I have a 42 flat screen projector. The picture i see doulbe the normal color of the letter. then behind the letter they show up in different color. Then when there people on the screen or object there color shadow of them in red or green in color
  • 84 Answers
The colors have to be aligned most systems have a calibration screen with in the setup menu
Follow the instructions .... this is a common issue
LB
Posted on Sep 21, 2008
How much does picture tube for 42 inch flat screen Sanyo TV cost
There is no picture tube in a modern flat screen TV.
And unless it's physically broken, it's usually something else that has failed and not the screen.
A picture tube is a CRT (cathode ray tube) that sends electrons from the back to the front to light up different color phosphorous dots.
A modern flat screen TV on the other hand is LCD (liquid crystal display) that turns on and off to allow backlighting through multi colored filters. (LED TV also uses a LCD screen, the only difference is the backlighting is LED and not fluorescent lamps.)
Nov 26, 2016 | Sanyo Televison & Video
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Feb 08, 2016 | Televison & Video
LCD projector not displaying color only black and white
Did you ever see color on this projector?
It could be the composite input cant detect the "color burst" 3.58 mhz signal for chroma.
Have you tried a different input?
That could help you track down what the problem may be.
Oct 31, 2009 | Televison & Video
Sharp 46" 6 months old see rainbow colors from left to right
Did he change the big video board?The main backlight video baord that the prob.
Oct 23, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Half of my screen will turn in to vertical colored stripes
T-con board. Check lvds cable for tight connection.
Sep 15, 2009 | LG 42LC2D 42 in. LCD HDTV
Many different small color vertical lines all across the screen
It could have a bad Q-Box. It could cause both problems. The Optical Block also has the ability to cause it too. I would call a service professional to be sure due to the cost of the parts.
Hope this helps,
Skyassoc
Jul 04, 2009 | Sony KDF-E42A10 42 in. LCD Television
Wide screen movies dont fill screen
This is normal because they are broadcast in a widescreen format (If they fit the screen the aspect ratieo would be off on the picture!)
Dec 20, 2008 | Hitachi UltraVision 42HDS52 42 in....
Image flickers and colors off
I have the same problem as philvo. I was watching, the projector was operating normally, I heard a snap, there was a flash of light behind me I believe, and my Mitsubishi XD300U projector went to a black and white picture. That is all it will show now. All lights show normal operation. I would like to know if it is worth getting repaired. Does anyone have any ideas?
Jan 07, 2008 | Mitsubishi XD300U Multimedia Projector
Distorted Color and geometry of Picture
I've posted this solution several times but here goes. Try setting up the convergence through the menu by accessing the convergence setup menu. If this fails to work you have a bad digital convergence box and need a tech to replace it. About $60 to $100 fix.
Nov 03, 2005 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
Electro Med Services...
