Question about Optoma EP719 XGA DLP PROJECTOR 2000L 2500:1 CONT DVI-D WITH HDCP Multimedia Projector
Optoma ep719 wont come off standby mode green light blinking
  • 4 more comments
  • jpax3 Oct 24, 2008
    i push the power button and the light flickers, but it wont't turn on, it stays in standby mode.
  • clfiredept Mar 31, 2009
    Green power LED just flashes. Projector won't turn on or do anything.
  • tamleis Apr 24, 2009
    I have the same problem. The projector worked fine a few days ago. The last time I checked the bulb, it had another 1,500 hrs left so it's not the bulb. Just does not seem to power on and remains in standby mode.
  • Tnts1 May 12, 2009
    I have the same problem, power light flashes and won't come off standby mode. The last time I used it ,I had to try a couple times to get it to power up....now it won't?
  • Anonymous May 25, 2009
    Same as above, no idea why.
    same issue.
  • 5 Answers
There is a stuffed 10v 3300uf capacitor on the power board. You need to replace it.
Bellow you can check in the picture where the capacitor is located.
Notice that in this picture I have already took the bad capacitor out and replaced with two small cords to reach the bottom and test the new capacitor.
To reach this place is not fast, several layers of plastic and metal must be removed, but is not a hard task to take the capacitor out and replace it for another.
It works just great! Now it is back on track with awesome image.
Posted on Oct 03, 2009
  • pbjax Nov 25, 2010
    Can you provide more details on actually replacing the capacitor? How do you take the bad one out? How do you fix the new one in? I am not really familiar with soldering, so any specifics would be great.
  • jdebaun1 Jan 11, 2011
    Thank you so much! Was having the same problem. Opened her up the capacitor was bulged and blown for sure.
The Optoma EP719, also known as the DX605 when purchased at TigerDirect, has been a great projector. But, I can't figure out why they installed a capacitor that has a shorter life expectancy than two lamps (or at least not make it replaceable too).
Mostly likely, you will find the capacitor in question has "bulged". This would cause your projector to slowly stop powering up over time, with each effort taking more and more time.
You will need to replace a "10V, 3300 uf HIGH TEMPERATURE or HT"CAPACITOR. It is a 10 cent part, plus shipping, should cost no more that $5.
Replacing is not difficult if you know how to wield a solder gun in a tight squeeze. But getting to the spot will take quite a bit of time.
Level of Difficulty = about 25 screws and tabs, and 5 cables.
Take out the bulb first. You will be making lots of movements on the unit and the less the bulb gets tossed and turned the better. Also, make sure the projector has been off for a very long time, components can still be slightly charged even if off. and unplugged.
You will need to remove the case (do not forget to remove the center screw deep from the bottom exterior). The case has about 10 tabs in addition to the screws. Use a flat edge to carefully nudge the tabs loose. Once removed, carefully pull back the tiny tab connecting the ribbon cable to the exterior button panel, pull out the ribbon cable. Make sure you note which direction the leads are showing so when you reconnect, you line it up the same.
Remove the heat shielding.
Remove the top circuit board. Note that it is not only secured with screws, but also with a PC style slot connection to a PC board upright directly beneath. You need to make sure when reassembling, you make a secure connection back here.
Remove the elevated PC board that is mounted on a black plastic riser. There will be ribbon connectors and power cables that need to be disconnected.
Access the lowest board that has the power supply on it. After removing a couple screws, you should be able to lift this straight up, and work on this board without interference.
With the power plug/mains to the left, the capacitor in question is to the right. Carefully remove any white glue that holds is used to separate the capacitor from other components. You can now just force twist the cap out, and the leads will be left in place.
You now have two choices. You can solder leads to the existing ones to connect the new cap (but you'll need to find space to place the cap when all is put back together, and it is a tight squeeze. OR, you can remove the leads with a solder gun and a tug, open the holes a wee bit with a very tiny drill (I used a super heated sewing pin to clear it out) on the PC board, put in the new cap and solder. Careful with the solder gun, the other components on the flip side should not be compromised. NOTE:When installing, make sure the NEG lead faces to the right (outside edge) of the PC board.
Assemble it all back and hope you don't have any screws left over!
post by Jeff Reid
thanks to Morris Burch for teaching me as a kid how to solder!
Posted on Aug 19, 2012
  • Andy Pforr
    Andy Pforr Nov 11, 2013
    Sorry...hit return...Anyway, I have an ep719 that won't fire up. I just replaced the color wheel since it blew apart and now the projector tries to turn on, the red lamp led blinks once, and then the projector tries 3 or 4 times more to turn on with no success. The bulb was fairly new and working fine when I removed it. I thought I'd tear down the machine and check the infamous capacitor but the board with the power supply looks slightly different and the infamous capacitor isn't there. There are a few others but not the one you mention. Have you heard of this?
I had the same problem where the power light would blink and pressing the power button wouldn't do anything. This actually happened to me twice and I fixed it the same way both times. I pretty much took everything apart so I could see the capacitor (like the photo above). I had to unscrew a lot of screws and unplug a lot of connectors, just remember how everything goes. At this point with everything apart, I just put everything back together and plugged it in and voila!!! It works. Like I said, I did this twice and it worked both times. I didn't replace anything or really fix anything. I think it could've been some connections that needed to get reset by unplugging and then plugging them back in. NOTE: I did try to see if the capacitor had a bulge, but it looked fine so I put it back together and now it works. Hope this works for you and please let people know if it does.
Posted on Jul 22, 2012
  • Somebody Dec 21, 2012
    For me it was the lamp cover switch. I bought an Optoma TX615 with this same symptom (green power light flashing for a few seconds before turning back to amber), but mine didn't come with a lamp cover. So the person I bought it from had shoved a piece of paper into the slot and put a piece of scotch tape to keep it in (and the switch depressed). Worked great for weeks...but then this happened. I'm guessing the paper moved or something, so I now have a plastic thing in there secured with a makeshift cardboard cover. Boots up/works great now!
I am troubleshooting the exact same problem on this model of projector right now. There is a short in parallel to R211 which is traced back to pin2 of the keypad jumper.
Posted on Jun 17, 2009
Seems like many people with this same issue. What junk, I'll not buy another optima!
Posted on Apr 11, 2011
  • jsreidnyc
    jsreidnyc Aug 19, 2012
    Actually, it is not an uncommon issue for electronics of all types to have bad capacitors. My iMac from a few years ago had exactly the same problem. Apple is a pretty reputable company, and yet, they still had the same problem that Optoma has had. This is not to say there are not better units out there though, but you'll pay a big difference between a Sony and an Optoma.
Lamp comes on briefly and then goes out
Check poewer connection
Check if fan filder is dirty ( if it is just hoover it out)
If "lamp" light on top of the projector blinks or stays lit - lamp probably faulty
How old is the Projector/lamp (average lamp life is around 2000-3000 hours)
Mar 01, 2011 | Optoma EP719 DLP Projector
Optima EP719 won't power on - when power button
check that the lamp is on securly and that the cover is on securly too.
Feb 02, 2010 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Optoma Projector power LED is blinking green,funs are not working, lamp not function, how can i solve this problem
i'd say power supply issue, but the led is blinking green. this means that it thinks it's in warmup/standby mode. but if nothing's running, the main board might be bad and needs to be replaced.
Dec 02, 2009 | Optoma HD65 DLP Projector
I have the Optoma ep719 and it will not power on. I plug it in the power light flashes. When you hit the power, the fans will come on and the bulb will light up for about 2 sec. Then it will go back to the...
some dry out, and you can't tell by looking at them. see if the colorwheel is spinning. if it chirps before it shuts down, or if it doesn't spin at all, replace it. otherwise replace the ballast.
Oct 27, 2009 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Optoma 719, can't get lamp and fan to turn on.
Jan 31, 2009 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Optoma EP719 lamp does not come on
Ok, so forgive me, I'm going by memory. Take the top cover off (4 screws on the side). Take the top silver shield off, look at the screws and only take off the ones you need. It's ok if you take more off, but its just more screws to track. You will need to take off the back outer cover. You will need to unscrew the hexagonal screws that the vga-out port uses to screw the connector to, as these are holding the back plate on. Once you get in, the board you need to look at is on the bottom back. Look for a capacitor that has a rounded top, not flat like the others. You will need to replace this with the same voltage and capacitance. Try an electronics site on the internet to get the right replacement if you cannot find it locally. Sorry for the poor instructions, but its just been too long. As a practice, take pictures as you go (during removal of parts) and you can use them to reinstall. Hope this helps as mine is still working.
Jul 24, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Projector not working
The solution is replacing teh Mainboard !
Mar 21, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Orange light on lamp icon on Optoma EP732H Projector
This same thing happened to me, I removed the bulb and put it back in, it reset something and I was able to use the projector again.
Nov 12, 2007 | Optoma EP732H EZPRO DIGITAL PROJECTOR...
3,853 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
