Question about Belling XOU270 / XOU271 Electric Single Oven
Cooker is a Belling XOU270 / XOU271
4 yrs old, on fan oven the fan works lights on but no heat. All other settings work fine HELLLLLPPPPP!!!!
  • sadeko60 Sep 28, 2008
    mine is XOU270, first it stopped heating on the bottom no heat at all, then the fan lights and sounds but no heat the top is heating nicely like usual so if the control panel is naked ? or what's the problem, please let me know if you get any news thanks
  • Belling Master
  • 3,463 Answers
You need to replace the fan oven element.
Posted on Dec 16, 2008
Tip
How to diagnose, fit and change a Belling fan oven element.
If your fan oven is not heating up properly the Fan Oven Element for your Cooker is usual culprit. Fitting an oven element is generally very easy, as demonstrated by The Apart4u video on How to change repair and replace your fan oven element:this fan oven element can usually be changed without taking the appliance out of situ.
on Aug 25, 2010 | Belling XOU270 / XOU271 Electric Single...
The oven stopped working but everything else still workes what is wronge with it
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Dec 25, 2010 | Belling XOU270 / XOU271 Electric Single...
There is no heat coming out of my fan oven, a Belling Countrychef 100df Range Cooker. The fan comes on and the light goes on to show it is on but there is just no heat ! It is about 7 years old. What is...
If the fan is working o/k, then it is sure to be the oven element that has failed.
This is located at the rear of the oven compartment behind a removeable cover.
Nov 17, 2010 | Ovens
The bottom oven on my zanussi zuq 875 has stopped working. No power indications of any kind.Top oven works fine. Followed instructions in manual but no power at all.ie; indicator lights, fan ,oven light....
Have you checked that the timer clock is set and not flashing,because the rest of the cooker will work after power outage but for the main/fan oven to work the clock needs resetting.
Hope this helps.
Jun 13, 2010 | Zanussi Ovens
Belling xou178 ss not heating up? fan blowing cold air, digital display working. is it the element and how do i fix it?
Yes most likely it is the element if the fan is still working.
First switch off the power to the cooker. You have to remove the back panel fom the back of the cooker which will give you access to the heating element, disconnect the wires and undo the retaining screws.
Remove the old element and fit the new, reconnect and it should be fixed.
Dec 30, 2009 | Belling Ovens
My hob is working but there was a bang in the oven and nothing is working inside the oven but the hobs are working fine. Many thanks for any help
If it is a fan assisted oven, and the fan is working o/k, then I would suggest that you fit a new oven element, if the fan is not working, then you are going to have to investigate further.
Please rate my solution.
Thanks.
Nov 08, 2009 | Belling XOU270 / XOU271 Electric Single...
The fan assisted oven has stopped heating up how can i fix this
If the fan is working o/k, then you needs to replace the oven element located at rear of oven compartment.
Thanks.
Oct 29, 2009 | Belling XOU270 / XOU271 Electric Single...
Replace Bottom Element in Belling XOU270
If this is a fan assisted oven, then there is no bottom element, only the fan element..
Remove the panel at the rear of the oven, there you will see the element, remove any screws that you can see and pull element towards you, disconnect the leads, don't loose them, and replace element.
If no screwws are visible then you will have to remove the oven from housing and do it all from the rear of the oven. Make sure power is off before you do anything.
Good luck.
Plz rate my solution.
Thanks.
Dec 15, 2008 | Belling XOU270 / XOU271 Electric Single...
Belling Synergie
NEED NEW FAN OVEN ELEMENT THAT CAN BE FOUND HERE
You need Element code AB20 on link below
http://cookerandovenelement.co.uk/bellingfanovenelement.html
element is located on back wall of oven you need to pull oven oven to remove the element element is held by two nuts from back and i screw from front
Dec 22, 2006 | Belling XOU270 / XOU271 Electric Single...
Belling XOU270 / XOU271 Electric Single Oven Logo
298 people viewed this question
Top Belling Ovens Experts
ashburton
Lawrence Oravetz
Are you a Belling Oven Expert? Answer questions, earn points and help others
