Support - MyHarmony
    https://support.myharmony.com/.../understanding-different-input-changi...
    Televisions, AV receivers, soundbars and other home electronic devices switch ...Devices with toggle (or cycle) inputs have a single button on their remote that ... In the below example, you would press the Source button to bring up a list of ...
    Changing AV input on TV using Sky remote ' AVForums
    www.avforums.com > ... > Satellite TV, Sky TV & FreeSat
    Changing AV input on TV using Sky remote. Discussion in 'Satellite TV, Sky TV ...VSX-924 LG simplink changing AV source to TV. Posted By djrobmac In AV ...
    Selecting the DVD, VCR, Game Console, HDTV, Camera, or ...
Feb 08, 2016 | Venturer KLV39150 15" Under Cabinet LCD TV...
I cant get any of my inputs to change my kids hooked up the Xbox and now none of the inputs work for cable or DVD its just a blue screen with a no signal can anyone help me tonight please
Kindly check first if the batteries of your TV remote ( medium to change input ) are fresh. After that please check again the button on your TV remote for INPUT, SOURCE, or TV/VIDEO and it should give you input lists.
May 12, 2014 | Televison & Video
Replaced lamp and still no pic lamp light comes on then lamp light goes out PT50DL14
This Akai TV is actually built by Samsung. You need to count the blinking lights on the front panel.This indicates an error code.With the code I can tell you what circuit has failed in the TV.
Jul 30, 2009 | Televison & Video
Optical engine for akai pt50dl14
Feb 17, 2009 | Televison & Video
I signed on last night, asked a couple of questions, but the info sent to my e-mail didn't have anything to do with the questions I asked. Noticing in the forum, several people has the same problem:...
Howdy Mike-d. here, mikedee4@gmail.com
Hi CindyCee,
I have tried to post solutions, but they seem to be too long, so I will have to post more than once to get the info to you.
First part- the "Line-In" Video Source thing many people are having fun with. Try these options from the Samsung FAQs website.:
How Do You Switch Video Sources? spacer.gif Depending on the model TV you have, there are up to four ways to change the video source:
  • Through the on-screen menu controlled by your remote
  • Through the on-screen menu accessed through the Menu button on your TV's front panel
  • Through the TV/Video, TV/Component, or Source button on your remote
  • Through the TV/Video or Source button on the front panel of your TV
Your TV could provide any combination of these methods. Instructions for all the methods are below
Changing the Source Using the On-Screen Menu Controlled By Your Remote To use the on-screen menu of your TV controlled by your remote to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on your remote. The Main Menu appears.
  3. Select Input, and then press the Enter button. The Input menu appears.
  4. Select Source List, and then press the Enter button.
  5. Press the Up or Down arrow button on your remote to select the signal source, and then press the Enter button on your remote.
  6. Press the Exit button on your remote to exit.
Changing the Source Using the On-Screen Menu Accessed Through the Menu Button On The Front Of Your TV To use the on-screen menu of your TV accessed through the Menu button on the front of your TV to change video sources, follow these steps:
  1. Turn on your TV.
  2. Press the Menu button on the front of your TV. The Main Menu appears.
  3. Use the Up or Down Ch button on the TV to select Input, and then press the - or + Vol button. The Input menu appears.
  4. Use the Up or Down Ch button on the TV to select Source List, and then press the - or + Vol button.
  5. Press the Up or Down Ch button on your TV to select the signal source, and then press the - or + Vol button.
  6. Press the Menu button to exit.
Changing the Source Using the TV/Video or Source Button On Your Remote To use your remote to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button. The current source appears on the TV screen.
  3. Press the TV/Video or Source button repeatedly to cycle through the available sources. Stop when you reach the source you want.
Changing the Source Using the TV/Video or Source Button On The Front Of Your TV To use the TV/Video or Source button on the front panel of your TV to change the video source, follow these steps:
  1. Turn on your TV.
  2. Press the TV/Video or Source button on the front of your TV. The current source appears on the TV screen.
Part 2 -next
Jan 20, 2009 | Televison & Video
Akai LCT2662N Channel Changing Problem
there is a button that controls how many digits you can enter. it is located betwwn the 0 and source or below the 8 buttons
Sep 02, 2008 | Akai LCT2662 Television
Input source change on remote for tv
Are there not enough ports? You can buy port splitters to add more connections to your tv. Also, some surround sound receivers have port switchers too.
Apr 26, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Akai PT50DL14
is it in the screen it self ?
Feb 08, 2008 | Televison & Video
Humm coming from speakers - can't get cable to work
The RF input is the correct one for a cable signal. The other sources use the RCA and other ports which you can connect to other devices, like DVD or VCR players.
If the humm noise only happens when you're on the TV channel then it's likely just the station. Try changing the channel and see if that helps, and make sure the coax is screwed in all the way. Also make sure the other end, if connected to a VCR or other stuff, is tightly attached. If you share cable with many other people and the signal has snow (white spots on the TV), then you may need to buy an RF signal amplifier to reduce the noise.
Source changes the input (RCA versus coaxial versus component inputs), change the channel for different channels..
Jan 31, 2008 | Akai LCT2701AD Television
Akai PT5492S 54" Rear Projection Television Logo
83 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
