Question about Video Game Consoles & Games
PSP battery keeps popping out by itself or when ever you pop the back out to put a disk in. Its charger does not go in as well as it should = we think. You have to twist it to get the light to go. And we think there is a faulty connection in the psp battery connection - as it turns off by itself when battery is slightly moved even with the back on. What should we do. Thanks Jayson Kermode
  • kermodes Sep 21, 2008
    yes thanks
  • 13,433 Answers
Hey, if you can handle a screwdriver and take the psp apart you could inspect the connectors. I beleave sony will repair this for you, if its under warranty, or with a price if out of warranty.
sony repairs @
http://eservice.sony.com/webrma/web/index.do
Posted on Sep 21, 2008
  • Ekse Sep 21, 2008
    the battery, if its just not touching the pins correctly. try lifting the connector pins, with a needle for example. Is the battery loose inside?
    and the connector as I said earlyer, you would need to take the psp apart inspect the connector, possibly replace it.
  • Ekse Sep 21, 2008
    Let me know if you need anything.
    Thanks,
    Ekse
Frozen sony psp e1000
Trey taking the battery out for a bit.....Theres a panel on the back side....Pop off the lid and pull out battery.....then put it back in
Apr 13, 2012 | Sony PlayStation Portable (PSP) Slim...
My psp will nt charge or turn on it has been in myy locker for a while now when i plug it into my ps3 it will not charge
Try keeping your psp battery in a dry place for a day,then try charging.If this doesn't work..
Try the following:
a) Try charging using a usb cable...
c)Also try cleaning the usb port and power port or the place were u connect the charger to psp...
b) Remove ur psp battery and plug in the charger and turn on the psp... When it turns on put the battery back in (do not turn off the switch or psp when u put the battery back in)...
Mar 15, 2011 | Sony PlayStation Portable (PSP) Console
My psp 1000 keeps turning itself on when not in use, and after i use it for a while it will automatically turn off. My battery seems to work as normal and i dont see a problem with my charger. ive had it...
Two things I can suggest other then trying a new batter. 1. Pull out the battery for a day or two and let it completely die. Put it back in, and then recharge if fully. 2. Reformat your PSP by holding the R-Trigger. A recovery menu should then pop up and a reset command should appear. The PSP should then restart itself and being trying to repair itself.
Mar 12, 2011 | Sony PSP (Piano Black)
No screen is coming on psp
Turn the PSP off and remove the battery and battery cover. Remove the two screws underneath the battery. Remove the other two screws on the opposite side of the battery. Remove the final screw on the bottom edge of the PSP.Grasp the PSP on both sides with each hand and pull the cover off of the PSP. Locate the button bar on the bottom front of the PSP. Use your flathead driver to lift up the left side of the button bar until it pops up off the LCD support. Lift the button bar cable tab upwards to remove the cable and remove the button bar.Insert your flat driver into the small space on the left side of the LCD screen between the the LCD housing and the LCD mounting bracket. Twist the screwdriver slightly and the mounting tabs will pop out. Gently remove the other side of the LCD after popping out the first side tabs. Bend the PSP screen all the way down until you can see the backside of the screen.
Lift up the flex cable connectors and unhook the cables that connect the screen to the PSP motherboard. The tabs are brownish in color; they are very fragile, so be gentle. Lift the PSP screen out of the housing and place to the side.Place your new PSP screen into the PSP, face down like you had the older screen after popping out the mounting tabs. Connect all of the cables from the PSP screen into the motherboard tabs. Fold the screen back into the bracket, snapping it into place. Place the button bar back onto the LCD support, connecting the last cable. Place the cover back onto the PSP and tighten screws to finish.
Apr 15, 2010 | Sony Video Game Consoles & Games
Nothing on the screen when psp is switched on
Apr 02, 2010 | Sony PlayStation Portable (PSP) Console
How to fix my psp the screen wont turn on
I try to connect to my internet on my psp it says : An internal error has occurred error 80410a0b
You may need to do what is called a hard boot. Without shutting it down, pop the battery out and wait five minutes. Pop the battery in and try it again. Sometimes you may just need to keep hitting refresh or make sure the WEP Security code is correct.
Jun 20, 2009 | Sony PlayStation Portable (PSP) Console
Psp UMD disc won't work.
try to turn umb auto start off on system settings turn off system put disk in and try again
Jan 06, 2009 | Sony PlayStation Portable (PSP) Slim...
My enV won't hold a charge
You said the new battery worked but wont charge in the phone. You had water damage to the phone before getting the new battery correct?
First remove any Mini S/D card in the phone, power it off and remove the battery. ( only do this if its out of warranty and nothing else works. ) Your need to take the phone apart and get some alcohol wipes and wipe down the circuit board and connectors and anything that may have had water on it, if you see any crude, try to rub it off, there may be water and crude built up on contacts from the water damage that may be shorting the phone. Also check the battery contacts for greas or crud on the contacts. Once you have wiped down everything the alcohole should evaporate and take any moisture with it. Leave it out for a day dis assembled so it can air dry completely.
Put phone back together and hook up the charger and see if it charges. wait to put the memory card back in as in case you screwed anything up, you dont want it to take out your memory card with it.
I have performed this task with many of my friends cell phone that have gone through washing machines or got moisture in it because they take there phones into a steamy shower and moisture ends up shorting it out.
If nothing else works and you want to try it, go for it.
remember theres 6 screws in back and 4 around the mainscreen that are covered with triangular sticky covers, then use a thin knife or something to pry from one of the corners, one it gets started you just have to pop it apart with your fingers. Everything snaps back together easily.
Be carefull on the side with the screens, you dont wanto to pop apart the front screen from the mainscreen as its a pain to keep together when putting it back, also dont get any dust or fingerprints on the screen as they will drive you nuts if you put it all back together and theres a greasy fingerprint under the plastic that protects the screen.
Good luck
Mar 21, 2008 | LG enV VX9900 Cellular Phone
Psp won't turn on
Try to charge your PSP with your son's PSP charger and your problem should be solved if so your PSP charger is faulty.
Aug 31, 2007 | Sony PlayStation Portable (PSP) Console
Video Game Consoles & Games Logo
321 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
