Question about Refrigerators
WE have a RM100 LP Royal Dometic Auto Defrost Ref. which has done well till now. The freezer works well but the ref. section, no matter what setting, is above 50 degrees F. and food spoils; it, in the past has stayed at 34 F. on setting #2. We have cleaned everything and checked the lp regulator. We are stumped as what could be wrong. Any ideas? Ga.
dutchman05
  • 487 Answers
SOURCE: Food gets spoiled too soon
the problem is gas build up in your fridge
use arm and hammer baking soda boxes for the fridge.
that will help a lot
Posted on Apr 30, 2008
Krazytech
  • 725 Answers
SOURCE: GE PROFILE FRENCH DOOR 3 YRS. OLD
sorry you have a bad control board
Posted on Aug 17, 2008
abhishek33
  • 1239 Answers
SOURCE: FRIGADIARE FSC23F7DSB7
hi If the compressor doesn't run, it is likely that the defrost timer is malfunctioning. This part is located near the compressor. To test the defrost timer:
Step 2: Disconnect the wires from the timer and timer motor. Remove the timer from its brackets by backing out two retaining screws.
Step 3: Test the defrost timer with a VOM set to the RX1 scale. Clip one probe of the VOM to each defrost timer -- not motor -- wire, and turn the timer control screw shaft until it clicks. If the defrost timer is functioning, the meter will read zero. If the needle jumps, the defrost timer is faulty. Replace it with a new one of the same type.
Step 4: Connect the new defrost timer the same way the old one was connected.
To check the defrost timer motor, clip one probe of the VOM to each motor wire, setting the scale to RX100. If the meter reads between about 500 and 3,000 ohms, the motor is functioning properly. If the meter reads higher than 3,000 ohms, the timer motor is faulty. Replace it with a new one of the same type. Connect the new motor the same way the old one was connected.
Posted on Sep 12, 2008
  • 93 Answers
SOURCE: Dometic rm 2652 fridge works on a/c. i get a check
you may need to change the thermocople this cost about 12 dollars this is what make electricity to epen the gas valve thanks from gilles
Posted on Mar 15, 2009
SOURCE: DOMETIC REF
Check your 5 amp fuse on the control board on the outside of the trailer where the condensate drain comes out of the side of the r.v. -- while you're at it, check the 3 amp fuse also.
Posted on May 27, 2009
Our model 2852 dometic frig is freezing in the lower frig section all of a sudden. I have tried lowering the plastic temperature sleeve to "warmer' with no change. Why would it start freezing all...
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Check cold control (thats where you turn it colder)
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
Jul 30, 2011 | Dometic RM2852 Refrigerator
Freezer temp reaches 20 degrees refridgerator wont go under 50 degrees on gas or ac dometic rm2807
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge
First I would check the fan in the freezer. Listen to see if it is running
Leo Ponder
imufo2
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 28, 2011 | Dometic RM2620 Refrigerator
Hi I got fridge from charity shop hotpoint FF71S fridge freezer, and fridge is not cool enough, I do not have manual, can you help me please! Thanks Syeda
I'm Leo
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Jul 27, 2011 | Dometic Refrigerators
Freezer is cold but fridge is not. It is running electrically right now. It ran just fine in April when it was last used.
I'm Leo
Leo Ponder
imufo2
Jul 27, 2011 | Dometic RM2652 Refrigerator
Refrigerator does not cool properly. Freezer seems to be ok.
I'm Leo
Leo Ponder
imufo2
Jul 27, 2011 | Dometic RM2852 Refrigerator
Ref not cooling
remove the access panel in the freezer section and see if the evaporator coil is iced over,a little frost is o.k.,but when they are covered with ice they can't pass cold air,if this is the case defrost the coil with a handheld hair dryer,then check the defrost heater under the coil for continuity,if its good then suspect a defective defrost control be it timer or adaptive defrost
Jul 10, 2010 | Whirlpool Refrigerators
Hotpoint CTX16CYSJLAD freezer works fine but fridge isn't cooling
normally when the freezer works but the refrig doesnt, it is a sign that you either have a defrost problem or your evaporator fan isnt working or the airway between the ref and freezer is blocked. first I would check to see if the fan is working in the freezer section. If it is working then I would check to see where the air comes into the ref from the freezer and make sure you have airflow into the refig section. Some models have a thermostatically controlled damper, i dont think that is what you have though. If you dont have airflow you need to check the defrost system. your would need to remove the evaporator cover and check for icing or frost over the coils. there is several parts to the defrost system. Timer or control board, defrost limit tstat and the heater. To test these components you would need a volt-ohm meter.
Dec 17, 2009 | Refrigerators
General Elec. refrig. about 12 yrs. old. water in bottom of frig., cleaned up, found water a second time.
drain is cloged. at some point the ref section was set too cold. the defrost water from freezer drains through the ref back wall. becaust it was set too cold the drain froze. two ways to fix .... empty unit and unplug for 24 hrs. OR remove back panel, defrost drainrail, remove bottom panel ,remove ice, insert 1/4 inch tube down drain, and squirt very hot water down drain till it is clear of ice..... when defrosted set ref on "3"
Aug 26, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Kenmore elite, two doors. pull our freezer below. ref.not cold even at #7 setting (coldest). Freezer is working
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
OR..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 21, 2009 | Refrigerators
Warm fridge cold freezer
Hi,advance thermostat setting, to get colder , it's possible you got defrost problem, is there excessive ice building inside back of freezer? to determine if you have a defrost problem, unplug ref. for about an hour,let it defrost, let all ice melt away, it's better to remove your produce, keep doors open to speed up defrosting, after defrosting and cleaning plug back your ref, and let it work for another hour, and check result, if it's o/k, put back your produce, let me know, during hot summer months, regular use (opening) of ref, could cause excessive ice build-up evap. if after defrosting and cleaning ref. work good for 3 to 4 days, but start doing the same thing, let me know, it means you got a defrost problem. also check your thermostat, but first defrost and clean it, that could just be your problem. good luck.
Aug 13, 2009 | Refrigerators
Refrigerators Logo
166 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
