Question about GE JVM1850 1000 Watts Microwave Oven
Microwave turntable won't turn
Microwave made a kind of grinding noise. I put wd40 around under center hub that holds the glass turntable; sound much better but turntable doesn't turn. the food just sits in one spot
  • 2 more comments
  • richardwdoct Sep 21, 2008
    wrong product. should be model jvm1860d 02
    Did all suggestions. When I press turntable pad, it says turntable off I press it again and it says turn table on and then disappears. Still doesn't turn. go back to pad and turntable off shows up again
  • richardwdoct Sep 24, 2008
    problem seems solved but turntable once in a while won't turn and seems slower than normal. But above advice at least got it going. thanks a lot!!
  • Anonymous Mar 25, 2014
    It turns on to use & does warm things up, but get hot spots because turntable doesn't turn.
  • 706 Answers
You may have a tunrtable motor or spindle problem..
This info is from GE website..( link : http://genet.geappliances.com/geasearch/Dispatcher?REQUEST=GETSEARCHRESULT
To minimize the possibility of electric shock, unplug this appliance from the power supply before attempting any maintenance or cleaning.
  • Make sure the turntable is centered and seated properly. On models with a stirrer motor there is a shaft protruding up through the floor of the microwave. Make sure the turntable is securely fastened to this shaft. On models that turn on a ring with wheels attached, make sure the turntable is seated securely on the ring.
  • Check the turntable to make sure it is placed right side up. If the turntable plate is upside down it will drag on the floor of the microwave.
  • Check to make sure that there is no food or debris under the "wheels" of the turntable ring. Food can prevent the wheels from moving forward.
  • Be certain you are pressing a cook function rather than a timer function.
  • If the microwave has a turntable on/off feature make sure the turntable was not inadvertently turned off. Try depressing the turntable on/off pad to re-engage the turntable.
Posted on Sep 21, 2008
  • Rick Gelin
    Rick Gelin Sep 21, 2008
    Have you tried unplugging the micro and allowing it sit for a minute or two and then powering it back up? Sometimes the logic gets corrupt and a power down/up reset intilaizes everything back to normal ...
Microwave makes grinding noise when microwave plate on turntable
check for the roller spider under the plate
small plastic item that has 3 (4) rollers that allows the plate to turn freely
May 25, 2015 | Microwave Ovens
When the glass tray turns it makes a noise. When
This problem is commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to (and is located under) the center plastic piece (called a turntable shaft or coupler) under the middle of the glass tray that you were referring to. The following link explains how to access and replace one:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The price range will be determined by the model and manufacturer. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can refer to any of the following websites for comparison:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed offer helpful exploded view diagrams to assist you with locating and properly identifying the part(s) you need. If the model number is correct, the part number for a replacement motor is WB26X10135.
If you have any questions, please post back and let me know. I hope this helps you.
Mar 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a JES1142 which I purchased only one month ago. The turning plate rotates both clockwise and counter clockwise. When it rotates counterclockwise it makes a grinding sound. Why does it rotate bot...
It's normal for the motor to turn both ways, that's because of how the motor is made. As for the grinding noise, there's no reason the motor itself would make more noise turning one direction than in the other. The noise might be coming from the roller ring under the glass turntable. One of its wheels might be binding when it tries to turn counterclockwise.
Here's a test. Take the glass tray and roller ring out of the oven. Put a microwave-safe container with a cup or so of water in the oven and start it. Stop the oven and start it again, and the motor should turn the other way. If not, repeat this until you've seen the plastic coupling turn both directions. Note whether you still hear the noise as the motor turns each way. If you do, then there is something wrong with the motor and it should be replaced. If not, the noise is coming from the roller.
In either case, if the oven is truly only a month old it's still under warranty. Since you are concerned about the noise and are worried that the oven is defective, contact the store where you purchased it and see if they will exchange it or take it in for service. If the store can't help you, refer to the owner's manual for the service procedure to follow.
Hope this helps. Thanks for using Fixya!
Feb 13, 2010 | GE Microwave Ovens
JVM1440 BD - has a loud noise when I turn it on
Sounds like the "hub" for the turntable is worn. either that or the actual turntable motor. also insure the "plate" has a ring under it with wheels. sometimes I find those missing which in turn put far too much loud on the hub & motor, hence wearing them out pre-maturely.
you should be able to pull the hub out from inside the oven, if not. remove the filters below and if you twist just right you should see a small round device mounted with two tiny philips head screws, that's the turntable motor. It's usually the "hub" that wears though, so it's likely an easy fix. The most difficult part may be finding the new replacement part itself.
hope that helps,
good luck
Sep 26, 2009 | GE JVM1410 Microwave Oven
I have GE JES735-BJ02 that heats but makes weird sounds like a rumbling sound.
It could be a failing fan motor or magnetron.
While a microwave should never be left running unattended under any circumstances (as your owner's manual will tell you) it's even more important when one is exhibiting a failure or any odd behavior. So play it safe and stay with it while it's running!
And, as with anything that is not working right, it should be fixed as soon as possible or it can get worse.
If it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
GE Customer Service is here.
Let us know if we can help further.
Jun 27, 2009 | General Electric Microwave Oven
The turntable comes off it's track and sparks. The sparks have taken off the black paint on the inside of the door. How can I touch up the spot of the door? I rent and I can't afford to replace the thing!
Sounds like you haven’t correctly centered the ring assembly under your glass platter. Remove the glass platter, now place the plastic ring with tiny wheels in the center and move it around by hand. You will be able to tell instantly if it’s centered correctly. Now place the platter on the center hub gear.
To replace the coating on the microwave glass visit these web sites. www.partselect.com or www.applianceaid.com and enter your model number then scroll down to your part. Click to enlarge and you will be able to view the entire diagram for exact assembly. If you found any of these suggestions helpful, please rate my solution. D. Lange
May 01, 2009 | Daewoo KOR-63D5 Convection/Microwave Oven
Turntable makes grinding noise and barely turns
Unplug unit and take bottom off of it with the screws that go around the outer edge. The turnatanble motor has 2 screws and is removabe from the bottom underneath.
Sep 24, 2017 | GE JES1851 Microwave Oven
GE spacemaker microwave turntable
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
Mar 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable sounds like its grinding
Sounds like the bottom bearing has siezed. This is then rotating on it's mountings instead of nice ball bearings.
Just check it's not simply any support wheels you can easily get to.
It is possible to access this from inside. If you wish to repair it, unplug, and remove case screws. The drive assembly is easily visable from underneath. If you can get the main bearing off, clean it in parafin or WD40 and use a little light oil on it.
Make sure you replace the case properly - with all screws before attempting to start again.
The microwave generator is only active when electricity is applied, and usually the door assembly is integral to the microwave chamber.
Jun 11, 2008 | GE XL1800 1100 Watts Microwave Oven
Sharp r-1610 microwave
It could be the turntable motor, the turntable support (with built-in coupler) or a problem on the control board. I would first look at the 3-legged turntable support with built-in coupler to see if it got hot and warped. It should be flat across the top from the center to the end of the legs. If the support's legs are pointing a bit downward, it will prevent the coupler from making contact with the motor shaft. I've held bent ones a few inches over a gas burner to heat them up where the legs meet the center hub, then set something a bit heavy on it to hold it in place while it cools. If it needs a new one, it is part # FROLPB025MRK0 and it runs $19.50 retail at Tritronics. A quick (but not necessarily definitive) test of the motor is to grab the shaft gently with pliers and gently try to turn it. If it moves slowly and makes a high-pitched whining noise, it's likely okay. If it won't turn or grinds, it is bad. The number for the new turntable motor is RMOTDA264WRZZ and it retails for $8.87. Please note that you may need to look under model R1600, R1600, R1601, R1601, R1610, or R1612. They are all mostly the same. Tritronics is at http://www.wehaveparts.com The service manual for the R1610, R1611, R1612 can be downloaded at: http://www.microwavedisplay.com/R1610.pdf There may be a grommet bewteen the mtoro and turntable support. Don't lose that! Be safe!
Dec 03, 2006 | Sharp R-1610 Microwave Oven
GE JVM1850 1000 Watts Microwave Oven Logo
3,264 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
