There could be a few reasons why the left deck on your Soundesign 4387 boombox is not turning when you insert a tape and push play. Here are a few things you can try to troubleshoot the issue:
Check to make sure that the left deck is not already playing a cassette. If a cassette is already in the left deck, try pressing the "eject" button to remove it and then reinserting it to see if it will play.
Check to see if the left deck belt is broken or loose. If the belt is broken or loose, it may not be turning the tape deck properly.
Make sure that the cassette is not upside down or inserted incorrectly.
Check the left deck for any visible signs of damage or debris that may be causing the issue.
If none of these troubleshooting steps help, it is possible that there is a more serious issue with the left deck of your boombox that will require more extensive repairs. In this case, it may be best to take the boombox to a professional repair shop to have it checked out.
Hi. Some amplifiers provide power for a record deck (or you mean a vinyl record player). Some vinyl record player have their one amplification system, some don't. Those with the amplification system work fine on older amplifiers but others require a back-up power, like a transformer to provide power for the record player. You need to enquire with the store person on the type of record deck or record player you can use directly with the V6090. I had an early Pioneer Amplifier and a matching record player so that I could play the vinyl disc and LP's on full volume. Later I switched to digital Pioneer 7 channel. This couldn't accept the record player because it did not have a power substitute like the older Pioneer. So, when the record player plays, no signal is being sent to the amplifier and therefore, no music is heard, except from the needle.
I must say I have never come upon a record deck that will only play one side of a good condition record!
The only action I can suggest is to replace the belt if it's a belt driven deck. Please make a note of how it fits before removing the belt. But why any record deck would treat a new record any different on one side than the other will be a mystery to any good engineer.
The only exception would be if the deck played one side good then played up on every other record. Till it's switched off for a while, then repeats this action.
The cause of this fault would be a part overheating the longer the deck is left on. When you stop it to turn over, the system fails. This is however more likely to happen on a direct drive turntable, not a belt driven one.
This is down to the head alignment. Once that is corrected the sound will recorded normally and playback normally too. However any tapes recorded during the fault will not play right.
The head alignment can be corrected, using two adjusting screws located either side of the head. To get at them the door cover has to be removed. To align you play a pre-recorded good quality tape. You adjust the screws till the sound is bright and clear and only the sound recorded on that side of the tape can be heard. Best done with headphones. If you can use a commercial music tape. If you use the decks own recordings it might not be right.
If there is any damage to the head mounting you will not be able to get the alignment right.
PS use the right screwdriver for the head screws. These are very small and easily wear away. If you wear the screw head away you might have a job getting a new small screw that will fit.
If I were you I would get that side repaired for the following reasons 1) the wear on the record head is the same on the B whether you record or play 2) the gap is a compromise if it is a record/play head and for play back only the quality is better albeit only seen on instruments . 3) Cassette machines will be very dear and scarce as the factories appeared to have stopped making them. If you have the quantity as I have then if your record side's head is more of value as you cannot record on the head 4) Is your recording side a "3 head " unit giving you "off the tape" recording capability.5) You loose the ability to do trick recording by adding voice with music This is the reasons for the time being If it is the unit in your pic then it was a very expensive unit
using the dubbing button on your recorder will recorder from your cd player on the right side of the deck to the cdr recorder on your left side..the left side of the deck is the cd recorder...hope it helps...just place a cd disc on the right side and a blank cd on the left side push dubbing button and wait till the left side reads the song on the recorder cd on the right
The left side is usually the playback deck and the right side is the record deck.put in a tape on the left side and push play.Then push the record button first and while holding it down ,the play button on the right side deck.One deck will not have record buttons on it,and that is the playback deck.
There should be a DUB button. After you push the DUB button, you will have another button that will allow you to select Dub form 1-2 or 2-1. If not there will only be one deck that will play while the other records and plays. Put the tape to be coppied in the play deck and the blank tape in the record deck push record and it should work.
I have the same deck and a very similar problem. Mine was stuck in the out position and would beep and move a little but there was no lights or music. I called Alpine and they told me that sometimes the inner sleeve around the deck will pinch the unit a little. I took my unit out of the dash and sure enough the plastic face plate came loose and moved about 1/32 of an inch when I slide it back in place and turned the power back on it worked perfectly. Hope this helps.
you have a record side and a play side make sure you have the right cassettes in the right decks, you press play on the one deck and record on the other, unless there is a sync button that starts recording. if this doesn't work tell me the model cassette and I will have another answer for you
