Question about Nikon Office Equipment & Supplies
LS400 works ok after re-boot but will not work after hybernate
  • 928 Answers
That means that the USB turns off when you go to hibernate. This means that the USB port is configured to turn off when you go into hibernate to save power but does not come on. This can be chagned in the control panel then power options or power management. So that I can give you more specific instructions kindly provide me with the type of windows that you are using as well as the brand and model of your computer.
Posted on Sep 21, 2008
1990 LEXUS LS400 power steering heavy leak when making right turn. replaced high pressure hose..what's next
Steering gear(aka Rack and Pinion) look for leaks at the bellows boots over the inner tie rod ends.
May 03, 2015 | Lexus Cars & Trucks
Dashboard
Hybernation is probably turned off.
to turn it on
start -> control panel -> power settings -> hybernation tab
enable hybernation.
I'd recommend you reinstall the driver software for your dashboard screen / video card.
Do you have the cds or should I get you a download?
May 19, 2008 | Gateway m1300-3004372 Tablet PC
How to open when computer is hybernated
as you start it normally-just press the power button and you are done
Dec 09, 2010 | Acer Aspire 4730-4947 Notebook
Hp pavilion dv6000 notebook is not starting after putting into hybernate mode , black screen, all leds on the panel glow, but notebook doesnt boot
Thats the first problem of that model.They first dont want to go out of hybernate mode after that the wifi will not work and after that the video of that computer will be dead.I had like 30 HP Pavilion dv6000 and i just hey them nov but i can repair them.!!!
Nov 10, 2009 | HP Pavilion dv6000z Notebook
When waking from hybernation - woulnd't boot for 2 minutes
Hello ccc9294,
The system may be trying to restore the browser last settings (including tabs) when resuming from hybernation. Try closing the browser before going into hybernation. Then check to see how long the system takes to resume from hybernation.
If the system still takes too long then look at task manager (Control+Alt+Delete keys). Check the processes to see which ones may be taking up too much cpu or memory resources. It may be a system security application like McAfee or Symantec working in the backgound while coming out of hybernation.
I thank you for giving a rating to this solution if it has been helpful.
Have a great day,
martyshaw562
Jul 27, 2009 | Fujitsu Siemens LifeBook S7010D Notebook
Toshiba Satellite A55-S306 doesn't come out of hybernation
Turn the PC on, when it is booting up, keep hitting "F8" until windows boot options come up, choose "Safe Mode" and then once it boots into safe mode fully, go to the start menu and choose shut down. After it shuts down, turn it back on and it should go back into normal mode. From now on, don't use Hibernate, its buggy and has been since XP.
Feb 02, 2009 | Toshiba Satellite A55-S306 Notebook
Compaq 6715B
If your computer will turn on, get to the page where you have the options on how to boot the computer. Slect the option to boot from your hard drive. If it still will not boot up, then you are probably going to just have to repair your OS or do a clean install of your OS.
Sep 04, 2008 | Compaq Presario Notebook
Wont shutdown or hybernate on ac adapter, ok on battery
You might need to do a system restore from an earlier time from tools menue in accessories/or use a recovery cd/or format your HD
Aug 14, 2008 | Toshiba Satellite A135-S4527 Notebook
My A105 Toshiba Satelliet is stuck in hybernation and will not come back on
hi dear
oke ...try to remove the battery from your notebook, try on with only adaptor
after normal you can put your battere again
thnks
cropp
Mar 17, 2008 | Toshiba Tecra 8100 Notebook
Samsung V25 Laptop When it is powered up nothing is showing on the screen although the power light is on and you can hear a noise. This has happened before and it just came on.
One way to make sure the system is still working, remove the Batery, then plug the power adapter only and turn the computer back on, normally if the laptop goes into Hybernation mode and the battery is low on power this can happen. If that fixes the system then you can do a safe shutdown and re-install the battery and turn your laptop on and it should come on, the fact that you mentioned this has happened before makes me believe it is Hybernation issue. Good Luck.
Jan 07, 2008 | Samsung V25 CXTD 2000 Notebook
42 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Tanvi Thakur
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
